Multidiag Pro+ Buying Guide: Choosing the Right Interface, Software & Installation Tips
hugo987 73824 14
How do I choose a Multidiag Pro+ interface, whether it includes software, and what program should be installed to use it?
These multidiag/DS150E interfaces are usually the same hardware sold in different housings, and the software is not always included, so check the auction description and the seller’s warranty before buying [#17099247][#17101659] Install DS150E or related software such as Autocom, Delphi, or WOW; the thread says their appearance and basic functionality are almost identical, except WOW [#17099247][#17099488] Do not trust claims of full coverage for cars from 2016, because the last full database mentioned is from the end of 2013, and 2014–2015 rely on an older converted base that may not work correctly [#17101693] If you need Mercedes DAS/Xentry, this interface will not work with that software; a dedicated interface is required [#17244798]
  • #1 17099219
    hugo987
    Rate: 23
    I want to buy an interface for aledrogo (such a red multidiag for PLN 400) Are these testers sold with software? If not, what program must be installed in order to do the study comp. (where should the program go out)
  • #2 17099247
    leonov
    Help: 1039
    Rate: 2247
    And the seller of aledrogo, did not write or sell with or without software? the rest can be found through the well-known search engine under the slogan ds150e
  • #3 17099259
    hugo987
    Rate: 23
    And how does this multidiag deal?
    He understands that you can upload different programs?
  • #4 17099488
    leonov
    Help: 1039
    Rate: 2247
    Depending on how you hit with the quality of performance ;-) on what components, etc. there are several programs but they have almost identical appearance and functionality in addition to WOW.
  • #6 17101659
    leonov
    Help: 1039
    Rate: 2247
    These are the same interfaces in different housings, both vendors praise theirs ;-) you will not find the better one, check the seller carefully, here the guarantee is what counts.
  • #7 17101693
    piotrekwoj1
    Help: 947
    Rate: 3433
    The description of the auction is that the diagnostics of cars from 2016, total rubbish. The last full database is from the end of 2013. The rest 2014,2015 is an old program with a converted base that does not quite work as it should.
  • #8 17182821
    bujemuje
    Rate: 27
    Will such an interface diagnose abs errors in renault master 2009 and opel astra g 2001?
  • #9 17183012
    leonov
    Help: 1039
    Rate: 2247
    That's how it will be able to diagnose these vehicles.
  • OBD-MB 34-pin adapter compatibility for W140 diagnostics
    #10 17191887
    bujemuje
    Rate: 27
    Thank you for the answer I ordered MVDiag (yellow) was able to diagnose astre in the weekend testing the master. There are two wow and opus cars for the interface (Autocom). If I buy an OBD-MB 34 pin adapter, will I be able to diagnose mb w140 3.2 1992 with this interfac and programs? In wow this is not possible this year (diagnostics not active) in the opusie is diagnostics and OBD only (without the possibility of choosing systems and ISS) or does this interface work with some other program such as Carsoft? She certainly did not work with MaxiEcu.
  • #11 17192242
    leonov
    Help: 1039
    Rate: 2247
    Here you have what softy it supports Multidiag Pro+ Buying Guide: Choosing the Right Interface, Software & Installation Tips
    What about diagnostics, including Opus, do you have advanced diagnostics checked in the menu?
  • #12 17204750
    bujemuje
    Rate: 27
    This is how the advanced drop is marked
  • #13 17240703
    bujemuje
    Rate: 27
    Unfortunately, he does not diagnose a Mercedes from this year. Can anyone know if such a multiplaxer works with das / xentry or does it have to be dedicated?
  • #14 17244798
    leonov
    Help: 1039
    Rate: 2247
    With this soft you will not work, you need a dedicated interface.
  • #15 17245683
    bujemuje
    Rate: 27
    I found information that you can convert antica multidiag so I suggested. Ultimately, in order not to do ot there is no possibility of a modification or another program to cooperate with a Mercedes from the 1992s. Autocom does not answer wow, it gives instructions only to flash codes.
    Greetings.
The discussion revolves around purchasing a Multidiag Pro+ interface for vehicle diagnostics, specifically from the platform Aledrogo. Users inquire about whether these interfaces come with software and what programs are necessary for effective diagnostics. It is noted that various interfaces, such as DS150E and MVDiag, have similar functionalities but may differ in performance based on their components. Users express concerns about the accuracy of diagnostic capabilities, particularly for vehicles like the Renault Master and Opel Astra. Recommendations include checking seller reliability and understanding that some interfaces may not support newer vehicle models or specific diagnostic software like DAS/Xentry for Mercedes. The conversation also touches on the potential for modifying older interfaces to work with newer software.
