Vordon HT-869v2 - Control of the radio from the steering wheel
dudi004 12159 1
  • #1 17066433
    dudi004
    I recently bought a Vordon radio and in the wiring I have 2 KEY1, 2 cables to be used to control the radio,
    I have a Honda CR-V and there is no steering wheel control but I thought to add control, e.g. link (this is steering with Renault Scenic 1998)
    I just do not know how to connect them to the radio
    On the producer's website I found something like that link
    Do you need a "driver" or something like that?
    Thank you in advance for your help
  • 5-resistor workaround for Megane II joystick control
    #2 17071639
    D_Mrozu
    Help: 31
    Rate: 94
    I warmly welcome.
    I contacted the Izotech company that produced the interface - I had previously ordered interafce to Kenwood, to which I replaced the original TunerList. I thought the interface was universal and would adapt it to Vordon.
    I received the answer:
    Subject: Re: Vordon - Megane
    > Hello,
    > car from which year?
    > These are different adapters.
    > We make new ones.
    > The roll is not programmed.
    Renault Megane 2 from 2003
    Joystick 8 function - roller operated with Kenwood.
    Please give me the price of a new interface that would work with Vordon TH-869V2
    Greetings.
    > Hello,
    > acted with Kenwood, but it will not work with Vordon.
    > Adapter PLN 129.00 + PLN 16.50 shipping on delivery.
    > PLN 10.00 with prepayment.
    > Execution about 7 business days.
    > Regards
    > Izotech
    So that PLN 129 and the roll will not work.
    I did something like this (I added 5 resistors) and programmed Vordon:
    I do not remember the resistor values - I bought a dozen or so in an electronics store after 15gr / item. They were from 1kOhm to 22kOhm, which I "drew" from the bag, I sold it.
    In this embodiment the roll does not work, but the price is only 5 resistors.
    Use the joystick from MeganeII - you can program 6 functions.
    Probably, using other randomly selected resistors, you could program other functions by simultaneously pressing 2 keys.
    Greetings.
