bmw e60 - after replacing the bulb in the ring it does not light up
orcho 12417 10
Why does the BMW E60 angel eye ring not light after replacing the burnt bulb, and will clearing the short-circuit fault restore power?
Yes, the output can come back after clearing the fault, because the light module can shut off that circuit after detecting a short; if the fault becomes latched, it may need a deeper reset such as Tool32 to clear it [#17170905] Check the fuse and the wiring/connector to the right lamp, since a cable or module fault was also suggested when there is no voltage on the plug [#17173381][#17172836] Make sure the correct bulb is fitted, because H10W is the specified type [#21099104] If there is still no power and the fault returns, the module itself may be the problem, and one reply pointed to the AHL light module as needing replacement [#21099067][#21099115]
  • #1 17051808
    orcho
    Hello ,
    The problem with the rings in the right lamp for 2 days, I had an error that the rings do not light. Before starting the replacement, I started and extinguished the car several times, where the error was repeated. After unscrewing the lamp, the bulb was actually burnt. I replaced it, but the new one shone only once, the second one did not start, come on. All the lights on the lamp work. the bulb in the holder works under another plug. no voltage on the plug, now the question is whether the car has coded a short circuit error in the car and after deleting the brightness will return? has anyone seen this before?
  • #2 17170875
    sebal7
    Rate: 12
    Rather, it should be so that after clearing the error, the voltage will return.
  • #3 17170888
    kkknc
    Help: 1915
    Rate: 6709
    Probably not. The system is testing all the time.
  • #4 17170905
    sebal7
    Rate: 12
    Not true, if it catches a short circuit, it cuts off the bus where the short circuit was and does not test. You need to clear the error as soon as possible because then there is a possibility that the error will stay forever and you will need to run tool32 to get rid of it and it doesn't always work.
  • #5 17172836
    orcho
    there is no short circuit fault. is ordinary. there is a possibility of chiming the cables and the module is necessary I do not know what pins in the module are responsible for the right lamp, I would check if there is voltage
  • #6 17173381
    sebal7
    Rate: 12
    did you check the fuse? I can give you 2 or 3 FRM descriptions, maybe you can figure something out
  • #7 21099067
    orcho
    AHL light module to be replaced
  • #8 21099104
    omegolotC30NE
    Help: 51
    Rate: 138
    Did you put in the correct bulb? H10W should be. What code does the module report?
  • #9 21099115
    orcho
    Yes correct. No power on cable. Ring currently running on power from second lamp. After such a time the computer has a permanent short circuit error.
  • #10 21099133
    omegolotC30NE
    Help: 51
    Rate: 138
    It has no right to work connecting either side to the opposite lamp, The current does not agree and the module shuts this down after a while. Can you give the error code?
  • #11 21099142
    orcho
    I've had the same breve connected like this for quite some time because the current escaped there too. When the car comes back from the electromechanic I will insert what error the module gives. Currently the car is on the error with cruise control when you go over 100km/h, it gives cruise control 2f4f ista
The discussion revolves around an issue with the BMW E60's right lamp rings not lighting up after a bulb replacement. The user initially encountered an error indicating the rings were not functioning, leading to the discovery of a burnt bulb. After replacing the bulb, it only illuminated once, and subsequent attempts failed, with no voltage detected at the plug. Responses suggest that clearing any error codes may restore functionality, but caution that if a short circuit is detected, the system may disable the affected circuit. Suggestions include checking the fuse, verifying the correct bulb type (H10W), and ensuring proper voltage at the lamp connections. The possibility of a faulty AHL light module is also mentioned, along with the need to check for error codes related to the module.
