[Solved] Multidiag pro version gold - Hello, someone is using this equipment, if so, what
Mlodziax 13620 12
Can Multidiag Pro Gold be used to code a BMW E46 2004, such as enabling daytime running lights or correcting the instrument cluster?
No, Multidiag Pro Gold will not do BMW coding tasks like enabling daytime running lights or correcting the meter on an E46, and the cheap version may not even connect to this car [#17561326][#17574349] Universal diagnoscopes are mainly for reading fault codes and sometimes only basic coding, not full brand-specific functions [#17561935] The thread says there is no single interface that will do everything for all cars and tasks; you need equipment chosen for the specific brand and job [#17567266][#17568218] For your mixed car list, suggested tools included Carprog, Smok, Xprog, VVDI Prog, INPA, Honda HDS, and VCDS, depending on what you want to do [#17574693]
  • #1 17560982
    Mlodziax
    I mean whether you can, among other things, turn on the daytime running lights, make a correction of the meter, of course, only p mim car bmw e46 2004
  • #2 17561326
    ZAHYR
    Help: 200
    Rate: 179
    You will not do it, the bmw coding, also not. If you buy a cheap, neutered version, you probably won't even connect to this car.
  • #3 17561482
    Mlodziax
    The version that I want to order costs PLN 500. And what would you recommend me specifically, which interface may be more expensive But to support other brands as well.
  • #4 17561935
    piotrekwoj1
    Help: 947
    Rate: 3433
    There is no one that does what you want. No matter which one you buy, it won't be everything. These are universal diagnoscopes, mostly for reading error codes, sometimes you can code something there, but it's some general stuff. What you exchange is only with special diagnoscopes and programmers, or possibly abrites would do the trick, but in it you pay for each brand separately and that's not enough.
  • #5 17562038
    Mlodziax
    Oh, a difficult topic with this And would you recommend an interface for me or this multidiag will be good for such basics?
    Added after 1 [hours] 56 [minutes]:
    Or what to buy, what interface for what program and what I work with it, maybe a few about the budget, I'm not worried about it ;)
  • #6 17567266
    ZAHYR
    Help: 200
    Rate: 179
    Rather, no one will write about over 100 interfaces available on the market.
    Maybe just write what you want to do and with what car someone will tell you which interface to use.
  • #7 17568152
    radiogaga
    Service technician RTV
    Help: 398
    Rate: 437
    Dedicated testers are the best, although you can talk about a slightly better class of this universal type - they can do not only error resetting.
  • #8 17568218
    piotrekwoj1
    Help: 947
    Rate: 3433
    I will tell you that it is not exactly like that, because even with such a service you will not do everything about what the author writes. There are devices that do what the service does, plus a lot more, but they also cost their own.
  • #9 17574301
    Mlodziax
    I would like to make a correction of the meter and activate, for example, daytime running lights or a new key. My cars, i.e. bmw e30 2.5i e60 3.0d e36 2.5i e46 3.0i vw golf 4 vr5 honda crv
  • #10 17574349
    piotrekwoj1
    Help: 947
    Rate: 3433
    Forget that with this equipment you will do something like that in any of these cars. There is no such thing, different equipment for each activity and brand.
  • #11 17574652
    Mlodziax
    I really like such answers ... ZAHYR replied that I should write what car and what I want to do, I understand that there is no one for everything. Therefore, as I wrote earlier, there may be several
  • #12 17574693
    piotrekwoj1
    Help: 947
    Rate: 3433
    Carprog, Smok, Xprog, Vvdiprog, Inpa, Honda HDS, Vcds read the rest.
  • #13 17618544
    Mlodziax
    Subject to be closed
The discussion revolves around the capabilities of the Multidiag Pro version Gold, particularly in relation to a BMW E46 2004. Users express skepticism about the device's ability to perform specific tasks such as activating daytime running lights and correcting the odometer. It is noted that universal diagnostic tools primarily read error codes and may not support advanced coding or programming for specific vehicle functions. Recommendations for more specialized interfaces are suggested, including dedicated testers and other diagnostic tools like Carprog, Smok, Xprog, and Vcds, which may offer broader functionality across different brands and models. The consensus is that no single tool can perform all desired functions across various vehicles, emphasizing the need for multiple interfaces for different tasks.
