[Solved] Satel Perfecta: Best SIM Card & Internet Operator Recommendations for 5GB, Subscription vs Top-up
szewcuu23 19383 4
  • #1 17700550
    szewcuu23
    Level 4  
    Gentlemen, what offer and Internet -SIM operator do you recommend to Perfecta headquarters today?
    It seems to me that you need to count a package of around 5GB.
    More subscription or top-up- (minimizing interference)?
    I will be grateful for your opinions and experiences.
  • #2 17700653
    dariusz.bembenek
    Stationary Alarms specialist
    Help: 455
    Rate: 615
    The SIM card should be such that the range and transmission are appropriate for a given location. Is it safe or cheap?
    How safe is it, see above.
    Perfecta consumption (per month) is, depending on the frequency of use, several dozen MB per month. I've heard voices that some people even eat hundreds of MB. But the topic is almost always limited to 1GB. It should be remembered that even if you do not use the mobile application, the control panel still exchanges data with the satellite server (listening). These are symbolic amounts, but they are.
    BTW:
    You must watch out for the purple operator when configuring the MCC / MNC code (this operator is gradually switching off national roaming).
    Prepaid or subscription?
    So again - safe or cheap? In general, most operators "forbid" the use of regular cards in m2m solutions. Telemetry cards should be used, and these are special cards (additionally for subscription). It is obvious, however, that an ordinary consumer will buy a "normal" card, not a "telemetry" card.
    By the way, maybe a week or two ago there was a similar discussion.
  • #3 17701359
    Pazurek
    Rate: 8
    I bought it for PLN 5 and put it into the Perfect Play Card for a renewed valid for 1 year, I topped it up for PLN 10. I registered on the PLAY website, and for PLN 5 100 SMSs were added to all networks that were valid indefinitely and for another PLN 5 1GB Internet also valid indefinitely. For a month of using the alarm, often entering from the Perfecta Soft computer and the Perfecta Control phone, I used only 45 MB from 1 GB of Internet. I have an alarm for only 1 month and so far it seems to be a good option, with such Internet consumption it will take a year. If nothing changes, it will recharge for PLN 10 again after a year :D
  • #5 18231491
    szewcuu23
    Level 4  
    I chose the best offer in my opinion "Play Renewal"
