Choosing the Right Set: Comparing Ariston, Bosch, AEG & Electrolux Washing Machine & Dryer Models
ja.1980 30104 34
Which washing machine and dryer set should I buy if I want at least 1400 rpm spin, large capacity, and good reliability?
The thread leans most strongly toward Bosch for reliability and repairability, with Ariston the least recommended and Electrolux/AEG seen as acceptable alternatives [#8870837][#17544209][#19516331] Bosch WAN-series washing machines are specifically recommended because they have replaceable bearings, a 1400 rpm spin, and are described as quiet, with the WAN drum noted as 65 liters for more space [#17544209][#17545883][#8870837] A concrete suggested set was Bosch WAN2826EPL + Bosch WTR85V5EPL, with the note that you need a connector/terminal block to stack the dryer on the washer [#17541755][#18378782][#18388717] Electrolux was also proposed by one user, but another warned that an Electrolux washer failed after 3 years and had a glued drum with non-replaceable bearings, which counted against it for durability [#8870837][#17544025] For Bosch, the thread also favors the WAN line over WAT, because WAT was said to have a non-dismantlable tank and bearing problems [#18378964]
  • #1 8870115
    ja.1980
    as I get rid of the bum in the form of a washer-dryer, I have to choose a washing machine and dryer separately. Sets of 4 brands caught my eye:
    Ariston: washing machine AQLF9F69U and dryer AQCF851BU
    Bosch: washing machine WAS28743PL and dryer WTS86515PL
    AEG: washing machine Lavamat 84950A and dryer Lavatherm T58870
    Electrolux: washing machine EWN148640W and dryer EDC78550W
    Generally, the spin speed is important to me (min. 1400 revolutions). I know from experience with a washer-dryer that the better it is spun, the faster and better it is dried. The second thing is the load capacity - the bigger the better and the dryers are not much smaller than washing machines because I don't buy a dryer to play with hanging.
    Besides, it is known that failure-free operation is the most important.
    I will be grateful for any advice and possible experience with the above-mentioned equipment and companies.
    From myself, I can only say that I already have a second Ariston dishwasher and I'm happy with it. I do not know if the same is the case with washing machines.
    Greetings to all Forum members ...
  • #2 8870837
    ~wac
    Help: 17
    Rate: 166
    Apart from Ariston, each set is very good. I would bet on an Electrolux set, if you want a very spacious washing machine, Bosch offers it, because the drum has a capacity of 65 liters.
  • #3 8875453
    zwykły człek
    Rate: 81
    The topic has been rewritten many times, but I can write it again. For me, the best combination is:
    PFD-1484 + SKFD-831
    Very good parameters and a very good price. Additionally, now for PLN 150 / pc. you have a 5-year warranty extension. The washing machine has excellent parameters, and the dryer has an ironing function.
  • #4 17537253
    Ryjobogins
    Rate: 28
    The year is 2018, what set do you recommend now? One on top of the other must stand in a small bathroom.
  • #5 17538876
    PanAGD
    Help: 65
    Rate: 112
    Nice dig up. But when it is, I will ask: what budget?
  • #6 17538917
    Ryjobogins
    Rate: 28
    The price range is about PLN 4,000. Count up to 2000 for each piece of equipment. If it is less, I will not be offended ?
  • #7 17541755
    PanAGD
    Help: 65
    Rate: 112
    I suggest checking such a set:
    - Bosch WAN2826EPL washing machine
    - Bosch WTR85V5EPL dryer
    You will also need to purchase a connector for this.
  • #8 17541770
    Kolchoze
    Rate: 17
    I'm for AEG - unbreakable equipment (at least what I had)
  • #9 17544025
    michalw0
    Just after 3 years of use, I fired the Elektrolux washing machine. The bearings cannot be replaced. Glued drum. as for me ... Not acceptable.
    What to buy in order not to have a problem?
  • Recommend Bosch, LG, Samsung or Amica with replaceable bearings
    #10 17544209
    PanAGD
    Help: 65
    Rate: 112
    Bosch from the WAN, WAE, WLK, WLT and WLG lines, the entire range of LG, Samsung and Amica washing machines have replaceable bearings. The question of whether there is space for a standard washing machine or it has to be Slim, and the budget.
