[Solved] Volvo V40 I - Timing replacement Volvo v40 I 1.8 petrol, 97 years
22431 5
  • #1 16993793
  • #2 16993841
    szymitsu21
    Help: 343
    Rate: 1300
    they should be ok :D
  • #3 16993842
    Ireneo
    Help: 747
    Rate: 2469
    The most important thing at the end is to rotate the shaft, whether there is a collision and whether it will return to the signs.
  • #4 16994464
  • #5 16994832
    szymitsu21
    Help: 343
    Rate: 1300
    TomaszNZM wrote:
    can you turn it around 2-3 times enough?
    2 times is a full cycle. This is enough.
  • #6 17024090
