KIA SPORTAGE RADIO MOUNTING - Control from the steering wheel of the VORDON HT-8
mariuszp1972 6981 4
  • #1 16269013
    mariuszp1972
    Hello, I connected the Vordon HT-869V2 radio, everything works except the steering wheel control, can someone give me a hint how to solve this problem?
  • #2 16269470
    rafal35
    Help: 23
    Rate: 47
    This radio probably has no input for connecting an additional control
  • #3 16269489
    mariuszp1972
    mariuszp1972 This radio has to have input to the control, because in the instructions there is a programming method and in the radio in the menu there is a window in which it is done. And the problem is how to connect it. There are free cables in the ISO radio bundle and I don't know where to connect them.
    mariuszp1972 This radio must have input for control, because the instructions in the instructions are programming method and the radio in the menu is the window in which it is done. And the problem is how to connect it. There are free cables in the ISO radio bundle and I don't know where to connect them.
  • #4 16269505
    rafal35
    Help: 23
    Rate: 47
    Maybe I missed in the description of the radio. The car should have an additional control cube, just a matter of whether the signal standard will match.
  • #5 16323672
    mariuszp1972
    Problem solved. I bought a module for 149 PLN and everything works.