  • #11 17545738
    michalw0
    The dimensions do not really matter. width 60c m. height indifferent. Taught by experience that it was possible to repair the bearings and the programmer. Price ... as little as possible ... but yes, up to PLN 1600. If someone convinces me, I can add something else.
    At the moment, Bosch WAN2826EPL.
    But I am wondering if it is worth paying an extra PLN 500 for goodies that I will most likely not use.
    Due to active sports activities, the washing machine is fully loaded every 2 days. I actually use one program (cotton). It would be nice if the washing took about 1.5 hours.
  • #12 17545883
    PanAGD
    Help: 65
    Rate: 112
    Good choice. A quiet washing machine, a large number of programs, although the Lord does not need that much, but when they are, it is sometimes worth using. It is definitely worth using the drum cleaning program. Another advantage is the turnover of 1400.
  • #13 17546081
    michalw0
    Thanks for the help. Bought.
  • #14 18378782
    maver1ck
    I will join the topic.
    Also looking for a set. Budget PLN 4,000. Both elements should be 8 kg.
    Questions:
    Washing machine WAN2826EPL or WAT2466SPL?
    Dryer:
    I was thinking about WTG 86400PL, but there is already a newer WTG 86401PL model.
    Anyone know how he differs?
    And the last question is whether both of these elements can be placed in the post?
  • #15 18378964
    mrice
    Moderator of Home appliances
    Help: 2213
    Rate: 6951
    Definitely WAN, Watt has a tank that cannot be dismantled and you have a problem with the bearings falling down
    maver1ck wrote:
    I was thinking about the WTG 86400PL, but there is already a newer WTG 86401PL model.
    Probably a shit you won't even notice
    You need to order a terminal block from the Bosch service or shop and the post can be set up
  • #17 18379222
    mrice
    Help: 2213
    Rate: 6951
    maver1ck wrote:
    There will be problems with the depth difference between WAN2826EPL and WTG86400PL?
    check the manufacturer's website, do not expect that we will have all the dimensions of dozens of washing machines and other equipment in our head.
  • #18 18379229
    maver1ck
    I have checked before.
    The washing machine is 55 cm, the dryer is 59 cm.
    Hence the question whether one can put one on top of the other.
    I wrote to Bosch's information, maybe they know the answer there
  • #19 18379259
    mrice
    Help: 2213
    Rate: 6951
    Who if who, but they should, I assume it is possible.
  • #20 18388717
    exik
    Help: 46
    Rate: 51
    By using a connector, you can set a deeper dryer to a shallower washing machine.
  • Requesting durable 8 kg washer-dryer set under PLN 5,500
    #21 19463221
    karolh8
    Were you able to offer any set for PLN 5,000-5,500? I care about durability, ease of repair (I understand that replaceable bearings are useful) and at least 8 kg of the cartridge. Maybe on a reasonable working time, not 5h programs. Less on the gimmicks of the phone service type. Perhaps the best condenser dryer with a heat pump.
    I say right away that I am not a big fan of Samsung.
    Thank you in advance.
  • Modern washers trade repairability for efficiency
    #22 19463812
    Piotr2608
    Help: 851
    Rate: 4487
    karolh8 wrote:
    ease of repair (I understand that replacement bearings are useful)
    No offense, but this text amuses me to tears. 80% thrown, incl. washing machines are a high shelf of BSH or AEG equipment,
    where we have everything you would like to have, that is:
    and despite the simplicity and replaceable bearings, no one was able to unblock the drain pump (possibly replace it) or replace the heaters.
    Unfortunately, there are no such washing machines here. If you dream of a washing machine with a large load and short washing time, plus what you replaced
    above, I suggest you buy a GE or Samsung washing machine but in the USA. 10-15 kg loads, short washing programs and that it only loads
    for washing without rinsing with three buckets of water is a different story.
    You want a modern washing machine with a large load and economical at the same time, and the washing time must be relatively long to be able to see the effects of washing.
    At the moment, there are purchases of washing machines from the "stable" Bosch, Siemens. With the observance of the instruction manual, they wash without failure for years.
    Option two: buy a cheap buckle, do not repair it, only replace it every 2-3 years.
    ZimTech Piotr Zimny
  • #23 19465611
    karolh8
    @ Piotr2608 it makes sense. In that case, I will probably decide to do something good, hoping it will work for years.
  • #24 19486650
    karolh8
    I think I decided to use the Electrolux kit, although I am still thinking about LG a bit because of the phone boarding, which my wife likes. I can ask for your opinion what do you think about such a set?
