VW Golf 4, 1998, 1.4 16v - Does not start / starter does not turn
xxrafixx 7044 4
  • Check battery voltage and starter ground connections
    #1 16473989
    xxrafixx
    I have such a problem. Due to the frost in May, the battery was completely discharged at night. I got in the car, turned the ignition to turn off the lights. The starter spun maybe twice and the battery fell, the trip meter reset and the hour disappeared. I removed the battery and went to the rectifier overnight.
    Today I put the battery in the car, turn the ignition key all the lights go out. I turn the ignition key, the ABS indicator lights up and goes out in a moment (the hands of the clocks fall below the 0 indication), and the starter does not even turn? Do you have any idea where to start?
    I have a TYTANDS300 alarm in my car at the beginning I thought that it still cuts off the ignition?
  • #2 16474003
    szymitsu21
    Help: 343
    Rate: 1300
    Check all the masses of the engine and body, for testing take the jumper cable and connect the negative point of the battery to the engine.
  • #3 16474023
    Hajna
    Help: 69
    Rate: 145
    When the clock hands fall to zero then the battery has no power, its end, measure the voltage at start-up.
    szymitsu21 wrote:
    take a jumper cable
  • #4 16475378
    xxrafixx
    I'm just waiting for the meter to measure everything. I tried to fire on the cables but also the starter does not turn anything. I don't know if the ignition is cut off because the alarm is defective or something.
  • #5 16476950
    xxrafixx
    Outdated. I unplugged the TYTAN alarm switch, plugged in again hard reset now helped smoke from arrow. To close.
