[Solved] Selecting Network SIM Card for Long-Term Use in GSM Alarm Notifications
1.b 26034 10
  • #1 17113402
    1.b
    Help: 5
    Rate: 70
    Hello. It will be advised by someone from which network sim card to alarm (GSM notification) with a long expiration date. I need such sim cards so that all outgoing calls are active for the duration of the account's validity period (notification works by dialing the number and calling the selected number). Thanks in advance.
  • #3 17113483
    1.b
    Help: 5
    Rate: 70
    Only from what I see, she has only 30 days to spare, I'm wrong
  • #4 17113570
    tino2003
    Admin of GSM Group
    Help: 1971
    Rate: 2085
    Play on the card from the new one there you have 1GB for 5 PLN to use without a time limit.
  • #5 17113646
    1.b
    Help: 5
    Rate: 70
    So in play it is without a deadline, and it's enough that something will be on the account and I can call (notification alarm turns on rings on my phone) whether it will work for all networks or only in play.
  • #6 17113680
    tino2003
    Admin of GSM Group
    Help: 1971
    Rate: 2085
    All you have to do is to have funds, calls, text messages for free play on your account and you will buy a 100-minute package for PLN 15 for other networks, which is valid for an indefinite period.
  • #7 17113947
    Cmentarz
    Rate: 8
    In Virgin, as a friend, kindlar recommended you have free. The freemium package is valid for 30 days but it renews itself for 6 months and in it you have these additional bonuses. However, if you top-up a card for 5 PLN and make one call, the validity of the account is normally a year. And when the package expires or runs out, it normally takes funds from the card. And on the Internet you can manage your account and after half a year when the package expires completely you can resume it, thanks to which the funds on your account will not be affected.
  • #8 17115440
    Gienek
    Level 37  
    Help: 393
    Rate: 352
    Wystarczy mieć na koncie środki, rozmowy, smsy do play za darmo a do innych sieci kupuje się pakiet 100 min za 15zł i który jest ważny bezterminowo.
    This is not the case with it. There are some restrictions that need to be done periodically to keep your account active and "free text messages". Anyway, PLAY describes it on your website https://www.play.pl/kampanie/nicnieprzepada/ - at the bottom of the page - Documents
  • #9 17115674
    1.b
    Help: 5
    Rate: 70
    Like such a small sim card and so much problem. Everywhere, some hooks, or the importance of a short kata or something else. So which network would be the least maintenance-free, if that's the way it could be called. (so you do not have to send something or something similar).
  • #10 17115865
    Cmentarz
    Rate: 8
    After all, you have an important year in Virgin. You can order for a free starter on the card. If you do not want a package, you only top up your account with an amount that would be enough for notifications and you have peace of mind. You monitor your account balance online and that's it. Each recharge causes that the year of validity counts from the moment of recharging. When you get the starter you need to top up your account and make the first call to make everything work. Then it's minimal service. The freemium package is just a bonus and you do not have to activate it. Only that we get a bit of free minutes, text messages and the internet for free.
  • #11 17116072
    1.b
    Help: 5
    Rate: 70
    Ok. Buddy "Cemetery" thanks, but I will take it as you say virgin.
✨ The discussion revolves around selecting a network SIM card suitable for long-term use in GSM alarm notifications. Users recommend various options, highlighting the importance of maintaining account validity for outgoing calls. Virgin Mobile's freemium package is noted for its 30-day validity, which can be extended to a year with a top-up and a call. Play offers a card with 1GB for 5 PLN, allowing indefinite validity as long as there are funds in the account. Users express concerns about the maintenance requirements of different networks and seek a solution that minimizes ongoing management. Ultimately, Virgin Mobile is favored for its ease of use and minimal maintenance.