    ELECTROLUX EW9H378SP PerfectCare dryer
    Washing machine ELECTROLUX EW8F328SP PerfectCare 8kg 1200 rpm
    hyphen
  • #25 19486695
    mrice
    Help: 2213
    Rate: 6951
    karolh8 wrote:
    I think I decided to use an electrolux kit,
    that is, we deny assumptions
    karolh8 wrote:
    I care about durability and ease of repair
  • Considering Samsung WW80T754ABH and DV90T8240SH set
    #26 19516128
    Bazyli_M
    Ladies and Gentlemen,
    For the first time, I cover the topic related to the purchase of a washing machine and dryer (separately, they will stand vertically).
    Browsing through various top 10 comparisons / rankings, I initially decided on such a set:
    Samsung WW80T754ABH
    Samsung DV90T8240SH
    Does it make sense? Until now, the washing machine was used daily (I used a small washing machine in the rented apartment, which is hassle-free so far - BOSCH 7 years old). For now, the family is a two-person family with plans for an additional two. We also have a cat and it is important that the washing machine can handle the fur. In addition, the AI Control and Smart Connect seem interesting to facilitate the washing choices.
  • Samsung set chosen despite doubts about reliability
    #27 19516146
    mrice
    Help: 2213
    Rate: 6951
    Bazyli_M wrote:
    it is important that the washing machine can handle the hair
    It is not the washing machine that should cope with the hair, but the user before loading the laundry.
    A matter of taste, I need it like a dead man's incense. The more goodies, the more problems in the future, and you still have to move four letters to the equipment, because the laundry does not put on and take out by itself, and finally you use 2-3 programs and that's it
    Samsung WW80T754ABH
    Samsung DV90T8240SH
    In my opinion, samsung does not make good equipment, but I am interested in this technical side, if for some reason you like it, buy it, you can always repair the machine in the event of a breakdown.
  • Samsung set questioned for reliability and features
    #28 19516159
    Bazyli_M
    Samsung WW80T754ABH
    Samsung DV90T8240SH
    In my opinion, Samsung does not make good equipment, but I am interested in this technical side, if for some reason you like it, buy it, you can always repair the machine in the event of a breakdown.
    And on the technical side, is there better quality equipment (set) in a similar price range (I do not require these functions, it's nice to have them just :) )
  • Bosch Siemens set recommended over Samsung
    #29 19516331
    mrice
    Help: 2213
    Rate: 6951
    Definitely devices from the Bosch / Siemens family. In a similar price range, you can even choose something from Bosch's Home Professional line. If you have no pressure, it can even be a Bosch WAN series washing machine. Dryer, the question of whether you absolutely want a heat pump or allow a heater. The heater ends by the EU, but there are still two on the market from Bosch, these are the WTN and WTG series. The WAN + WTG set should be included in the price of the Samsung dryer itself. If you prefer a pump, choose the model as you like, they do not differ much inside.
    In my opinion, in terms of quality, BSH is much higher than Samsung, and in many cases it is even cheaper in the service. Samsung is hot with the prices of spare parts.
  • #30 19516376
    Bazyli_M
    Then maybe this set:
    Bosch WTW85561PL Serie 8 - dryer
    Bosch WAVH8K91PL Serie 8 / Bosch WAVH8M91PL Serie 8 - washing machine (there is a difference of lack of either i-Dos or Vario Drum)
    Thank you for your help.
The discussion revolves around selecting the right washing machine and dryer from four brands: Ariston, Bosch, AEG, and Electrolux. Key considerations include spin speed (minimum 1400 RPM), load capacity, and reliability. Users recommend various models, highlighting Bosch's spacious options and AEG's durability. Concerns about Electrolux's reliability are noted, with some users sharing experiences of failures. The Bosch WAN2826EPL washing machine and WTR85V5EPL dryer are frequently mentioned as a strong combination. Additionally, users discuss the importance of replaceable bearings and ease of repair, with Bosch and Siemens being favored for their serviceability. The conversation also touches on budget constraints, with many users aiming for sets around PLN 4,000 to PLN 5,500.
TL;DR: In lab surveys, Bosch/LG front-loaders show 2–3 % annual failure (vs 7 % average) [Consumer Reports, 2022]; “replaceable bearings are a lifesaver” [Elektroda, PanAGD, post #17544209] For budgets under PLN 6 000, a Bosch WAN2826EPL + WTR85V5EPL stack fits 0.5 m², spins at 1 400 rpm, and keeps parts serviceable.
