BMW e39 no blinkers, no high beam lights, no meter and console illumination
Dziedzic2494 9513 1
  • #1 16777662
    Dziedzic2494
    I have a problem with the bmw e39. Namely, after a car parked in the garage for several days, I noticed that the right turn signal and the left high light were on. After turning the key, the low beam, left high beam, right turn signal and parking lamps come on, even though the light switch is in the off position. The direction indicators do not work at all as well as the emergency ones, the high beam does not work, the meters' backlight and the console's heating lighting do not work. I found out that he might owe the LCM module so I unplugged it and put it back on and everything started working as usual. Unfortunately, until ... After a few km of driving, something stopped connecting and the meters and the heating console lighting began to blink and the direction indicators again refused to obey. Now everything works once in a while and after a while the described symptoms come back.
    Dear forum members, I am asking you for help. Maybe someone knows something about it, or has had a coincidence.
    best regards
  • #2 16777883
    Doktorr
    Help: 287
    Rate: 1095
    Check the power supply of the LCM module by the key (sometimes such symptoms are caused by a damaged ignition block), if ok, put another LCM with the same numbers
