[Solved] Ideal Soldering Iron Temperature for Soldering Motherboard Capacitors: 280°C or 430°C?
brit32 65874 7
  • #1 17033748
    brit32
    I did not know in which department to add it, as I am asking for a transfer.
    Gentlemen, I am interested in what temperature the soldering iron should ideally have for soldering (motherboard capacitors)? I am curious about your opinions, because I read somewhere that one is 280 degrees enough for another 430. How do you do it?
  • #2 17033783
    LightOfWinter
    Help: 369
    Rate: 935
    Welcome.
    I think that the heat capacity of the mains is the most important for a comfortable exchange of these elements, because it has to heat up a relatively large surface. It would also be beneficial to preheat the bottom with hot air or a preheater.
    I use a temperature of 360 -370 degrees for soldering.
  • #3 17033785
    kamyczek
    Help: 394
    Rate: 574
    It all depends on the equipment and what you sold. Most soldering irons work similarly to the difference in how much they are able to maintain the temperature during soldering and desoldering large surfaces and components that receive a lot of heat from the tip. The surfaces of the masses, some transistors, can quickly lower the temperature of the mains, so that the tin turns into a solid state. Cheap soldering irons melt the tin well, but often have a problem with stable temperature during operation, which is why people often make up for this defect with temperature. Soldering pads and elements can be overheated with such a soldering iron. A good soldering iron solder everything without the necessity of drastic temperature changes. Differences in temperature may also result from the accuracy of the temperature measurement system of the mainsail and its location, and this also has to be remembered because it is important in settings.
  • #4 17033786
    pdemski
    Help: 36
    Rate: 71
    It depends on the soldering iron and the thickness of the tip. I just need to set 260 degrees on the soldering iron, and most solders are doing well, unless it sometimes happens that the plate dissipates heat well, then I overclock up to 300 degrees max.
  • #5 17033901
  • #6 17039424
    brit32
    But is not it that the high temperature can damage the system or the soldering station itself? Is there anything to worry about stations?
  • #8 18951641
    brit32
    Soldering station purchased, ordinary without Hotair.
The ideal soldering iron temperature for soldering motherboard capacitors varies among users, with opinions ranging from 260°C to 430°C. Many emphasize the importance of maintaining a stable temperature during the soldering process, as cheaper soldering irons may struggle to do so, leading to overheating or insufficient heat transfer. Preheating the board or using a hot air tool can aid in heat distribution. A common recommendation is around 360-370°C for effective soldering, while some users suggest adjusting the temperature based on the specific components and their heat dissipation characteristics. The actual temperature at the tip is crucial, as it can differ from the displayed temperature due to various factors during soldering.
