BMW / E60 / sedan - Connecting the universal lamp hook driver
fifolin 6624 3
  • Wiring the shared fog and position signal on BMW E60
    #1 16396255
    fifolin
    Rate: 20
    Can someone help in connecting the universal towbar module to the lamps in the BMW E60 2003?
    3 bulbs in a row shine in the position.
    After turning on the stop, one of them (completely right in the right lamp) shines stronger.
    When the fog light is turned on, another of them shines stronger (completely left in the right lamp).
    The direction is on a separate bulb.
    I have to give control signals to the universal module (6 cables in total), i.e .:
    1st stop
    2. L direction
    3. P direction
    4th position left
    5th position of the law
    6. fog
    The problem is that the stop is carried out on the same bulb as the position bulb (outermost)
    The same fog light is implemented on one light bulb as the positional light bulb (inner extreme)
    There is a note in the description:
    "When the STOP and position lights in the car are controlled by one wire (1-wire), connect it to both inputs 58R / L and 54 in the module.
    And it is clear what to do with the fog signal, which is also implemented on one of the 3 bulbs that light up as a position?
  • #2 16396287
    Ireneo
    Help: 747
    Rate: 2470
    How good the module will detect voltage fluctuation control. Plug in before asking, call the manufacturer and don't ask without specifying the module company. The fairies are elsewhere.
  • Trailer fog light switching and bulb-warning suppression issues
    #3 16396747
    fifolin
    Rate: 20
    I just didn't want to try at random so as not to miss something.
    But I tried it and it works as it should.
    One issue remains to be solved: as far as I know, the fog light in a car with a trailer attached should not light, it should only burn in the trailer. How to solve it so that the computer does not hit the eyes on the board with messages from the burnt bulb. I thought to throw in a relay that switches either the car or the trailer as it is connected, but this will not solve the problem because in my car there is a rear halogen implemented on one wire along with the position.
    Any ideas?
  • #4 16396880
    Ireneo
    Help: 747
    Rate: 2470
    Do not connect the fog cutter
