LG K8 K350N Single SIM: Firmware Upload Issue with LG Flash Tool 2014
palik26 5970 8
  • #1 17007952
    palik26
    Hello!
    I have LG K8 K350N with play single sim and I have this problem - when uploading new software using LG Flash Tool 2014 I have this message and the firmware does not want to upload further:
    All USB drivers etc. are installed. I would like to add that the phone cannot be accessed because there is a pin code from Play and I bought a broken phone because I wanted the motherboard for a second phone.
    Can anyone help me to upload this firmware?
    marcin7904
    Help: 138
    Rate: 257
    Download LG UP from the attachment and try this video.
    • LGUP_Install_Ver_1_14_3.rar (11 MB) You must be logged in to download this attachment.
  • #3 17018497
    rudy178
    Help: 10
    Rate: 55
    It is not better to enter recovery mode and restart it with the keys?
    If you throw in LG soft not with play, but e.g. Europe, then you will get an error after restart (one-time only after restart) with incorrect customization.
    Also try the options as a colleague wrote above.
    There are problems with the flash tool and it crashes a lot of errors, it will still install the software, but if you are a beginner, you can damage the phone.
  • #4 17018556
    palik26
    Marcin's friend's method worked.
    LG UP + additional libraries for lg up and it went smart.
    And it's good that it went because I was rooting according to the youtube guide and I broke the phone.
    Nowhere have I found a step-by-step guide on how to root in Polish for K8 or K10.
  • #5 17018564
    rudy178
    Help: 10
    Rate: 55
    There is a bit of fun with root, look for XDA, the best there are instructions in YT.
  • #6 17044041
    jan009
    For me, lg up does not go to the error "LGUP can't load the model [C: \ Program Files (X86) LG Electronics \ LGUP \ model \ com"
  • #7 17047992
    palik26
    What windows do you have?
    I tried on Windows 10 and it was a total failure, I installed Windows 7 on the second drive and the usb drivers went elegant and the LG UP also works well with k8 and k10.
  • #8 17048543
    jan009
    I have win 10, tried these two ways and neither works.
    The android forum is already working, maybe I'll find the answer there.
  • #9 17048819
    palik26
    Install windows 7 under 10 you will not do it.
The discussion revolves around a firmware upload issue with the LG K8 K350N using the LG Flash Tool 2014. The user encounters an error during the upload process, despite having all necessary USB drivers installed. Suggestions include using LG UP as an alternative tool, entering recovery mode, and ensuring the correct firmware version is used. Some users report success with LG UP after installing additional libraries and switching to Windows 7, as Windows 10 presents compatibility issues. The conversation also touches on rooting the device and finding appropriate guides for the LG K8 and K10 models.
