[Solved] Seeking Code for Aeris Next Zehnder ComfoAir Q350 Recuperator After Change in Unit Setup
maciacho 30384 6
  • #1 17111858
    maciacho
    Rate: 104
    Hello, I need the code for the comfoair q350 zehnder unit because I can't run it because I have changed the intake and launcher sides and it works wrong this way. Of course, I understand all installers and this code, please, e-mail: maciacho30 @gmailcom Thank you in advance for your help.
    Added after 18 [hours] 2 [minutes]:
    I will answer it myself, I already have it!
    As if what to write on priva.
  • #2 17162628
    LucaM
    Rate: 20
    I will ask and what is the password because it also needs?
  • #3 17209854
    Bennysecond
    Rate: 17
    Regards,
    • ComfoAir350 Zehnder.pdf (533.71 KB) You must be logged in to download this attachment.
  • #4 17218215
    Wacha77
    Rate: 8
    Bennysecond wrote:
    Regards,
    This is the manual for the "old" model, and what will the 4-digit service code for the aeris next / comfoair q series be?
    I want to clean the recuperator in the service manual is written to enable the service mode (for which you need this code)
  • #5 17224402
    Bennysecond
    Rate: 17
    hmmm ...
    Maybe something like this:
    1. OK button
    2.3 seconds MENU button,
    3. MAN button (press within 3 seconds),
    4. OK button,
    5. code 14,
    6 OK button,
  • #6 17461558
    rtomkow
    Rate: 14
    Hi, I haven't found the Zehnder Q450 recuperation installer code anywhere, will anyone help? possibly please on priv. Thank you.
  • #7 17948335
    maciacho
    Rate: 104
    subtract the devil's numbers 4.
The discussion revolves around obtaining the service code for the Zehnder ComfoAir Q350 recuperator after a change in the unit's setup. The original poster initially requested assistance via email but later indicated they found the code themselves. Other participants inquired about the service code for different models, such as the Zehnder Q450, and shared potential methods for accessing service modes, including a sequence of button presses and a specific code (14) for enabling service mode.
