Huawei P 8 Lite ALE-L21 - Breaks Bluetooth when connected to the speaker
wiktormax123 6075 6
  • #1 17078822
    wiktormax123
    Rate: 16
    Hello, I have a problem with audio dropout when connected to my phone speaker.
    The phone is huawei P8 lite and the speaker is JBL Flip 4
    The problem is that when I listen to music after a while the sound starts to interrupt but does not disconnect, then it plays well again and it stops again and it is still like that.
    When I connected the flip to another phone, everything worked.
    Does anyone know what could have broken or how to fix it?
    PS. If the post is in the wrong category, I'm sorry, but I haven't seen whether to choose "GSM" or "Speakers"
    matej1410
    Help: 115
    Rate: 219
    Make software updates on your phone
  • #3 17078940
    wiktormax123
    Rate: 16
    It works for now, but I don't have time, so I will write later if it is fixed :)
  • #4 17079185
    Glemark1
    GSM specialist
    Help: 190
    Rate: 111
    Standard fault in this model, i.e. damage to bt / wifi systems. Replacing it with a new one will do the trick.
  • #5 17079288
    wiktormax123
    Rate: 16
    [quote = "Glemark1"] Standard bug in this model, damage to bt / wifi systems. Replacing it with a new one will do the trick. [/ Quot]
    Except that the motherboard has already been replaced because of the non-working wi fi so it shouldn't be done anymore
  • #6 17079829
    wiktormax123
    Rate: 16
    Added after 3 [hours] 41 [minutes]:
    Ok works, I updated my phone and it's ok
    Thanks
  • #7 17100984
    nutergsm
    Help: 1034
    Rate: 1663
    I open the topic again at the author's request.
    The problem is back.
✨ The user reports experiencing audio dropouts when connecting their Huawei P8 Lite (ALE-L21) to a JBL Flip 4 speaker. The issue manifests as intermittent sound interruptions while streaming music, although the connection remains intact. Other devices do not exhibit this problem when paired with the JBL speaker. Suggestions from the forum include performing software updates on the phone, which initially resolved the issue. However, the user later reported the problem resurfacing, indicating a potential standard fault in the Bluetooth/Wi-Fi systems of the Huawei P8 Lite. A previous motherboard replacement due to Wi-Fi issues complicates further hardware solutions.
