Best TV for PS4 Pro Gaming: Sony KD-55XD7005 vs Samsung UE55MU6472 vs Samsung UE55MU6172
almanah123 4131 9
Which of these TVs is best for PS4 Pro gaming if I will use it only for games and care mainly about HDR and 4K picture quality?
For PS4 Pro gaming, you should not expect a big HDR effect from these models, because their panel brightness is too low and the HDR is described as similar across them [#16996853][#16997486] The Samsung MU6 series is the strongest gaming choice here because it has very low input lag, around 16–18 ms, which is considered perfect for games [#16997190] If you buy one of these TVs, try to get the VA-matrix version, since it gives better black levels in games [#16996853][#16997190] One reply also says the KS7000 is clearly better in HDR than the MU6172, so if HDR is the priority you need a higher model than these [#16997746]
  • #1 16996489
    almanah123
    Hello, I have a question about buying a TV only for games on PS4 Pro.
    I intend to buy the TV only for console play.
    I will not use it to watch TV, movies and the internet.
    I am thinking (up to PLN 3,000):
    - Sony KD-55XD7005
    - Samsung UE55MU6472
    - Samsung UE55MU6172
    I can't decide which one has the best HDR and 4K, which games will be the most beautiful?
    Or maybe there is no such difference, since tv is used only for games ?? hmmmm
    I emphasize again. TV only for games.
    Thank you for your help in advance.
  • #2 16996853
    Ludwik XVI
    Help: 1325
    Rate: 788
    These models have poor HDR - matrix brightness is too low to see the "wow" effect eg in Horizon ZD.
    All in all, no matter what you take - just make sure there is a VA matrix - better black in games,
  • #3 16996904
    almanah123
    And you can recommend a good model for 3000 PLN 55 inches ???
    Added after 57 [seconds]:
    For games only. Only for games.
    Ludwik XVI
    Help: 1325
    Rate: 788
    Samsung MU6 series have a very low input lag 16-18ms - perfect for games.
    If you hit the model on VA (they are also on IPS) then take it.
  • #6 16997248
    almanah123
    I will buy the one that has the best hdr. Only now the question? Which model at this price has the best hdr, which shows a good game effect.
  • #8 16997535
    almanah123
    I am wondering Just between ks7000 and mu6172 is the big difference in hdr ??? If you use it only for games ???
  • #10 16998358
The discussion centers around selecting the best TV for gaming on the PS4 Pro, specifically comparing the Sony KD-55XD7005, Samsung UE55MU6472, and Samsung UE55MU6172, all within a budget of PLN 3,000. Participants note that these models generally have poor HDR performance due to low matrix brightness, which diminishes the visual impact in games. Recommendations include the TCL 55C70 and Philips 55PUS6561, both offering low input lag and HDR capabilities. The Samsung MU6 series is highlighted for its low input lag, making it suitable for gaming. While HDR performance is similar across the discussed models, the Samsung KS7000 is noted to have superior HDR quality. Overall, the consensus suggests prioritizing low input lag and VA matrix technology for better black levels in gaming.
