Printing Grayscale Documents with Only CANON PIXMA MG5750 Black Ink - Settings Adjustment
gogus.majka 13839 2
  • #1 17076973
    gogus.majka
    Hello, is it possible to adjust the printer's settings so that when all the ink colors are installed, it will print in shades of gray using only plain black ink instead of sticking the image from all colors? Unfortunately, I did not find a clear answer on similar topics. It prints mainly black and white documents, rarely colored, while the consumption of all inks is quite clear. Thank you in advance for your help.
  • #2 17076991
    kokapetyl
    Help: 1787
    Rate: 2099
    How are you set in the print options? (color, black and white)
    I'm not sure, but I think that should change the situation.
  • #3 17079919
