Connecting AerisNext 350 Recuperator to Satel Integra 128 Control Panel
atomic339 1206 2
  • #1 19876196
    atomic339
    Hi
    Is it possible to connect an AerisNext 350 recuperator under the Satel Integra 128 control panel?
    Basically, I am concerned with one "absence" function, which would be switched on when, for example, an alarm is passed.
  • #2 19876551
    gkwiatkowski
    CCTV and Stationary Alarms specialist
    Help: 650
    Rate: 1231
    From the description of the recuperator, it appears that you can connect a control module to it via KNX.
    You can connect a bus converter to KNX to the Integra and try to control the recuperator.
  • #3 19876555
    alster1
    Help: 352
    Rate: 540
    This question is more for the recuperator specialist, the Integra can handle it without any problems as long as the recuperator has some input which can be controlled.
    In the recuperator description I have seen the "AVAY" function, which switches the ventilation to the lowest recuperator output, the only question is whether the device allows this to be switched on from the "outside".
