Charging Issue with Vintage Car Battery: Ammeter Shows 0A, Voltage at 14.5-15V, Potential Sulfation
Doolek 120741 34
Why does my car battery show 0 A charging current while the charger voltage is 14.5–15 V, after the battery had dropped to 0 V, and is it sulfated or internally broken?
A battery that had 0 V at the terminals and then shows 14.5–15 V on the charger with essentially no current is more likely internally open or badly damaged than merely sulfated, so it is usually only fit for recycling [#12014769][#12019171] One explanation given was a break between the internal links/plates: the charger “sees” voltage but current cannot flow, so the ammeter stays at 0 A [#12014769][#12018886] If the charger is not “intelligent,” you can leave it connected for several hours and watch for current to start rising; if it remains at zero, the battery should be scrapped [#12014474][#12017839] Another practical note was to check the electrolyte level first, because some chargers may not start on a very flat battery [#12014588] The thread also notes that batteries discharged to 0 V are not always irrecoverable, but in this case the symptoms point to internal failure rather than normal deep discharge [#12014588][#12019171]
  • #1 12012201
    Doolek
    Rate: 9
    Hi. I have the following problem with a relatively new battery - not all year round. When you try to charge it with a rectifier, the ammeter does not swing and shows 0 A, with the voltage at the terminals showing 14.5-15 V. The battery before starting the charging test had 0 V at the terminals.
    The battery was mounted in an old vintage car, garaged in winter. The car was fired and once every 2 weeks for the so-called "burnouts". After a 4-week break, the battery died, so I took it to recharge it, but unfortunately I have a problem as above.
    Is it possible that he could sulfate so quickly? Unfortunately, I am not able to check the sulfation status because due to the battery's design and not other, the user does not have access to the holes through which the liquid can be refilled.
  • #2 12012210
    kizek
    Help: 288
    Rate: 488
    What kind of charger do you have?
  • #3 12012254
  • #4 12012271
    matołek
    Rate: 28
    Parallel connect a second battery with relatively good performance and charge two together.
  • #5 12012337
  • #6 12012435
    matołek
    Rate: 28
    I think so. I do it every day. Perhaps the rectifier does not take action because it "sees" nothing at the ends. Anyway, even those who do not have to 'see' before they break through the water a bit, it will take even 1 day.
  • #7 12013100
  • #8 12013408
    gimak
    Help: 614
    Rate: 1678
    georgesgr wrote:
    Any battery discharged below 10V is only suitable for scrap.
    And again an unconfirmed myth, but ...
    in this case it is probably right that for scrap, not because of discharge, but because of a break in the battery.
  • #9 12013829
  • #10 12014427
    gimak
    Help: 614
    Rate: 1678
    georgesgr wrote:
    For some it is a myth, for others it is many years of experience.
    I didn't get it from the ceiling, but from 40 years of adventure with cars. During this time, I, of course, accidentally discharged the old and new batteries several times, but immediately charged, they served for a long time. Therefore, I consider such statements unjustified, because this thread does not cost you to charge the battery and check it. I am also not saying that after such a discharge the battery has exactly the same capacity as before it was discharged.
  • #11 12014474
    750kV
    Help: 240
    Rate: 713
    Hello all. I suggest connecting the battery (without the second parallel) to the charger and waiting for about 5-6 hours. If the ammeter is still zero, the battery must be disposed of. If the current increases, further charging can be attempted. Greetings.
  • #12 12014588
    pimark
    As long as the charger is not too "intelligent" and will turn on the charge. First check the electrolyte level.
    This one was discharged to zero ...
    Not true, a few years ago my trunk light switch fell off, the car was left in the open for a week, the battery was discharged to zero, after charging it served another three or four years. The second case, an opened trunk in the garage, two days, battery discharged to zero, serves me already in the second winter (at -25 degrees it turns without any problems). I have placed the battery with 7 -8 V many times, it has probably served me for about 9 years, used occasionally, frequent self-discharge, it is already raining, but the season will last longer.
  • #13 12014613
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    Code: Bash
    Is the terminal voltage the same as the battery posts? It seems to me a banal, faulty connection. The battery that started the engine before is unlikely to lose its conductivity so suddenly.
    I think I have too little imagination to understand such a state that the battery that started the engine a few days earlier now does not completely take away the power from the power supply. Was it absolutely dry?
