Opel Corsa C wiring diagram or list of fuses with socket numbers and functions
HeadCutter 174248 17
Where can I find a wiring diagram or fuse list for an Opel Corsa C with the fuse socket numbers and functions?
A fuse diagram PDF for the Opel Corsa C is available at the shared link [#8482109] Fuse 25 is for the clutch switch at the clutch pedal lever and the brake sensor [#6967820] The Corsa C also has a second small relay box in the BCM area with at least five relays [#2830407] Those relays are described as being for items such as the horn, turn signals, road lights, and central locking [#2831137]
  • #1 2428312
    HeadCutter
    Rate: 11
    Hello. I am looking for a wiring diagram for this Opel model, unfortunately I could not find one through the search on this forum. Does anyone have such a schematic?
    Alternatively, I would be provided with a list of fuses with the number of sockets and what the fuse is for.
    Many thanks in advance :)
  • #2 2431206
    krzysztof1291
    Help: 31
    Rate: 151
    You say, and you have.
    Provide more data for the future.
    • Corsa C bezpieczniki.pdf (46.22 KB) You must be logged in to download this attachment.
  • #3 2830407
    arekm
    Rate: 71
    Hmm, where is the horn relay? I can't locate the bully. In general, the Corsa C has a second, small box with at least 5 relays. For her, the description would be just as useful.
  • #4 2831137
    woooojtek
    Level 19  
    Help: 21
    Rate: 104
    In the second box, in the pit, there is the so-called BCM body control shaft and relays there are relays, probably from the signal, direction indicators, road lights + central locking. In fact, descriptions are available rather for websites.
  • #5 6141484
    wisniak222
    Rate: 21
    I am looking for a wiring diagram for Opel Corsa D 2007. capacity 1.3 CDTI diesel.
    I searched for a long time and could not find it.
    Alternatively, I would be provided with a list of fuses with the number of sockets and what the fuse is for. If someone has such a diagram with fuse descriptions, please send this diagram to me by e-mail wisniak222(_at_)wp.pl
    I will be very grateful !!!
    so I am waiting and greetings
  • #6 6755621
    marcel1973
    Rate: 39
    And where is the description of fuse 25?
  • #7 6967820
    marcel1973
    Rate: 39
    Fuse 25 is responsible for the clutch switch (at the clutch pedal lever) and the brake sensor.
  • #8 7245378
    marian_44
    Rate: 58
    Hello, I have a problem with the central lock - it stopped working overnight. I have an Opel Corse C which of these fuses is responsible for the central locking. Thank you in advance for your answer. Regards
  • #9 7920838
  • #11 10249973
    kristo01
    Rate: 10
    Hello everyone
    In my wife's Corsa C, the display showing the meter reading does not work.
    Can someone help me pinpoint the problem?
    Thank you in advance and best regards,
    Christopher
  • #12 12771559
    daroviper
    "In my wife's Corsa C the display showing the meter reading is not working.
    Can someone help me pinpoint the problem? "
    Your light bulb under the meter is blown. Just replace.
    If the speedometer didn't work, it would most likely be a wheel sensor
  • #13 12887951
    rafal k71
    Rate: 24
    I would like to know which of the fuses is from the candles in the c 1.7 di op.
    There is no indication of their operation on the board, whether the car is cold or warm.
    thanks for the answer .
  • #14 13175344
    Ticon
    Yesterday I replaced the lighting in the heating and blower panel in the CORSA C 1.7 Y17DTL. I took out the bulbs and pressed the leds. Unfortunately, it still does not light - it is certainly not a matter of inserting the light bulbs - I checked if they were polar by inserting alternately.
    In addition, it turned out that the clocks were backlit (the controls and the counter are working).
    1. What to check to find the cause of the bulbs not lighting up in the heating and blower panel?
    2. Why are the clocks not working? Could my fumbling with the above-mentioned light bulbs have an impact on this?
    3. Could some fuse have flown? How so, which one?
    I checked 16 and 25 - they are ok.
    Do you check fuses 11 and 17 for the BCM?
    According to the diagram, the heating bulbs are connected to the BMC, but I have not noticed that they are connected to the backlight of the clocks.
    I will be very grateful for your help in solving the problem.
  • #15 18245402
    Karolina256
    Rate: 15
    does this fuse diagram fit the Corsa C 1.0 2001?
  • Blower motor works, likely lost supply voltage
    #16 19140846
    Kula_Jastrzebie
    Rate: 26
    Hey, I'm looking for some kind of wiring diagram from Corsa C. Engine is 1.0 and year 2002. Cab blower doesn't work. I checked the fuse and it's ok, I connected the blower briefly right from the battery and it works. Like a resistor, but then it should only work in 4th gear, the others should not. All 4 gears do not work for my son, so I have a dilemma where to lose all the tension. If someone has a pattern, I would be grateful.
  • #17 21738709
    Bensonm
    >>7920838
    • opel-17dti-y17dt ECM diesel control unit wiring (2).pdf (558.34 KB) You must be logged in to download this attachment.
The discussion concerns locating a wiring diagram or fuse assignment list for Opel Corsa C, including fuse socket numbers and their functions. Several replies mention the need for more vehicle data, the presence of a second fuse/relay box in the engine compartment, and the BCM (Body Control Module) with relays for signals, indicators, headlights, and central locking. Specific fuse-related issues are discussed, including fuse 25 for the clutch switch and brake sensor, central locking faults, extra engine-compartment fuses on the 1.7 DTi version, dashboard illumination problems, and blower fan wiring/resistor troubleshooting. A PDF fuse diagram link is also shared.
