Seat Leon 1.9 TDI 2001: Persistent Yellow Indicator Circle with Triangle Warning Light
vafioza 29037 7
  • #1 16383431
    vafioza
    Hello . I have the Seat Leon 1.9 TDI 2001. My problem is that after 10-15 minutes I get a yellow indicator circle and in the middle a triangle with an exclamation point and I do not want to go out. It will be extinguished only after the engine has been restarted. What could have happened?
  • #2 16383464
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Do you mean a manual brake control? Check the brake fluid level.
  • #3 16383467
    Michal_WWL
    Help: 76
    Rate: 283
    Here, on page 2.14 link
  • #4 16383491
    vafioza
    I am sorry I wrote the circle and in the middle of this circle there is a triangle with an exclamation mark
  • #5 16383501
    Michal_WWL
    Help: 76
    Rate: 283
    ESP system. The instructions attached by me are a bit.
    There is probably something damaged and you will need a specialist visit.
  • #6 16383532
    vafioza
    much such "pleasure" will cost?
  • #7 16383542
    Vytautas_YT
    Level 30  
    Help: 128
    Rate: 297
    Electronic Stability Program (ESP) - The warning light comes on after switching the ignition on for about 2 seconds and then it should go out automatically. If the system is activated while driving, its operation will be indicated by the control lamp blinking. If there is a failure in the system or the system is disconnected, the indicator will be permanently on. If the system cooperates with the ABS system during braking, the ESP indicator will also light up.
  • #8 16383550
    Michal_WWL
    Help: 76
    Rate: 283
    No one will answer this question without a diagnosis, and this can only be carried out "live". Sometimes it's not just a computer connection and reading errors, you may also need a test drive and observe the parameters.
✨ The user reports a persistent yellow indicator circle with a triangle and exclamation mark warning light on their 2001 Seat Leon 1.9 TDI, which activates after 10-15 minutes of driving and only extinguishes upon restarting the engine. Responses suggest checking the brake fluid level and indicate that the warning may relate to the Electronic Stability Program (ESP). If the ESP system is malfunctioning or disconnected, the warning light may remain illuminated. A proper diagnosis is recommended, which may require a specialist visit and could involve a test drive to observe system parameters.
