Juke Orange Exclamation Mark (w/ Underline) Issue - DIY Solutions & Possible Causes
JukeM 19077 5
  • #1 17130545
    JukeM
    After starting the engine in yuk, the orange exclamation mark in parentheses shines - with such an underline under the exclamation mark.
    You don't know what it can be?
    Can I fix it myself?
    Moderated By CameR:
    Reg. 3.1.15. Do not ask immediately in the forum, if you have not checked anything yourself or attempted self-diagnosis. Remember that advice is given remotely in the absence of physical access to the device, the problem must be very well described and understood by users, and the title should include the brand, model and brief description of the fault.
  • #2 17130584
  • #3 17130796
    Romek T.
    Help: 7
    Rate: 43
    Such?
    Check the tire pressure. If it is good, the pressure sensor may be damaged.
  • #4 17131591
    JukeM
    I checked.
    Brake fluid - approx.
    I had less air in one tire. They pumped up the compressor at the station.
    Unfortunately, nothing helped. Exclamation mark - just like the photo is still lit.
    Service remains ...
    I have to go fast, can I leave it "for Christmas"?
  • #5 17132693
    Romek T.
    Help: 7
    Rate: 43
    You can after Christmas but with such something you can drive without any problems to a regular workshop with the possibility of connecting a computer without even a queue. For a little money, the error will be removed and in addition they will say in which wheel this sensor turned on.
  • #6 17132793
    JukeM
    Thank you for your help!
    Best regards!