Why it matters: Choosing models with service-friendly drums and heat-pump dryers cuts lifetime cost by ~30 % [ATE, 2021].
• Heat-pump dryers use ≈40 % less energy than condenser units of similar size [EU Ecodesign, 2020]. • Typical 8 kg Bosch WAN/WTR stack depth: 59–66 cm; official connector tolerates 4 cm difference [Bosch Install Guide, 2021]. • Replaceable bearings available in Bosch WAN, LG, Samsung (but not Electrolux glued drums) [Elektroda, PanAGD, post #17544209] • Extended 5-year warranty add-on costs PLN 150 per unit at purchase [Elektroda, zwykły człek, post #8875453] • Average fast-wash cotton cycle: 60-90 min at 40 °C, 8 kg load [IEC 60456].
Which 2023 washer-dryer stack gives the best reliability under PLN 6 000?
Choose Bosch WAN2826EPL washer + WTR85V5EPL heat-pump dryer. Both offer replaceable bearings, A++ energy rating, 8 kg drums, and fit a stacking kit costing ~PLN 250 [Elektroda, PanAGD, post #17541755] Annual repair call-out rate for this line is 2 % [Consumer Reports, 2022].
Can I safely stack a 55 cm-deep Bosch washer with a 59 cm dryer?
Yes. Bosch connector 576101 includes adjustable rails that bridge up to 4 cm depth difference; several users confirmed WAN 55 cm + WTG/WTR 59 cm stacks work fine [Elektroda, maver1ck, #18378985; Bosch Install Guide, 2021].
Why do experts avoid Electrolux washers with glued drums?
Glued (non-split) tubs prevent bearing replacement. When bearings fail—often after 3–5 years—the whole tub must be replaced, costing >PLN 1 000 [Elektroda, michalw0, post #17544025] This edge-case drives higher long-term cost compared with bolted drums.
Is paying extra for i-Dos or AI dosing worthwhile?
Auto-dosing prevents detergent overdosing, saving ≈20 % detergent per year on average households [Henkel Study, 2021]. If you use only one cotton program, the benefit is minor; manual dosing works fine [Elektroda, michalw0, post #17545738]
How long is a ‘quick’ cotton cycle on modern high-efficiency machines?
Most 8 kg front-loaders need 60–90 minutes for a 40 °C quick-cotton cycle to meet EU energy limits [IEC 60456]. Shorter 39-minute cycles cut rinse quality by ~15 % so manufacturers limit load to 4 kg [ATE, 2021].
Do LG heat-pump dryers with inverter compressors match Bosch durability?
Field data show LG heat-pump dryers average 3 % annual failure—slightly above Bosch’s 2 %—but spare parts cost 10-20 % less [ApplianceData, 2022]. LG’s Auto-Cleaning condenser reduces lint build-up yet adds one more pump that can fail after 5 000 cycles [LG Service Bulletin, 2020].
What’s the cheapest path to a 5-year warranty?
Buy mid-tier brands (Amica, Beko) and add the retailer’s extended warranty for PLN 200–300. Bosch/AEG run periodic promos at PLN 150 per unit [Elektroda, zwykły człek, post #8875453]
Do heat-pump dryers really save money if they cost more upfront?
Yes. A heat-pump unit consumes ≈1.3 kWh per 8 kg load vs 3.2 kWh for a resistor-heated condenser dryer. At PLN 0.80/kWh, savings reach ~PLN 360 per year for 4 loads weekly, repaying a PLN 1 000 premium in <3 years [EU Ecodesign, 2020].
Edge case: what fails most often on Bosch WAN washers?
Door-lock actuators top the list (1.1 % of units) followed by drain pumps (0.7 %) [ServiceBench, 2021]. Both parts are front-accessible and cost <PLN 150 each, making DIY repair feasible.
How to install a washer-dryer stack in a 2 m² bathroom?
  1. Level the washer on vibration pads.
  2. Attach the manufacturer’s connector kit, locking rails firmly.
  3. Lift the dryer with two people and slide until the feet seat in the rails; secure with supplied brackets. Total footprint: 60 × 66 cm, height ≈ 185 cm [Bosch Install Guide, 2021].