TL;DR: 2013 is the last full database; “Diagnostics of cars from 2016, total rubbish.” Pick DS150E-compatible software and sellers who back warranties. This guide explains interfaces, supported software, coverage limits, and Mercedes caveats. [Elektroda, piotrekwoj1, post #17101693]
Why it matters: It helps DIYers and small shops choose a DS150E/Multidiag clone wisely and avoid misleading claims.
What do Multidiag Pro+, DS150E, Autocom, WOW!, and Opus actually mean?
Multidiag Pro+ and DS150E refer to the VCI hardware class. Autocom/Delphi, WOW!, and Opus are the diagnostic software. Most programs share a near identical interface and functions. WOW differs more in look and features. Expect similar capabilities across the others. [Elektroda, leonov, post #17099488]
Do color, case, or "Bluetooth" versions matter when buying?
Vendors sell the same interface in different housings. Prioritize warranty and seller reliability over color or case. “These are the same interfaces in different housings.” Compare return terms and support before purchase. [Elektroda, leonov, post #17101659]
Are these testers sold with software, or do I install it myself?
Check the auction description for software inclusion. Some listings bundle software, others offer hardware only. If it lacks software, search for installers using the keyword “ds150e.” That search term leads to the relevant software family. [Elektroda, leonov, post #17099247]
What vehicle year coverage is realistic for these tools?
Expect complete database coverage up to the end of 2013. Builds labeled 2014 or 2015 use converted bases. Those can misbehave or work only partly. Treat 2016 coverage claims as false. [Elektroda, piotrekwoj1, post #17101693]
Should I trust auctions promising diagnostics for 2016 cars?
No. “Diagnostics of cars from 2016, total rubbish.” The last full database ends in 2013. Converted 2014–2015 releases can run, but not reliably. [Elektroda, piotrekwoj1, post #17101693]
Can it read ABS on Renault Master 2009 and Opel Astra G 2001?
Yes. The interface can diagnose ABS on a 2009 Renault Master. It also supports ABS on a 2001 Opel Astra G. [Elektroda, leonov, post #17183012]
Will a multiplexer like this work with Mercedes DAS/Xentry?
No. This interface does not work with DAS/Xentry. Mercedes diagnostics with that software need a dedicated, compatible multiplexer. Choose hardware built for DAS/Xentry. [Elektroda, leonov, post #17244798]
Can I scan a 1992 Mercedes W140 using adapters with this tool?
Users report no diagnostics on early 1990s Mercedes with this interface. Adapters do not change that limitation. A dedicated Mercedes interface is required for W140-era systems. [Elektroda, leonov, post #17244798]
Does this interface work with MaxiEcu or Carsoft?
A user verified the interface did not work with MaxiEcu. Their unit offered WOW and Opus instead. Stick to the supported software shown for this interface. Compatibility with Carsoft was not confirmed. [Elektroda, bujemuje, post #17191887]
How do I enable Advanced Diagnostics in Opus or similar software?
Enable the Advanced Diagnostics option in the program’s menu. That unlocks deeper system access where available.
  1. Open the app and connect your VCI.
  2. Open settings and enable Advanced Diagnostics.
  3. Reopen vehicle selection and scan again. [Elektroda, leonov, post #17192242]
What matters most when choosing a seller?
Hardware variants are similar. Warranty and seller support matter most. Check the seller carefully and read guarantee terms. Favor sellers with clear return policies. Avoid listings that dodge warranty details. [Elektroda, leonov, post #17101659]
What price should I expect for a clone interface?
A buyer referenced a red Multidiag around PLN 400. Expect similar pricing on local auction sites. Compare bundles and support before paying. [Elektroda, hugo987, post #17099219]
What search keyword helps me find the right software?
Use the keyword “ds150e” in your search engine. It aligns with the software lineage used by these VCIs. Review results for your software choice. [Elektroda, leonov, post #17099247]
What are the risks of using converted 2014–2015 databases?
Converted databases can work incompletely. Some modules may not communicate or functions may fail. Treat these builds as partial coverage only. Use them with caution. [Elektroda, piotrekwoj1, post #17101693]
