[Solved] programming the ZIP 308 universal remote control for Ferguson AC-8000HD
Alienar 8376 9
How can I program an Elmak ZIP-308 universal remote to work with a Ferguson AC-8000HD DVB-C tuner without the original remote?
There is no Ferguson AC-8000HD code listed in the ZIP-308 database, so the suggested path is to try the remote’s unknown-device search mode or contact Elmak, the remote manufacturer, for support [#17092962] [#17092982] [#17092987] The thread also says the learning/code-detection attempt from the manual did not work for this tuner [#17092967] One reply concludes that the ZIP-308 is simply not suitable for this decoder and that you need the original remote instead [#17093392] The final update from the original poster confirms the universal remote still did not work and the topic remained unresolved [#17143959]
  • #1 17092800
    Alienar
    Hello, please help me find the code to program the Elmak-ZIP 308 remote to work with the DVB-C Ferguson AC-8000HD tuner. I bought this tuner without a remote control. In order to use the tuner, I had to buy a universal remote control for DVB-C receivers, just ZIP-308. I can't program TV channels without it.
  • #3 17092967
    Alienar
    I have an instruction, unfortunately according to it, I was unable to communicate with the tuner. I tried to determine the code via the remote control, because according to the instructions it is possible - to no avail.
  • #4 17092982
    spinacz
    Help: 1204
    Rate: 2651
    Write to the manufacturer.
  • #5 17092984
    Alienar
    To the manufacturer of the remote control, I understand because no tuner?
  • #6 17092987
    spinacz
    Help: 1204
    Rate: 2651
    Yes to the manufacturer of the remote control.
  • #7 17092993
    Alienar
    I will write, only the question of whether and when he will write back at all.
    Thank you for your help.
    best regards
    I will come back to the thread when I get some information.
  • #8 17092995
    spinacz
    Help: 1204
    Rate: 2651
    Then call, there is definitely a contact number given there.
  • #9 17093392
  • #10 17143959
    Alienar
    The topic has not been solved, I have not found the original remote.
    The purchased universal remote control, which was supposed to support this type of decoder, does not work.
    Money thrown in the mud.
    I have to buy a new set-top box with a remote control
The discussion revolves around programming the Elmak-ZIP 308 universal remote control to operate the Ferguson AC-8000HD DVB-C tuner. The user is seeking the correct code to enable functionality, as the tuner was purchased without a remote. Initial attempts to find the code through the remote's instructions were unsuccessful. Suggestions included contacting the remote control manufacturer for assistance, as the tuner model is not listed in the manufacturer's database. Ultimately, the user expressed frustration over the inability to program the universal remote, leading to the conclusion that purchasing an original remote or a new set-top box may be necessary.
