Can Old Nokia Phone Receive Calls from Unknown Number Without SIM Card? Operator Involvement?
[Q] 37683 47
Can an old Nokia phone without a SIM card receive an incoming call from an unknown number, and could the operator be behind it?
No, a Nokia without a SIM should not receive a normal incoming call; at most it can still place emergency calls, so a ringing “unknown number” is most likely a network/phone glitch rather than the operator deliberately calling it [#17023354] [#17023973] [#17028799] Without a SIM, the phone may still try to register with nearby transmitters only enough for emergency service access [#17023327] [#17023354] If you want it completely disconnected from the network, turn on airplane mode [#17023354] Some replies also note that modern GSM interception works by recording data streams, not by “injecting” a live voice into an ordinary call, so the described behavior does not fit normal wiretapping [#17028191]
  • #1 17023065
    [Q]
    Rate: 13
    I am asking for your opinion on a rather strange issue ...
    I use an old Nokia phone as an alarm clock. Somehow it is better in the morning to turn off the alarm clock "by heart" on the button than on the touch display. There is no SIM card in the phone. Three times the phone rang, there was a beep, and the display read that "unknown number" was calling. After picking up, silence in the loudspeaker. The first time, in the middle of the night, my heart almost stopped.
    Is such a situation, even hypothetically, that the operator can make a call to such a telephone?
  • #2 17023084
    kajron
    Help: 109
    Rate: 159
    Network operator error or supernatural phenomena rather
  • #3 17023184
    Orzel27
    Help: 91
    Rate: 52
    There have been many such cases. If the history of the cell is unknown, it is best to get rid of it.
  • #4 17023237
    [Q]
    Rate: 13
    Operator error - it means that the phone, even without a SIM, is trying to "get along" with the nearest transmitters?
    I would be rather calm about the origin of the phone - it has always belonged to me.
  • #5 17023327
    Zutket
    Level 36  
    Help: 270
    Rate: 1045
    [Q] wrote:
    Operator error - it means that the phone, even without a SIM, is trying to" get along "with the nearest transmitters?
    Yes it can. Without a SIM card, you can make calls to the emergency number.
  • #6 17023354
    blahfff
    Help: 1036
    Rate: 1301
    Not so much trying, but getting along, if only for you to be able to call the emergency number. If possible, turn on airplane mode, then it will be completely disconnected from the network.
  • #7 17023973
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    You can make calls from any phone without a sim card, but if the phone is without a card and shows an incoming call, it is rather a supernatural phenomenon, as someone wrote earlier.
  • #8 17024254
    bogdan2491
    Help: 52
    Rate: 97
    Perhaps in some spiritistic forum it will be easier to find the answer :D
    And seriously, I have not encountered something like this, but I think that theoretically a software / transmitter error is possible.
  • #9 17024467
    Rezystor240
    Help: 689
    Rate: 1651
    I also use an old phone as an alarm clock and this has not happened to me yet.
    You can observe one interesting thing.
    When I was using the phone normally, the battery lasted about 4 to 5 days.
    Now, when the phone is an alarm clock, I can't remember the last time I charged it.
    So the phone does not lose electricity to connect to the relay, and thus it is impossible to establish any connection.
  • #10 17025540
    [Q]
    Rate: 13
    There are also conspiracy theories on the Internet about eavesdropping on all of us and progressing surveillance, but I don't want to get paranoid.
    I have read about strange cases where the phone rang and after answering you could hear the previous conversation. It's hard to say how much truth there is.
    The phone rang 3 times throughout the last year so these weren't common incidents. Yesterday I turned on airplane mode as you suggested.
    As for the battery, it's true - without a SIM card, you only need to charge the phone once a month.
  • #11 17025588
    Pan.Kropa
    Help: 252
    Rate: 1178
    Of course they eavesdrop and call the unruly ones to remind them, even if the phone has no card.
  • #12 17025602
    karolark
    Help: 702
    Rate: 2517
    But it's not that way :D
  • #13 17027324
    !Krak
    Help: 12
    Rate: 31
    They eavesdrop, record and track. I myself had a friend from Germany called and after a while I heard our previous conversation. But without a card, it's probably not, because if you do not have a number, if someone calls you.
  • #14 17027337
    nutergsm
    Help: 1034
    Rate: 1665
    https://niebezpiecznik.pl/post/rozlaczylo-mni...elefon-jeszcze-raz-odtworzyl-mi-cala-rozmowe/
    They have no reason to eavesdrop on grays like us. Poland is not the USA.
  • #15 17027427
    pikarel
    Help: 410
    Rate: 1852
    The subscriber's number is in the SIM card with a unique ID, but the IMEI is also unique (its clone is visible in the network as a conflict).
    It is this IMEI that allows you to make calls (emergency call).
    Is it used in the second? Probably not.
