GoPro Hero5 Session: TV (Samsung) Unable to Play MP4 Movies, Monitor Unsupported Refresh Rate
JurijR13 9165 4
  • Samsung TVs reject GoPro MP4 and high-frame-rate video
    #1 16466758
    JurijR13
    I warmly welcome.
    I recently bought a GoPro Hero 5 Session webcam. He records beautifully, but problems have arisen.
    The movies are recorded in .MP4 format, unfortunately, regardless of whether I connect the webcam to the TV via USB, memory card in the USB adapter or drop the videos on pendrive and connect via USB, the TV (Samsung) can not see any movies on it.
    But the second TV - monitor (to make it funny also Samsung) already sees movies, but does not play video in 4K (which is quite understandable, since it has the highest resolution of 1080p), 90pps 90pps, 90pps 1080p pops "Unsupported refresh." Number of frames: 59 "(monitor has 60 Hz refresh).
    When you play movies on the computer in 4K 30 fps, everything is nice and smooth, scaled to 1080p, with movies in 90 fps pop artifacts on the play screen (green screen, gray fragments), 1080p 60 fps runs smoothly on one and stutters on the other computer.
    Well, damn it. Does anyone have a solution to this? Even though I watched the 1080p 60 fps on the TV (because as I said, it does not see any movie, even though it is in .MP4 format).
  • Check exact Samsung model for supported MP4 formats
    #2 16466785
    xury
    Automation specialist
    Help: 878
    Rate: 1497
    JurijR13 wrote:
    But the second TV - monitor (to make it funny Samsung too)
    I will tell you that it would be even more funny, that I also have a Samsung TV and see mp4, and to make it really funny, I also have a Panasonic TV and this one sees movies that Samsung does not see. :)
    Well, we were laughing :D now we can get to the point: Samsung does not make one TV set. Once you find out what your model is, check the specification of the formats for this model on the internet.
  • #3 16466788
    JurijR13
    Now, let us laugh. Suddenly, he began to see the movies played on the pendrive, but the information pops up that it is an unsupported video codec ...
  • #5 16466831
    JurijR13
    Okay, she explained it. The TV does not support SD cards even through the adapter and is 30 Hz (such an old age). 1080p 30fps movies are playing. Subject to be closed
