[Solved] Huawei P8 Lite: MMI Function Test - How to Run? Test Conversation Microphone, Code Needed
muzior 26484 4
  • Need code to test P8 Lite microphone function
    #1 17072097
    muzior
    Rate: 68
    Colleagues, what code to run the test of the MMI function. I want to test the conversation microphone in one of my P8Lite. Interlocutors complain that I am very weak. The smartphone in perfect condition, never fell, used by his wife and suddenly it is not known when the problem with the microphone began. Microphone net clean. I do not know if the problem is soft or the microphone itself. I am asking for a hint.
  • #2 17072500
    jurkuc
    Help: 146
    Rate: 315
    * # * # 4636 # * # * - Information about the phone, use and battery
    * # 06 # - IMEI number
    * # 0 * # - Enter the service menu
    * # * # 34971539 # * # * - Detailed information about the camera
    * # * # 273282 * 255 * 663282 * # * # * - Back up all media files
    * # * # 232339 # * # * - Wireless LAN test
    * # * # 197328640 # * # * - Enable test mode for the service
    * # * # 0842 # * # * - Backlight test
    * # * # 2664 # * # * - Test the touch screen
    * # * # 0842 # * # * - Vibration test
    * # * # 1111 # * # * - FTA software version
    * # 12580 * 369 # - Complete information about software and hardware
    * # 9090 # - Diagnostic configuration
    * # 872564 # - USB login control
    * # 9900 # - System dump mode
    * # 301279 # - HSDPA / HSUPA control menu
    * # 7465625 # - View phone lock status
    * # * # 232338 # * # * - Shows the Wi-Fi MAC address
    * # * # 1472365 # * # * or * # * # 1575 # * # * - GPS test
    * # * # 232331 # * # * - Bluetooth test
    * # * # 2664 # * # * - Touch screen test
  • #3 17072523
    muzior
    Rate: 68
    I know the codes. Unfortunately, none of them work on P8 lite. I need a 100% working code for this model.
    plustek
    Help: 176
    Rate: 200
    MMI tests: * # 2846 #
    Service menu: * # * # 2846579 # * # *
  • #5 17075076
    muzior
    Rate: 68
    It works! Thank you, that's what I meant. close