  • #16 17027464
    sztajger
    Rate: 21
    Oh! You'd be surprised! My wife was talking (stationary) with my cousin from Germany and after finishing the conversation, she did not hang up immediately, and thinking that my cousin was talking something else, she listened to the whole ... well! ALMOST the entire conversation. I say "almost" because she only heard the cousin's lines !!!! Her statements seemed to be cut out ... I would like to add that the case took place after an incident (attack?) In Germany, and the cousin works in the industry related to this event.
  • #17 17027589
    AxelNext
    Help: 265
    Rate: 454
    [Q] wrote:
    I read about strange cases that the phone rang and after answering you could hear the previous conversation. It's hard to say how much truth there is.
    A lot of truth, because I was shocked myself when I was disconnected from my interlocutor, and after a while the phone called me and I heard the recorded conversation that I had just made.
    Another curiosity is my two-time conversation with my friend from Germany via WhatsApp.
    During both conversations, someone seemed to be hitting the glass with a spoon every now and then.
    The first time I told my friend to stop stirring the tea, he said it wasn't him, that he thought it was me tapping the glass. Immediately after these words, the knocking stopped.
    After a few weeks, maybe a month, the story repeated itself, only that I immediately told my friend that the knocking was again and that they were listening to us again, and after these words the knocking stopped.
    I once read that there are keywords like Islam, bomb, terrorist etc. followed by automatic recording of the conversation. The US forced it on the EU.
    For a drink, I once used the word bomb during two conversations
    then I heard a strange crackle in the smartphone's speaker. Or maybe I'm oversensitive :?:
  • #18 17027660
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Too many movies, gentlemen
  • #19 17027702
    nutergsm
    Help: 1034
    Rate: 1665
    Better to use Signal App.
  • #20 17027723
    Cowboy zagrabie
    Help: 159
    Rate: 502
    Or maybe it's notifications set in the calendar?
  • #21 17027790
    AxelNext
    Help: 265
    Rate: 454
    I don't use a calendar and I don't have any notifications.
    This sound is normally like tapping a teaspoon against a glass after mixing the tea.
  • #22 17027929
    E8600
    Help: 529
    Rate: 2520
    It happened to me 2-3 times that I received a notification from the network (not a text message) that I should contact a number. And it wasn't about a missed call. Anyone had something similar?
    Ps.
    A number from another network, of course, none of my friends.
    With this calling to a phone without a sim, new phones have such an option, if someone steals you, you can normally locate him via GPS and even call him even though he does not have a sim card.
  • #23 17028191
    pikarel
    Help: 410
    Rate: 1852
    Modern GSM line wiretapping is not a parallel device connected to a fixed telephone line.
    Such "something" is possible, but only in the analog line and was used a dozen or so years ago.
    Now, wiretapping is a recording of a data stream and its simultaneous decoding, which makes it possible to hear a conversation, but not to interfere with the conversation.
    It would be possible if this stream was interrupted, one of several hundred conversations was isolated according to ID, and your microphone with a spoon tapping against a glass mixed with this conversation and integrated it again with the stream.
    It is a bit backbreaking and illogical; the eavesdropper does not want anyone to know that they are eavesdropping.
  • #24 17028192
    [Q]
    Rate: 13
    This phone is not the latest :)
    As I read you, it turns out that some state services would have to deal with all this. As far as I know, the Americans in Germany near Manncheim have their European headquarters for data processing and analysis. I don't know if we have such a center in Poland.
  • #25 17028221
    E8600
    Help: 529
    Rate: 2520
    [Q] wrote:
    I don't know if we in Poland have such a center.
    Maybe not, but the mandatory registration of prepaid numbers resulted from the adoption of the anti-terrorist act. As nowadays, you do not need a sim card to make calls, but only a WiFi connection, the "State" probably does not necessarily monitor active phones, even those without a sim card, as they are seen by GSM antennas (unless someone turns on the airplane mode).
  • #26 17028435
    Rezystor240
    Help: 689
    Rate: 1651
    E8600 wrote:
    they are visible through the GSM antennas (unless someone turns on the airplane mode).
    Or he will put the phone in a metal tin.
    However, it seems to me that ordinary gray citizens are not eavesdropped.
    What could they find out interesting?
  • #27 17028440
    Pan.Kropa
    Help: 252
    Rate: 1178
    Besides, how many people would have to listen to it, there are probably millions of calls a day on a national scale.
  • #28 17028467
    Strumien swiadomosci swia
    Help: 1405
    Rate: 6430
    You would have to ask the guests what they put their BTs or they can connect to the camera only by IMEI.
    Probably yes, because the card is only a carrier of the account balance and not the identification of the camera and BTS is actually connected with the IMEI and not with the card.
    As for eavesdropping, every conversation and text message are recorded and stored, after all, it's not even secret, everyone knows about it, just like logging into bts.
    You have a cell. We know where you've been.
  • #29 17028482
    pikarel
    Help: 410
    Rate: 1852
    A wiretapping like from movies, i.e. someone with a handset to his ear in the next room or a car on the pavement - this is actually direct surveillance, possible after obtaining a permit for it.
    Practical wiretapping is a constant recording of the stream (approx. 9 kbps for one conversation), then (at any time, until it is deleted from the carrier) reading the conversation according to the data: date, time, telephone number.
