Renault Master LH35 120 2.5DCI 2005 - Coolant Temp & Engine Speed Sensor Pin/Wiring Diagram
rosak 25149 8
  • #1 17039999
    rosak
    Car dashboards specialist
    Help: 142
    Rate: 559
    Today I bought the diagrams for Renault Master LH35 120 2.5DCI, but nothing is wrong (attachment), maybe one of you will help me not to have to pay for the next hour.
    I just need to know which pin and which socket the sensor is on, from the temperature of the coolant and the engine speed.
    Thanks in advance.
    best regards
    • instrument panel.pdf (35.73 KB) You must be logged in to download this attachment.
    milejow
    Help: 1563
    Rate: 5149
    This information goes digitally over the CAN network from the ECM.
    This diagram is from Master 1.
    Działalność własna
    Mętów 99, Lublin, 20-388
  • #3 17040260
    rosak
    Help: 142
    Rate: 559
    Thanks milejow.
    Forgive the stupid question, but are you sure? Because that would mean that I will not repair the meter because it is functional. The customer reports that the tachometer and the temp gauge are not working, even though the built-in odometer test moves everything.
    Added after 1 [hours] 48 [minutes]:
    If I only knew how to look for this pattern. I was sure it was Master II, that's why I chose Master II, and you write that the schematic is from Master 1.
    The diagram shows the heading "X70" and it is also on the sticker on the meter board, but it is not 100% this diagram.
    After the number of the reg, it turns out that it is "Master Lh35 Dci 120 Lwb" and for h .. I can't match it with any option on their website.
    Renault Master LH35 120 2.5DCI 2005 - Coolant Temp & Engine Speed Sensor Pin/Wiring Diagram Renault Master LH35 120 2.5DCI 2005 - Coolant Temp & Engine Speed Sensor Pin/Wiring Diagram Renault Master LH35 120 2.5DCI 2005 - Coolant Temp & Engine Speed Sensor Pin/Wiring Diagram
    Renault instrument cluster diagrams are interchangeable across models
    #4 17042151
    milejow
    Help: 1563
    Rate: 5149
    rosak wrote:
    but are you sure?
    At 1000%, I have the same countertop in my wife Clio from 2004. and I know him about the last screw. Besides, I once wanted to transplant these clocks to Thalia and completed my doctorate on them for a few weeks.
    At the bottom you have a diagram of the watches in Trafic 2004, they are identical in the Clio II, Master II, Kangoo and Trafic from 2004 and up.
    And the last thing - schematics are available on the web, you don't have to break the pig :D
    http://manualy.autooo.eu/pl/renault-manualy/138-renault-visu-dvd-schemy
    Działalność własna
  • #5 17042689
    rosak
    Help: 142
    Rate: 559
    Thanks a lot good man!
    I can see at first glance that this is the pattern. I can not see much more because the quality of the graphics has been cut a lot, it makes no sense in such a forum, but I will download what you need from this link ;)
    milejow
    Help: 1563
    Rate: 5149
    rosak wrote:
    but I will download what I need from this link
    You can do it because yesterday I just downloaded a schematic for 2008 (I only had until 2003) and everything works fine.
    Działalność własna
  • #7 17044243
    rosak
    Help: 142
    Rate: 559
    Yes, I already downloaded the CD from this link, it is an offline version of what is on the net where access is available for 8 euro per hour.
    I followed your screenshot and downloaded Autodata as well but I haven't checked it yet.
    Thanks again.
  • #8 20512388
    Dejw321
    Hello, buddy, did you manage to solve the tachometer and temperature problem? I have the same case, I'm curious what was the problem for you?
  • #9 20512931
    milejow
    Help: 1563
    Rate: 5149
    So what??? There is no case in the subject here, a colleague wanted to know where the temperature and speed signals for the indicators are.
    Działalność własna
The discussion revolves around identifying the pin and socket locations for the coolant temperature and engine speed sensors in a Renault Master LH35 120 2.5DCI (2005). The original poster purchased diagrams but found them unhelpful. Responses indicate that the information is transmitted via the CAN network from the ECM, and there is confusion regarding whether the schematic pertains to Master I or Master II. Users shared links to relevant diagrams and resources, confirming that similar schematics exist for other Renault models like Clio and Trafic. The original poster later found a useful offline version of the diagrams and expressed gratitude for the assistance received.
