Vw Golf 4 exclamation point on the board - Red indicator (!).
Tomol94 67971 9
Why does the red exclamation mark warning with three beeps appear in a VW Golf 4 after driving a few meters, even though the brake fluid level and brake pads are OK?
The red (!) with three beeps after driving off usually means an ABS system fault, not a problem with brake fluid or brake pads [#16805562][#16805915] It can appear once the car reaches about 20 km/h, when the ABS error is detected [#16805562] Check the ABS power supply first: the fuses on the battery and in the fuse box, plus any weak or burnt contacts, because one reported fix was simply replacing a fuse with poor contact [#16805915][#16806720] Also diagnose the ABS module and wheel speed sensors, since a supply issue or loss of communication with one or more sensors can trigger the warning [#16805937][#16806584] Once the ABS fault is repaired, the warning should return to normal [#16805562]
  • #1 16805498
    Tomol94
    Hello. I have a Golf 4 1.9 tdi. When I pass a few meters, the indicator lights up with an exclamation mark in red (!), Squeaks 3 times and then only flashes. I have a good level of brake fluid, I have new brake pads. I have a separate control (p) from the handbrake. I will add that I am stuck with ABS - can it affect something with Abs or something else? GREETINGS.
  • #2 16805562
    Chupacabra
    Help: 247
    Rate: 868
    Tomol94 wrote:
    I will add that I'm stuck with ABS - can it affect something with Abs or something else? .
    Of course. After exceeding the speed of 20 km / h, the car reports an ABS system error. Bring the system to order and everything will be back to normal.
  • Weak fuse contact caused red warning light
    #3 16805915
    Eidems
    Help: 83
    Rate: 253
    I had a similar solution, the prosaic solution, the old fuse had a weak contact, I replaced it with a new one and it still works today.
  • #4 16805937
    Chupacabra
    Help: 247
    Rate: 868
    There may be a problem with the module supply and maybe with communication with one or several wheel speed sensors.
  • Weak fuse contact on battery fuse block caused warning
    #5 16806481
    Tomol94
    Are you referring to these three 30A guns on the battery?
  • #6 16806490
    mod22
    Help: 130
    Rate: 312
    Check the oil. Level and when to exchange.
    Moderated By CameR:
    Reg. 3.1.11. Do not send messages that do not contribute to the discussion.
  • #7 16806498
    Tomol94
    The oil in the engine has nothing to do with the brake system, and this indicator suggests something just with the brake system.
  • #8 16806547
    leonov
    Help: 1039
    Rate: 2251
    And what a problem to do diagnostics, and do not guess the guesses.
  • #9 16806584
    Chupacabra
    Help: 247
    Rate: 868
    Why these combinations. Make the order with ABS. You can connect under the computer so that you do not look in the dark, which element does the problem.
  • #10 16806720
    psilos1
    Level 32  
    Help: 203
    Rate: 881
    Check not only the fuses on the battery but the box itself - often contacts are burning
The discussion revolves around a red exclamation mark indicator issue in a VW Golf 4 1.9 TDI, which activates after driving a short distance, accompanied by three beeps and then flashing. The user has confirmed adequate brake fluid levels and new brake pads, while also mentioning a separate handbrake control. Responses suggest that the problem may be linked to the ABS system, with recommendations to check for ABS errors, inspect fuses for weak contacts, and ensure proper communication with wheel speed sensors. Diagnostics are advised to pinpoint the exact issue, as the indicator is primarily related to the brake system.
