Opel Corsa C fuses - I need a fuse scheme in the Opel Corsa C 1.3
Donia1234 19827 5
  • #1 17152819
    Donia1234
    As in this abbreviated question, I ask for a fuse scheme :) Specifically, I mean the fuse of the left turn signal :) Thank you for all the answers :)
    Edit: For Opel Corsa C 1.3 CDTI :) Because I see that it is not displayed :)
  • #2 17152845
    Pedros050
    Help: 2471
    Rate: 3926
    Hello. Maybe you would have to check if the bulb is not burning? Is the entire left side off?
  • #3 17152871
    Donia1234
    The bulb one does not work: / all the time
    Added after 42 [seconds]:
    But already listed, but it still does not work
  • #4 17152879
    Pedros050
    Help: 2471
    Rate: 3926
    Have you checked the voltage? Cables not torn or bare of mass?
  • #5 17153074
    abart64
    Help: 271
    Rate: 633
    How such a twisted frame is probably the contacts of the socket burned out. See how they look, whether there are signs of heating, changed contact color or burnt hole.
  • #6 17153148
    -kris-
    Help: 12
    Rate: 39
    Opel Corsa C fuses - I need a fuse scheme in the Opel Corsa C 1.3 hi
    relay no. 13 left, 14 cases
    here you have a schematic
    • Corsa C (X01) 1.3 CDTi.rar (729.91 KB) You must be logged in to download this attachment.
