[Solved] Firefox 58.0.1 Portable: Google Translator pops up & Disappears - Seeking Advice & Solutions
MM2X 3921 12
Why does the Google Translator add-on in Firefox 58.0.1 briefly open a translated page and then immediately close it, and how can I stop that?
The translated page is being blocked by the site itself, so Firefox opens it and then it disappears because the page refuses cross-origin framing with X-Frame-Options and related scripts [#17011840] Changing Firefox settings like `dom.allow_scripts_to_close_windows` or `browser.tabs.closeWindowWithLastTab` did not fix it in this case [#17011401] One workaround mentioned was blocking scripts with NoScript, which still worked in Firefox 58 [#17011987] Another user found that turning JavaScript off on that page made the translation reappear, which points to the page’s scripts as the cause [#17011864] So this looks like a page-compatibility problem rather than a general Firefox 58 translator bug [#17011840]
  • Translated page flashes then disappears in Firefox 58.0.1
    #1 17010724
    MM2X
    Rate: 618
    The Google FF translator works in such a way that a new page is opened with the translated text, so we have one in English and the other, e.g. Polish, which is very practical. In older versions of FF, this worked without a problem and differed from the translator in Chrome in that it wasn't chaotically crammed text.
    I currently have FF 58.0.1 Portable (the newest) and the problem is that for a split second the translated page pops in and unfortunately disappears :( . I looked for help on Mozilla's website but unfortunately it failed.
    Thanks in advance for any advice and suggestions.
    roxio
    Help: 108
    Rate: 213
    I don't know this add-on, does it work like a popup window? If so, then the Adblock add-on or other ad blockers can only trigger this window.
  • #3 17011385
    MM2X
    Rate: 618
    It is an add-on to the search engine, with a foreign-language page open, just press the letter "T" from the bar at the top and the second page already translated into Polish opens.
    The difference between the FF and Chrome translator is that the latter translates on the same page and it is chaotically crammed and sometimes hard to see. I turned off Adblock and, unfortunately, the same continues. I also tried yesterday with IE but it's a total massacre there :( .
    roxio
    Help: 108
    Rate: 213
    OK, I installed it, checked how it works and it works fine for me. So try to open a new tab in FF and enter it in the address about: config , accept the risk :) and search for a position dom.allow_scripts_to_close_windows if it is set to true change it to false. Restart your browser and try to translate something.
    There is also an option browser.tabs.closeWindowWithLastTab you can also change it to false
  • #5 17011590
    MM2X
    Rate: 618
    roxio wrote:
    search for the entry dom.allow_scripts_to_close_windows if it is set to true change it to false.
    I have "false"
    roxio wrote:
    You can also change the browser.tabs.closeWindowWithLastTab option to false
    I changed it to "false" but unfortunately it doesn't help.
    g107r
    Help: 811
    Rate: 993
    Translation from the context menu / right click and translate the page / also works like that?
    I blocked the updates, the last change killed me, the few extensions I used now do not work, and I will probably go back to the earlier version.
    Do you have that too? Because I would suspect incompatibility with the new version.
    @roxio What's your FF number? On 57.0.4 32bit it still works.
    Is this telegram really one way? It would be a pointless messenger. Don't you want to check it out on an older FF version? I had to install JAVA, because after the introduction of a new FF, the old one stopped working, and suddenly some functions stopped working, e.g. the inability to do so
    MM2X wrote:
    The Google FF Translator works by opening a new page with the translated text
    that is, citations and other such.
  • #7 17011811
    MM2X
    Rate: 618
    I tried 57.0.4 64 bit - Google Translator for FF doesn't work at all :(
    roxio
    Help: 108
    Rate: 213
    I have the latest FF and translator version 3.0.3.1.
    @ MM2X
    I debugged the page you gave me and we get a message Load denied by X-Frame-Options: https://www.forexfactory.com/ does not permit cross-origin framing.
    vbulletin_alt_global.js and vbulletin_global.js block placing the object in the frame so the translator crashes in this case
  • #9 17011860
    MM2X
    Rate: 618
    roxio wrote:
    they block placing the object in the frame, therefore the translator crashes in this case
    So it is impossible to translate it on the part of FF, I understand. Well, it remains chaotic with Chrome, and Chrome has the same translator and yet translates ...
    g107r
    Help: 811
    Rate: 993
    Earlier, on this one they broke my browser, I do not know if not some 53 - I did not follow which version is the NEW one, safer and in my opinion to d ....
    https://support.mozilla.org/pl/kb/modernizacja-technologii-dodatkow-dla-firefoksa?as=u Przedsiębiorstwosource=inproduct
    It comes out that it is 57, or 56 ??
    If it would work, you have to look for what you don't have from extensions or add-ons.
    As I wrote, then some Java and some others turned gray for me.
    For example, Google Translator has not yet embraced itself
    What I miss the most now is Tab mix plus ...
    roxio wrote:
    I debugged the page you gave me and we get the message Load denied by X-Frame-Options: https://www.forexfactory.com/ does not permit cross-origin framing.
    He, he, my so far and in question Translator it also crashes on this page, she translates, and then the translation disappears :( but another S3. Translator is not.
    What's better, when I turn java off, the translation reappears.
    I do it on / off Javascript Toggle On and Off 0.2.2
  • #11 17011987
    roxio
    Help: 108
    Rate: 213
    The addition of noscript and the blocking game works well even on version 58
  • #12 17012134
    MM2X
    Rate: 618
    g107r wrote:
    Heh, my current and said Translator is also crashing on this page, he translates, and then the translation disappears but another S3. Not anymore.
    For me, S3 did not cope yesterday :( .
    Wow..respect, thanks so much !!! :) :) :)
    I did not even know this supplement, I will read what kaman is about in a moment ;)
  • #13 17124631
    MM2X
    Rate: 618
    Peace of mind until today :) .
The discussion revolves around issues with the Google Translator add-on in Firefox 58.0.1 Portable, where the translated page briefly appears and then disappears. Users note that this behavior differs from older Firefox versions and Chrome, where translations are more stable. Suggestions include checking browser settings related to script permissions, disabling ad blockers, and using alternative translation methods like right-click context menu options. Some users report that the translator works on older Firefox versions, while others experience compatibility issues with the latest updates. The conversation also touches on the impact of Java and various extensions on functionality.