TL;DR: Over 100 interfaces exist, and "write what you want to do and with what car" still applies. Multidiag "Gold" handles basics; coding DRLs, keys, or mileage across BMW/VW/Honda needs brand-dedicated tools and software. [Elektroda, ZAHYR, post #17567266]
Why it matters: DIYers and small shops want to know how to enable DRLs, code modules, or program keys without buying the wrong interface.
Can a Multidiag Pro "Gold" enable DRLs or other coding on a BMW E46/E60?
No. The thread consensus is that BMW coding is not possible on cheap Multidiag units, and connection may fail. Use BMW-specific software instead. [Elektroda, ZAHYR, post #17561326]
Will Multidiag "Gold" correct odometer values or program a new key?
No. Those tasks require dedicated programmers or high-end solutions with paid brand licenses. As one expert put it: "There is no one that does what you want." [Elektroda, piotrekwoj1, post #17561935]
What toolset fits BMW E30/E36/E46/E60, VW Golf 4, and Honda CR‑V from this thread?
Use brand tools for diagnostics/coding and separate programmers for EEPROM/immobilizer. Suggested picks: INPA (BMW), VCDS (VW), HDS (Honda), plus Carprog/SMOK/Xprog/VVDIprog for memory and key work. [Elektroda, piotrekwoj1, post #17574693]
Is a budget Multidiag "Gold" enough for basic diagnostics?
Yes for reading and clearing error codes. Expect limited, generic coding only. It is not a replacement for brand tools for feature activation. [Elektroda, piotrekwoj1, post #17561935]
Why isn’t there one interface that does everything across brands?
Because the market is fragmented—there are over 100 interfaces. Start with the job and the exact car, then match a tool. [Elektroda, ZAHYR, post #17567266]
How do I choose the right interface for my car and task?
  1. List the exact job (DRL coding, key add, mileage read).
  2. Map each job to the specific car and module.
  3. Pick a brand-dedicated tester or programmer that covers that combo. "Write what you want to do and with what car." [Elektroda, ZAHYR, post #17567266]
Will dealer-level testers cover everything I need?
No. Even service testers won’t do all tasks you listed. Some aftermarket devices go beyond service tools, but they cost more. "Even with such a service you will not do everything." [Elektroda, piotrekwoj1, post #17568218]
Is Abrites a one-box solution for coding, keys, and mileage?
Abrites can handle many advanced operations, yet it requires paid per-brand licenses. Even then, it may not cover every task you plan. [Elektroda, piotrekwoj1, post #17561935]
What’s the main risk with cheap "Gold" clones on BMWs?
Some neutered units fail to connect to BMWs for coding. You may read DTCs, but advanced session access can be blocked. [Elektroda, ZAHYR, post #17561326]
Which tool should I use for BMW coding from the thread’s suggestions?
INPA is the named BMW option in the thread. It is a better fit for coding and deeper diagnostics than universal clones. [Elektroda, piotrekwoj1, post #17574693]
What suits VW Golf 4 VR5 diagnostics and coding?
Use VCDS for Volkswagen. It offers deeper access than universal scanners and aligns with VW modules and coding. [Elektroda, piotrekwoj1, post #17574693]
What’s recommended for Honda CR‑V diagnostics?
Honda HDS is the suggested software. It gives proper access to Honda ECUs for diagnostics and supported adaptations. [Elektroda, piotrekwoj1, post #17574693]
Can a universal tool handle DRL activation at all?
Sometimes they can change generic settings, but success varies by car and module. For reliable DRL coding, use the brand’s software. [Elektroda, piotrekwoj1, post #17561935]
I’m not worried about budget—should I still split tools by task/brand?
Yes. There is no single device for coding, mileage, and keys across all your cars. Use different equipment for each activity and brand. [Elektroda, piotrekwoj1, post #17574349]
