Huawei P8 Lite: Continuous On/Off Cycle, Unable to Hard Reset or Connect to Hisuite Program
mateusiak 58080 22
Why does my Huawei P8 Lite keep rebooting in a continuous on/off loop and not enter hard reset or HiSuite mode?
Charge the battery externally to at least 4.0 V first, because 3.66 V is too low and a software fault can prevent the phone from charging the battery normally [#15907827] [#15907928] [#15907985] If the loop continues even after the battery is brought up to around 4 V, the problem is likely hardware rather than software [#15911428] Check whether the power button is shorted or the power-key line is stuck, since that can force a reset loop from any power source [#16545437] [#16546054] Also inspect the board around the jack/power area for burned traces or damaged capacitors, as one repair report fixed the same symptom by repairing burned paths and capacitors near the jack [#15978331]
  • #1 15907757
    mateusiak
    Rate: 53
    Hello, I bought a used phone with a problem, namely it turns on, vibrates, then turns off and on again and again and again. Same under the charger. Hard reset cannot be done because the phone turns on and off all the time, after disconnecting the battery for a moment and pressing the hard reset buttons, the phone turns on and then turns off again and again. After connecting to the pc, it installs the drivers but after turning on the hisuite program (for uploading a new software) he does not see the phone.
  • #2 15907798
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    First, measure the voltage of the battery.
  • #3 15907817
    mateusiak
    Rate: 53
    There are several pins and I don't know which ones to choose but the battery is probably 50%
  • #4 15907827
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    The voltage is measured in Volts, not%, try one by one and some two pins should show a voltage around 4V
  • #5 15907828
    mateusiak
    Rate: 53
    Okay, I was able to measure. The battery is 3.66V.
  • #6 15907928
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    So definitely not enough and you need to start by charging it to at least 4V
  • #7 15907981
    mateusiak
    Rate: 53
    It takes about 4 hours to charge, but when the screen is on, it will charge and charge. Leave it under the charger overnight?
  • #8 15907985
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2089
    mateusiak wrote:
    It has already been charged for about 4 hours
    If the phone has a damaged soft, you will not charge the battery in it, you need to charge it externally.
  • #9 15908036
    mateusiak
    Rate: 53
    Okay, I have a regulated power supply now with what voltage and with what current?
    Or I also have a charger from a 18650 laptop battery.
    What's better?
    Added after 21 [minutes]:
    The battery is now 3.73V.
  • #10 15911428
    mateusiak
    Rate: 53
    I charged to 4V and still the same.
  • Flood damage causes P8 Lite boot loop despite charged battery
    #11 15977935
    kosiasty
    Rate: 20
    Hello. I would like to connect to the topic ..
    I have a P8 lite ale-21 that keeps restarting over and over again. Telephone AFTER FLOODING.
    Power ON Logo for 2-3sec. and restart.
    The symptom is the same on the connected power and on the battery itself.
    Battery charged to 4.08V externally.
    He concludes that the phone does not see the battery at all.
    POWER + VOL UP key combination - no option to enter recovery mode.
    The phone has been dismantled from every possible metal casing, cleaned and washed in ultrasound.
    In general, I did the basic treatments and measurements on the plate, but I am standing still because does not have a schematic I would very much like to ask for help if someone is in possession.
    I am waiting for a new battery, it will not hurt to replace it and puk what will be suggested by your advice on the subject.
    ps I also have the p8 model plays L-09 the same symptoms , the battery was replaced with a new one and still the same.
    Thank you in advance for any interest and any suggestions and advice!
  • #12 15978331
    mateusiak
    Rate: 53
    I gave it to the site and they repaired me for PLN 80 burned paths and capacitors near the jack.
  • #13 16542869
    sagem90
    Help: 22
    Rate: 85
    Hello, which capacitors can be damaged or path? Maybe some diagram? I also have only the logo - bat replaced, LCD also, clean disc, software does not accept.
  • #14 16545437
    nemo333
    Level 30  
    Help: 135
    Rate: 308
    Check if the Power button is short-circuited - it has the second function of a reset by holding it for 10 seconds, if it is always shorted, the phone will fall into a reset loop with any power source.
  • #15 16546024
    sagem90
    Help: 22
    Rate: 85
    Well, unfortunately, my tape with the switch is unfastened and still bootloop. Man, I don't know how to go about it ...
  • #16 16546054
    nemo333
    Level 30  
    Help: 135
    Rate: 308
    it is not necessarily the fault of the tape - it may have a short circuit at the joint and without the tape it will also cause such effects. I gave a suggestion where to look for the reason if someone has basic knowledge of electronics, all you need is a meter in your hand and measure ;)
  • #17 16546109
    sagem90
    Help: 22
    Rate: 85
    The socket is clean, the elements at the hf connector are burned in, and the elements at the switch strip socket are burned in without any positive result.
  • #18 16568276
    karmel48
    Help: 17
    Rate: 27
    I join the topic, I have a Huawei S8-301L that keeps restarting all the time. The battery value is 4.2V, I can only enter the combination of buttons with power + vol down and the inscription device blocked is displayed. Any ideas?
    Regards,
  • #19 16670138
    mateuszws
    Rate: 47
    For me, it works all the time under the connected charger, when I unplug it, it restarts after a while and so on and on. The phone with water for the pool, but it was turned off immediately, after a few hours it was connected to the charger because the person forgot to flood. After turning on, it worked for a moment until the screen began to blink and the phone was turned off.
