Accessing Service Mode and Pampers Reset Program for Canon MG5650 Printer
adam_xx 39798 15
How do I enter service mode on a Canon MG5650 and which program resets the waste-ink absorber (pampers)?
You can clear the MG5650’s 5B00 state by entering the service/startup sequence: power off, hold the red triangle button while powering on, release the triangle, then while holding Power press the triangle four times so the jam lamp toggles, and finally release Power; the printer should start without the error [#17118113] For the absorber reset, one reply says a service program is required and the correct version may be hard to find for this model [#17117784] The confirmed working solution reported in the thread was WicReset with a registered code, which successfully reset the pampers on a Canon MG5650 [#17131266] The poster also noted they physically cleaned and renewed the waste tank cartridge, so the reset should not be used as a substitute for actually servicing the absorber [#17132722]
  • #1 16259082
    adam_xx
    Rate: 81
    I need information on how to get into the MG5650 service mode in this printer
    and what program resets the pampers in it.
  • #2 17117761
    jerry74
    Help: 21
    Rate: 58
    Now I have the same problem, does anyone know how to reset it?
  • #3 17117784
  • #4 17118113
    jerry74
    Help: 21
    Rate: 58
    I was able to turn on the printer without this error. I checked it several times and it is repeatable. it is not suitable to give the printer to the client, but it can be useful for your own needs:
    The display shows error 5B00 (the lamp blinks 6 times).
    1. I turn the printer off
    2. I press the red triangle and hold it down and press the printer on.
    3. I release the triangle button, and now holding power I make this sequence:
    I press the triangle (the jam indicator lights up), press the triangle (the jam indicator goes out), press the triangle again (the jam indicator lights up), press the triangle (the jam indicator goes off) then release the power button and the printer starts without error. you can print on it, enter the menu etc. Everything indicates that the printer is operational.
    The problem occurs when the printer is turned off. the printer will not turn on for the second time. you have to pull the plug out of the socket, wait a moment, then it will turn on but with this error. If I turn it off now and repeat the procedure, the printer will be fully functional again.
    Now the challenge is to keep this state. I will be grateful for any ideas. I unscrew the printer and clean the "pampers" and see what happens. I do not see any sensors here but it can help.
  • #5 17118152
    adam_xx
    Rate: 81
    Buddy, it is in this printer that entering the service status will be as you enter it. If you start the printer from the power switch, the error will still be unresolved. For its solution, I recommend you look at the alle-expensive portal from eg No. 7025114699.
  • #6 17118250
    jerry74
    Help: 21
    Rate: 58
    Unfortunately, this model is not on the list.
  • #7 17118306
    adam_xx
    Rate: 81
    Man mg 5600 I think that mg5650 also will handle
  • #8 17131266
    jerry74
    Help: 21
    Rate: 58
    Ok.
    I downloaded WicReset and bought a registered code. everything works on the Canon MG5650.
    Pampers reset.
  • #9 17131689
  • #10 17132722
    jerry74
    Help: 21
    Rate: 58
    As I wrote earlier, I intended to clean the waste tank and I did it together with renewing the cartridge in this tank. So I am aware of the risk of overfilling the waste tank. The smallest problem would be a stain on the desk, it could also lead to short circuit etc ...
  • Blocked service mode indicates motherboard replacement needed
    #11 17135339
    grudin85
    As far as this Canon model is concerned, when you enter the service mode after 5 buttons with a triangle in a circle and the power button does not start flashing, and the display does not illuminate, it means that the service mode is blocked. At this point, even WicReset will not help us just replacing the motherboard.
    I know that the use of the Service Tool is tragic for this model when it comes to trying to reset the absorber. Unfortunately, I do not know how it will be when trying to check the consumption, I rather do not want to try.
    Here the question arises whether we are able to see the state of absorber consumption after replacing the motherboard. Has anyone ever tried the Service Tool program and what were the consequences?
  • Absorber wear is stored as a page counter
    #12 17135369
    jerry74
    Help: 21
    Rate: 58
    grudin85 wrote:
    using the Service Tool is tragic for this model when it comes to trying to reset the absorber
    So I was lucky that I succeeded.
    I would post that the state after replacing the motherboard will be the same as in this disc is saved, there are no sensors in the absorber, the lifetime of this part is described for me as a counter of reprinted pages. So many pages printed, the absorber should fill up and the system on the motherboard stops the printer.
  • Pampers fill level depends on head cleaning count
    #13 17135795
  • #14 17136000
    grudin85
    I agree with that, obviously. I'm interested in how full the pampers are. Is it possible to get this information in some way or just wait until the error pops up when the absorber is full?
  • #15 17136068
  • #16 17680126
    Staszeg
    People,
    if you do not want to be stuck in you every day, never buy this damned thing! I - moose - I bought two G3400, which for a year never worked properly (in two separate companies / networks). There is always a problem with it, and sometimes it is simply impossible to print anything - either through the network or even on the cable. Sometimes the printer drips "that's it" and prints a forgotten document from half an hour ago. Sometimes nothing. One big problem - just a mistake: for almost a year I have been fighting with ill-fated equipment, instead of printing (as I have done for 30 years on every printer). I will look for a purchase invoice, maybe I can give it back to the producer ... (I do not want to see it anymore).
The discussion revolves around accessing the service mode and resetting the waste ink absorber (pampers) for the Canon MG5650 printer. Users share various methods to enter service mode, including a specific button sequence to bypass error 5B00. Some mention the use of the WicReset program, which successfully resets the pampers for the MG5650. However, concerns are raised about the potential blocking of service mode due to using incorrect service tools, which may necessitate motherboard replacement. Users also discuss the challenges of monitoring the absorber's fill level and the implications of overfilling, emphasizing the importance of proper maintenance and awareness of the printer's operational status.