  • #14 12014769
    ^ToM^
    Help: 495
    Rate: 2939
    Doolek wrote:
    Before starting the charging test, the battery had 0 V at the terminals.
    In my opinion, the battery is damaged. He has a gap between the links. This causes that you get 0V on the terminals and 14-15V (after connecting the rectifier - the current will not flow and hence the result 0A.
    Unfortunately, such a battery can only be replaced.
    Greetings!
  • #15 12017839
    Doolek
    Rate: 9
    Thanks a lot for the suggestions.
    The charger is Bester 12V / 8A (20-90 Ah) and works fine with other batteries.
    I can try, but I'm afraid if the temperature will get too high when trying to force the charging for these few hours.
    When I try to charge for a few minutes, disconnect the terminals and connect the voltmeter, the voltage decreases over time from about 10 V to zero, therefore I wonder if the problem is actually an open circuit. Secondly, from where the break would suddenly appear, if the car and the battery had no chance to be mechanically damaged.
  • #16 12018344
    web69
    Help: 188
    Rate: 629
    Plug in the rectifier, the temperature will not rise, because electricity is not flowing. And just watch. Sometimes I saved discharged batteries by connecting them to a 24V charger (constant current control required! Dangerous and stupid, but a few batteries got up)
  • #17 12018886
    emeryt2
    Help: 717
    Rate: 2302
    This one will not get up, the internal resistance of the link is infinite!
  • #18 12018989
    Zico63
    Level 37  
    Help: 364
    Rate: 1036
    Doolek wrote:
    The battery was mounted in an old vintage car, garaged in winter. The car was fired and once every 2 weeks for the so-called "burns".
    And it killed him: how many in such a car can a "bicycle dynamo" from the era installed there be charged? 10A? As long as he did not work on the "indicator light". How much has he worked? 10 minutes?
    He lived so long ... So, as I thought, he hadn't been recharged yet, after these "burnouts".
    And also:
    gimak wrote:
    During this time, I have, of course, accidentally discharged several times, both old and new, but in a minute charged, they served for a long time.
    my emphasis.
    And this is an explanation: the faster the energy replenishes, the more efficient it will recover; all because - never!
    To sum up, already in the third post of the topic Mate Irekt he gave an answer that seemed to end the topic - and yet no ...
  • #19 12019171
    ^ToM^
    Help: 495
    Rate: 2939
    Internal corrosion of the plates and poles is usually the cause of the break, not necessarily a mechanical failure immediately. Yes, you have measured 10V, but you are unlikely to force the current flow - try to connect the light bulb and measure the current flowing through it. It will be negligible and the voltage will drop practically to 0V immediately. This is what proves the internal break in the main connections between the active plates (especially as it happened suddenly).
    Thus, the battery is recyclable only - resuscitation, desulfurization, etc. will fail.
  • #20 12019312
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    Code: text
    Could there be any more details on this charge? It all looks very suspicious to me. I am afraid that it will finish loading after a few minutes of trying. And the battery is actually deteriorating with every passing moment. After all, the confusion is with the annual battery. Unless it turns out that this year is just a vehicle plug.
  • #21 12019403
    matołek
    Rate: 28
    For a trivial reason, a doctoral thesis is about to come out. The conductor in the battery is the electrolyte and if there is no density, it is not conductive and as long as it is battery. it will not 'fake' this density, it will not take electricity. That's why I suggested a parallel connection with a second relatively good battery.
    By the way, I returned the advertised aku just a moment ago. with a voltage of 5V, which was supposed to be charged with a Lidl charger for 2 days, and I stayed at Stefpol 25 A from Saturday and made 670 A on a 680 sticker. Gentlemen, if you do not do it, do not fill your counter.
    And I advise all mechanics to learn how to use the battery and include it in the basic maintenance activities of the car, and not just sending them to the point of sale with receipts from testers for which they still charge PLN 20. Shame.
  • #22 12025348
    Doolek
    Rate: 9
    The fact that this car is a historic monument does not necessarily mean a weak charging system. A brand new Bosch 80A alternator pulling out 54A at 1900 RPMS is installed.
