Deca MACH 214 Charger Not Charging Tuborg Silver TS553-053 Battery: Zero Amp Issue
potas1 9630 3
  • #1 17139025
    potas1
    I have a rectifier: Deca MACH 214
    and battery: Tuborg Silver TS553-053
    The car was parked in the parking lot for two months. Now there is no reaction after turning the key. Nothing is displayed. When I check the battery voltage while charging with the charger, it shows about 2.5V all the time. The battery is approx. 4 months old and the charger was bought yesterday.
    I would like to add that when I charge the battery, the indicator showing the intensity during charging does not change position at all. Whether the battery is connected or not, the indicator shows 0A. Has the battery died then?
  • #2 17139086
    fuutro
    Help: 1450
    Rate: 836
    Automatic rectifiers require a certain minimum voltage to be present at the battery terminals. Do you have the option of recharging it with an ordinary transformer? Borrow from a neighbor for at least a few hours or try to temporarily connect it on cables (just in case, solid through gloves) to another functional one and only your charger?
  • #3 17139188
  • #4 17139350
    zetdeel
    Help: 717
    Rate: 879
    As Col. BC109B , check the 5A fuse.
    Turn on a 40-55W bulb in series with the battery.
    Up to voltage approx. 11V charge via light bulb, above this voltage charge normally (without light bulb).
    The light bulb acts as a charging current limiter, a deeply discharged battery short-circuits the charger and causes the fuse to "burn".
