GoPro Hero 4 Black as Webcam for Twitch/YouTube Streaming: Required Equipment & Alternatives
djsmutazz 10866 2
  • #1 17082420
    djsmutazz
    Hello crew!
    I would like to connect the gopro 4 to my laptop as a webcam.
    Mostly it will be used to steam set on twitch or yt.
    What equipment will you need to capture the camera image?
    Is it better to buy a steam camera?
    Thanks in advance.
    GoPro not cost-effective for streaming only
    #2 17083961
    Sithios
    It depends, if you already have GoPro it's clear you can use it as a webcam. However, if you are planning to buy it mainly for streams, then I think it is a waste of funds.
    Fast, the price of GoPro is around 700-1000 PLN +, while for example Logitech C922 Pro Stream you can buy for 300-400 PLN. Check out some Logitech recordings on youtube and rate if such quality satisfies you.
    Of course, if you prefer GoPro anyway, because you may also need to do other things, just enter "GoPro hero4 as webcam" on youtube. From what I see, all you need is a camera, cabling and the appropriate program, e.g. OBS. However, I don't know if you need an image recorder, e.g. avermedia.
  • #3 17084285
    djsmutazz
    Yes, I already have GoPro, thanks for clarifying the topic ;)
    In that case I will buy a mini-hdmi cable and see how it all works without a recorder.
    Thanks for the help!