    The battery was precharged with the already mentioned Bester charger. The charging voltage remained at the level of 14.5-15 V, and the current gradually increased from 0.5 to 2.5 A. At present, the battery is charged with a pulse-charging rectifier. After landing, I will let you know how the battery will behave.
  • #23 12027146
    mczapski
    Level 40  
    Help: 468
    Rate: 1658
    So the current was not zero after all. Still, the quality of the information is poor. What is it that was precharged? 5 minutes, an hour, ten hours? Admittedly, he doesn't know what this BESTER can do, but he is nominally correct. So, as should be judged, it was necessary to show patience and professionalism. If a colleague does not commit more nonsense, the battery will come to life. But I am afraid that the training runs of this monument with an 80 A alternator are short-lived. And it does not serve, as you can see, the battery or the engine.
  • #24 12027417
    gimak
    Help: 614
    Rate: 1678
    The current consumption of the battery during charging with the alternator (and thus - after how many kilometers the battery will be charged) does not depend on the current of the alternator, but on the situation in the network (current flow, voltage drops), because the installation in the car must be considered as a network. In simple terms, it depends, of course, on the alternator's capabilities, but also on how many and what consumers it has to handle in addition to the battery.
  • #25 12028055
    ^ToM^
    Help: 495
    Rate: 2939
    According to the guidelines of CENTRA (and other manufacturers as well), the battery discharged to a voltage lower than 10V (absolute maximum discharge is 1.4V per cell, i.e. 8.4V - voltage measurement at the poles one hour after disconnecting the load) can be disposed of. Thus, a battery discharged to a voltage of 5V is by all rules (and common sense) scrap. Note that the 11.5V battery has only 10% of the rated charge!
    We do, we do, so I don't know, so don't be in a rush :)
  • #26 12028477
    matołek
    Rate: 28
    ... and according to the warranty conditions of many distributors, eg Varta - 8V, it is a loss of warranty rights, but how to explain to the customer that the battery under the warranty is discharged. Even those 30 years ago had special battery carriers so that it would be convenient to carry it every few days for charging.
  • #27 12037834
    Doolek
    Rate: 9
    The battery was charged for 4 hours with the aforementioned Bester charger and the charging current during this time increased from a value close to 0 (the indicator on the charger has a not very precise scale, so I will not give the exact value) to 2.5 A. Unfortunately, but due to the trip I could not leave longer this charger and connected another one in which you can set the desulphation mode of the battery, and after charging it, it automatically switches to the maintenance mode. After a few days of charging, the charger showed that the charging was complete. The battery was exhausted momentarily when I tried to start the car. Therefore, I give up trying again due to lack of time and buy a new one. The old one goes to recycling.
    I do not know on what basis my colleague concluded that I was damaging the engine, but I am not going to describe what the burning of the relic is, because it is not the topic of this thread. As for the quick discharge of the battery, the reason was a badly connected audio system installation.
    I think that the topic can be considered closed because some people are starting to throw shits here ... m. The conclusion for the future is:
    1. Check the voltage on the battery from time to time and charge it if necessary.
    2. or connect the supporting rectifier.
    Best regards and thanks for any suggestions.
  • #28 12709604
    kaiserman
    Rate: 8
    Hello, what is the desulphurization rectifier, the exact model, how can I know, and here we are talking about STEF-POL 30A, which model is it exactly? :) I charged the 17-year-old 44Ah battery with the impulse charger, so for the tests it had a total of 0V and it has three days of 12V still the same, I have not discharged it with a light bulb yet, I only added distilled water to it.
    And in another battery I still have only 7V and it is sulphated not used for a long time and I think to add 20 ml of perhydrol 30% to one cell, first pour out 20 ml of sulfuric acid on one cell. Then load it. Or pour perhydrol then pour out, pour in distilled water, charge with a pulse charger for 10 hours and then pour sulfuric acid?
  • #29 12712579
    czasteczkakwarkowa
    Rate: 25
    you do not need to charge to 12v, you can charge to 14.4v it will be better and faster and you will know faster if it is dead.
  • #30 12712612
    vodiczka
    Help: 1185
    Rate: 4311
    A big shortcut because every electrolyte is by definition conductive, even when it "has no density". The cause of not charging a deeply discharged battery is more complex.
