[Solved] Samsung UE55MU7042 or Philips 55PUS7502 / 12 | TV up to PLN 4,000 - 5,000
pezet210 3258 9
Which TV is the better choice for a 55+ inch living-room setup with low input lag and good smart features: Samsung UE55MU7042 or Philips 55PUS7502/12?
Samsung UE55MU7042 is the better choice here, and if you can stretch the budget, the Philips 55PUS8602 is considered the stronger alternative over the 55PUS7502 [#17185881][#17191742] The thread also lists other models in this price range worth checking: TCL 55X2, Samsung 55MU7052, Sony 55XE8505, and Philips 55PUS7502 at a lower price point [#17186128] For the smart system, one reply says Android 7.0 runs smoothly, so it is not automatically slow or unstable [#17186258] Another point made is that TV speed should not be the main buying criterion; the system only needs to be stable, not necessarily the fastest [#17191742]
  • #1 17185857
    pezet210
    Referring to the topic, I am asking for help in the selection and for all the pros and cons of the above-mentioned TV (other suggestions ??). Below are my answers to the questions:
    1. How big is the room where the TV is to be 25m2
    2. How far are we sitting from the TV screen 2-3m
    3. How many people sit in front of the TV standard 2+ guests
    4. Are we sitting in front of the screen or also sideways to the screen? rather straight ahead, possibly the positioning of the TV will change then also at an angle
    5. Should the TV stand or should it hang? I prefer wall mounting
    6. How does the sun shine in the room? falls through the window perpendicular to the wall on which I intend to hang the TV
    7. What kind of TV do you currently have? CRT :D parents living next door have SONY KD-55XE8505
    8. What do we want the TV to have? voice control necessary, good SMART TV, low INPUT LAG (console, PC), good remote control;
    9. What signal will be connected to the TV? [WIFI internet !!, terrestrial TV, satellite in the future]
    10. What devices? occasionally a laptop, I intend to buy consoles and a home theater in the future
    11. How many hours a day should the TV work? about 3h
    12. Does it happen that you watch only one program for several hours? Yes
    13. What kind of programs do you watch the most? sports, series, movies
    14. Are you going to surf the internet? rather not, unless it would be super liquid
    15. Are you going to play games - if so, how many% a day? yes, occasionally approx. 1 hour
    16. Brand Preference? Samsung ??
    17. Size preferences? > 55 "
    18. What annoys you in TV sets? silting up, lack of fluidity (bad experiencewith Sony KD-55XE8505), poor sound quality
    19. Do you watch more in the evenings or during the day? definitely in the evenings
    20. To what maximum amount do you plan to purchase? 4000-5000 PLN
    21. How often do you replace televisions at home? ~~ 6 years
    22. Do you use internet applications often? sporadically / Netflix
    Please help and answer if the TVs mentioned in the title meet my expectations and which of the two is better, or maybe you recommend some other TVs? I would like to emphasize that I care about the voice control of the TV (preferably with a remote control), the display quality and smooth operation are of course important (the operation of the Sony KD-55XE8505 terrifies me).
    Feel free to discuss :)
    Ludwik XVI
    Help: 1325
    Rate: 788
    There is nothing to discuss here :)
    Samsung MU7042 is a better TV.
    What's wrong with the XE85? the smoothness of the motion on the matrix or the fluidity of the Android system?
  • #3 17185907
    pezet210
    The fluidity of the android system, how the TV turns on for a long time and can jam in the menu / switching between youtube and netflix applications, return to TV ... Channels switch for a long time, I do not know if this is the fault of the CI module (Polsat digital decoder).
  • #4 17186128
  • #5 17186134
    Ludwik XVI
    Help: 1325
    Rate: 788
    It's all clear.
    See how the tv goes on Tizenie, WebOsie or MyHomeScreen - in terms of the speed of the TV itself, it is much better than on Android TV.
  • #7 17186371
    Mariano11
    Help: 57
    Rate: 43
    I also heard that the new Android works very fast and stable.
    Android speed less important than system stability
    #8 17191742
    lesmian45
    Level 19  
    Help: 19
    Rate: 17
    Good, but without exaggeration that the speed of the system should be the main criterion for buying a new TV. Maybe Android is to be improved, but this is a feature of this system and it will remain so. Regardless of the power of the Prock, it will always jam - the most important thing is that it is stable. And if you have the author of 5,000 and LOCOLOCO offers you 55PUS8602, it's a sin not to take advantage of it.
  • Sony X8505 chosen after in-store 4k comparison
    #9 17191864
    pezet210
    Gentlemen, thanks for your advice and insights. Of course, we do not buy a TV for the Smart TV itself, but sometimes it gets damn if it can silt up sometimes. Fortunately, Sony with new updates improved this problem, and I got along with my parents and I take x8505 from them because they exchange for a bigger one. . Also in my case, the topic solved itself, I hope someone else will take your advice.
    BTW, the local inspection in the store showed, however, that Sony defends itself with the image and full support for 4k
    Best regards!
  • Staying with the Sony 55XE8505
    #10 17191871
    pezet210
    Best regards!
    He does not buy a new TV - he stays with the Sony 55XE8505
The discussion revolves around selecting between the Samsung UE55MU7042 and Philips 55PUS7502 TVs, with a budget of PLN 4,000 - 5,000. Users highlight the Samsung MU7042 as a superior choice, citing its performance and features. Concerns about the Sony KD-55XE8505's Android system lag and slow application switching are noted, with suggestions for alternatives like the Philips 55PUS8602 and TCL 55X2. The importance of low input lag for gaming and a good smart TV experience is emphasized. Ultimately, the author decides to keep the Sony 55XE8505 after evaluating the options and considering image quality and 4K support.