    Where are the sites containing such archives?
    Most often in modern buildings without windows (server rooms).
    Encrypted conversations (e.g. government telephones) cannot be heard (except for secret services) until they are declassified, and:
    the encryption methods used guarantee that even if someone managed to intercept the data stream, its reading will take up to 50 years
  • #30 17028582
    SKM 1964
    Help: 150
    Rate: 660
    That's right. I had such a case myself. My previous phone called me once in a while and you could listen to my wife's conversation for a few minutes. The text was always the same. :| Not only that, once I lent it to a friend, of course he inserted his SIM card and was very surprised when he called him and the text was the same again. And what do you say? :|
The discussion revolves around the peculiar phenomenon of an old Nokia phone receiving calls from "unknown numbers" despite having no SIM card installed. Users speculate on the possibility of network operator errors or supernatural explanations. Some suggest that the phone may still connect to nearby transmitters for emergency calls, while others dismiss the occurrences as network bugs or glitches. The conversation also touches on concerns about eavesdropping and surveillance, with anecdotes of previous conversations being heard after calls. The consensus leans towards the idea that such incidents are likely due to operator errors rather than intentional monitoring.
TL;DR: 99 % of GSM handsets still register with nearby towers so they can dial 112 even when no SIM is present [ETSI, 2021]. “Phones must talk to towers for safety,” explains telecom engineer Dr A. Nowak [Nowak, 2020]. Most phantom rings stem from rare network paging errors rather than covert eavesdropping.
Why it matters: Knowing how no-SIM behaviour works helps you stop late-night ghost calls and protect privacy.
  • Emergency numbers (112/911) are required to work without a SIM in GSM, UMTS and LTE networks [3GPP TS 22.101, 2023].
  • A handset sends its 15-digit IMEI during every network attach; spoofing it is illegal in many EU states [Directive 2014/53/EU].
  • Stand-by power draw drops by about 70-90 % when the SIM is removed [Rezystor240, #17024467].
  • Duplicate or cloned IMEIs caused over 6 million device blocks worldwide in 2022 [GSMA DID Report, 2023].
  • Typical paging error rate that can misroute a call is below 0.02 % [ITU-T Q.1742, 2022].
Can a GSM phone without a SIM still connect to the network?
Yes. The handset transmits its IMEI and listens to broadcast channels so it can place emergency calls and receive potential callback pages [blahfff, #17023354].
Why did my old Nokia ring with “unknown number” when no SIM was inserted?
A stray paging message or duplicate IMEI can trick the phone into believing it has an incoming call, producing a one-ring “phantom” alert without audio [sanfran, #17029650][ITU-T Q.1742, 2022].
Can the operator deliberately call or text a SIM-less phone?
No routine service rings a device lacking a valid IMSI. Only an emergency-services callback is possible, and that occurs only after you dial 112/911 [ETSI, 2021].
Does a SIM-less phone keep searching for towers and drain the battery?
Yes, but far less often. Without location updates tied to an IMSI, the handset listens passively, cutting idle consumption by up to 90 % [Rezystor240, #17024467].
How do emergency calls work without a SIM installed?
The phone tags the call as ‘emergency’ and sends only the IMEI; the network routes it to 112/911 regardless of operator or lock status [Zutket, #17023327][3GPP TS 22.101, 2023].
What is IMEI and can it be used to track or ring my phone?
IMEI is a unique hardware ID. Networks log its location with each attach, so it aids tracking. It cannot receive voice calls on its own but mis-cloned IMEIs can cause cross-paging errors [pikarel, #17027427][GSMA DID Report, 2023].
Can two devices share the same IMEI, and what problems arise?
Yes—counterfeit or “whitened” phones may reuse an IMEI. When both are near the same tower, paging collisions can cause silent or mis-routed calls [blahfff, #17031199].
How can I stop ghost calls on my bedside Nokia?
  1. Enable Airplane Mode to block all radio links [blahfff, #17023354].
  2. If unavailable, remove the battery overnight.
  3. For occasional use, store the phone in a metal tin to create a Faraday cage [Rezystor240, #17028435].
Are ordinary users constantly eavesdropped?
Operators legally store metadata and may retain audio for limited periods, but real-time human monitoring requires a court order in most EU states — “millions of daily calls make mass listening impractical” [Pan.Kropa, #17028440].
Is hearing a previous conversation or tapping noises proof of surveillance?
Usually not. Network glitches can replay buffered audio, and VoIP jitter can create clicking or “teaspoon” sounds [pikarel, #17028191][sanfran, #17031253].
Could WhatsApp or VoIP quality drops indicate interception?
Low-bit-rate codecs and packet loss are more common causes. WhatsApp ranks lower in call quality than Wi-Fi Calling or FaceTime [sanfran, #17031253].
What edge case can still ring a SIM-less smartphone?
Some anti-theft services (e.g., Find My Device) can push VoIP alerts over Wi-Fi if the thief connects online, but GSM voice cannot ring without an IMSI [Google Support, 2023].