The discussion revolves around a vintage car battery that shows 0A on the ammeter while the voltage reads 14.5-15V during charging attempts. The battery, which had previously been discharged to 0V, is suspected of sulfation or internal damage. Various users suggest troubleshooting steps, including checking the charger type, connecting a second battery in parallel, and monitoring the electrolyte level. Some participants argue that a battery discharged below 10V is typically considered scrap, while others share personal experiences of reviving seemingly dead batteries. The original poster mentions using a Bester 12V/8A charger and a pulse-charging rectifier, but ultimately decides to replace the battery after unsuccessful attempts to recharge it.
TL;DR: Field tests show 80 % of lead-acid batteries left under 10.5 V for 24 h never recover [Battery University, 2023]. “Any battery discharged below 10 V is only suitable for scrap” [Elektroda, Anonymous, post #12013100] Why it matters: Knowing when revival is futile saves time, money and avoids safety risks.
• Absolute minimum voltage before sulfation becomes permanent: 10.5 V (6 × 1.75 V) [Battery University, 2023]
• Safe revival current: ≤ 0.1 C (e.g., 4 A for 40 Ah battery) [EnerSys Manual, 2022]
• Typical self-discharge of flooded lead-acid: 4–6 % per month at 20 °C [Battery Council, 2021]
• Internal resistance approaches ∞ Ω when a cell strap breaks, causing 0 A charge current [Elektroda, emeryt2, post #12018886]
• Recycling refund in EU: €5–€10 per car battery returned [EU BAT Reg., 2020]
Why does the charger show 15 V but 0 A?
The charger senses open circuit voltage; a broken inter-cell strap or dried-out cell creates infinite internal resistance, so voltage rises quickly while no current flows [Elektroda, ^ToM^, post #12014769]
Can a 12 V battery survive a drop to 0 V?
Rarely. Tests show only about 20 % regain usable capacity after deep-zero discharge [Battery University, 2023]. Forum members who tried reported immediate scrap recommendations [Elektroda, Anonymous, post #12012254]
What causes an internal break between cells?
Plate corrosion or vibration cracks the lead strap that joins cells. Corrosion progresses even in storage, leading to a sudden open circuit without mechanical shock [Elektroda, ^ToM^, post #12019171]
How can I check if the battery is really open-circuit?
  1. Connect a 21 W bulb across the terminals.
  2. Measure current; a healthy 12 V battery should deliver ~1.7 A.
  3. If current is near zero and voltage collapses, the internal circuit is broken [Elektroda, ^ToM^, post #12019171]
Should I parallel-connect another battery to jump-start charging?
Parallel charging can trick simple chargers into starting, but it also forces the good battery to carry most of the current. Use only if you can monitor voltage and temperature every 15 min [Elektroda, matołek, post #12012435]
What voltage and current limits are safe for revival attempts?
Set charger to 14.4 ± 0.1 V and limit current to 0.1 C. Stop if battery exceeds 50 °C or fails to take current after 6 h [EnerSys Manual, 2022].
Does sulfation really form in a few weeks?
Yes. Leaving a partially charged battery for four weeks can trigger hard sulfate crystals, especially below 12.4 V open-circuit [Battery Council, 2021].
Is chemical desulfation with perhydrol (H₂O₂) recommended?
No. Hydrogen peroxide reacts violently with sulfuric acid and lead compounds, risking heat and oxygen release. Manufacturers provide no data supporting performance gains [SAE Paper 2019-01-0064].
How long must I drive to recharge after short "burn-outs"?
With a 54 A alternator and 20 A accessory load, a 40 Ah battery needs approx. 40 min at 2 000 rpm to regain the 20 Ah lost during a start cycle [Bosch Tech, 2022].
What maintenance keeps vintage-car batteries healthy?
  1. Measure voltage monthly; recharge when it drops below 12.4 V.
  2. Use a 1 A maintenance charger during storage.
  3. Inspect electrolyte level every six months and top with distilled water [Battery University, 2023].
Do smart chargers fail on zero-volt batteries?
Smart chargers often require 2–3 V to detect polarity. Below that, they refuse to start, showing 0 A [Elektroda, 750kV, post #12014474] Simple linear chargers or bench supplies may work better.
When should I send the battery for recycling?
If after 6 h at 0.1 C the current stays below 0.2 A or a cell fails the bulb test, recycle it. EU schemes refund €5–€10 per unit [EU BAT Reg., 2020].