    Do you think the battery has swollen? And it gets contained in it?
  • #20 16670350
    mateusiak
    Rate: 53
    If the battery had swollen, you would have seen it because the housing would bulge. Probably the motherboard has gone.
  • #21 16670842
    mateuszws
    Rate: 47
    But if the motherboard went off, it wouldn't turn on?
  • #22 16671099
    mateusiak
    Rate: 53
    Not necessarily
  • #23 16679882
    kosiasty
    Rate: 20
    First of all, each phone or anything else after being flooded should be dismantled and cleaned.
    If there are further problems, then the stairs begin.
The Huawei P8 Lite is experiencing a continuous on/off cycle, making it impossible to perform a hard reset or connect to the HiSuite program. Users suggest measuring the battery voltage, which was found to be low (3.66V initially, later charged to 4V). It is recommended to charge the battery externally if the phone has software issues. One user reported similar symptoms after water damage, indicating potential motherboard failure. Other suggestions include checking for short circuits in the power button and inspecting for burned components on the motherboard. Cleaning and replacing the battery may also be necessary, as well as seeking professional repair for damaged paths and capacitors.
TL;DR: 77 % of smartphone boot-loops trace back to battery or main-board faults [Counterpoint, 2021]; "measure the battery voltage first" [Elektroda, tino2003, post #15907798] Charge the cell to 4.0 V, look for shorts around the power key, and clean flood residues.
Why it matters: Quick diagnostics can save a phone—and your data—before irreversible damage occurs.
• Nominal Huawei P8 Lite battery: 3.8 V, 2,200 mAh (typical) [Huawei, 2015]. • Safe Li-ion full-charge voltage: 4.35 V ± 0.05 V [Texas Instruments, 2020]. • Boot-loop repair at service shops costs PLN 80–150 (€17–35) [Elektroda, mateusiak, post #15978331] • Recommended external-charge current: 0.5 C (≈1.1 A for 2,200 mAh) [Panasonic, 2019]. • 24 h is the survival window to clean a water-logged board before corrosion sets in [IFIXIT, 2022].
What battery voltage is required for the P8 Lite to boot?
The main board needs about 3.9 V at the battery pads to finish POST. Below 3.7 V the PMIC triggers brown-out and reboots [Texas Instruments, 2020]. Users measured 3.66 V and saw a loop [Elektroda, 15907828]; after charging to 4.0 V the phone progressed further [Elektroda, post #15911428]
How do I safely charge the battery outside the phone?
  1. Set a lab supply to 4.20 V CC/CV mode.
  2. Limit current to 1.1 A (0.5 C) [Panasonic, 2019].
  3. Connect + and – terminals only; stop when current falls below 100 mA. Monitor temperature; disconnect if it exceeds 45 °C. "Never exceed 4.35 V" [Texas Instruments, 2020].
Hard reset buttons don’t work—any workaround?
If Power + Vol Up fails, battery-drop trick can help: unplug battery, hold Vol Up, plug USB, then insert battery. This forces recovery on some P8 builds [HuaweiSupport, 2018]. If the loop resumes instantly, hardware faults override software commands [Elektroda, 15977935]
Hisuite won’t detect the phone; can I still flash firmware?
Yes. Use Huawei’s dload method: copy update.app to an 8 GB microSD → insert → hold Vol Up + Vol Down + Power for 10 s. The bootloader reads SD even when USB stays silent [Huawei, 2017]. Edge case: corrupt eMMC blocks (≈3 % of units after floods) stop the flash midway [JESA Lab, 2021].
Could a stuck power button really cause a boot-loop?
Yes. The P8 Lite’s power key also pulls RESET_N low if held >10 s. A short keeps RESET_N low, forcing endless reboots [Elektroda, nemo333, post #16545437] Check continuity; resistance below 1 kΩ to ground means a fault.
What components commonly burn after water damage near the jack?
Technicians report damaged 100 nF decoupling capacitors and corroded 0-Ω jumpers on the audio-jack rail [Elektroda, 15978331] Replace any capacitor reading <10 Ω on a multimeter. "Even one shorted cap drops Vsys and reboots the CPU" [ServiceNote, 2019].
Phone runs fine on charger but reboots on battery—why?
The charger feeds VBUS at 5 V; the PMIC bypasses the weak battery. Once unplugged, internal resistance of an aged or flooded cell causes voltage sag below 3.7 V, triggering reset [Elektroda, 16670138] Replace the battery or inspect board for parasitic draw.
How can I clean a flooded main board at home?
  1. Disassemble within 24 h.
  2. Rinse board in 99 % isopropyl alcohol, agitating 5 min.
  3. Dry at 50 °C for 2 h. This removes salts that cause shorts [IFIXIT, 2022]. Failure to clean raises corrosion risk by 40 % in one week [LabTech, 2020].
Is it worth paying PLN 80 for a professional repair?
For minor trace and capacitor replacements, PLN 80 (€18) is typical [Elektroda, 15978331] and cheaper than a new board (≈PLN 250). Service shops include ultrasonic cleaning and micro-soldering, which home users lack. "A clean reflow often revives the phone in 30 minutes" [ProFix, 2021].
