NC+ Decoder Replacement Issue: Finding Compatible Set-Top Box for Dual-house Setup
matheo99 8976 13
  • #1 17168417
    matheo99
    I have two NC + decoders, one for rent, the other with two cameleon cards. I must admit that as part of one subscription I have TV in two houses (in different places). In December one of the set-top boxes broke down, so I went to the point for a fee they exchanged, but for rent, it is important that they changed. Now my second decoder breaks down and I wanted to do the same again, but they don't want to replace it with a new one. They will exchange, but order to return the cards and give multiroom for several TV, but it will work only in one house, and this is not what he wants. Hence my question, what decoder can I buy on the free market to work with this card? I searched half the internet and nothing, I even bought a pre-paid decoder from nc + television and it doesn't work.
  • #2 17168452
    matheo99
    I have one. It spreads out that this black decoder is cut on HD channels and I wanted some other, better one. Most black and white
    • NC+ Decoder Replacement Issue: Finding Compatible Set-Top Box for Dual-house Setup BC508025-6996-4BDA-A3BF-0262E9210D93.png (130.7 KB) You must be logged in to download this attachment.
  • #3 17168493
  • #4 17168507
    matheo99
    Will this work for me?
    Moderated By simhak:
    Do not place links to short-term sources that expire quickly.
  • #5 17168520
  • #6 17168554
    matheo99
    Is this an option not to throw money away and the decoder will work?
  • #7 17168601
    geco
    Help: 69
    Rate: 175
    Or maybe first check the antenna is it properly set up and not immediately blame the decoder how is the problem with the reception of HD channels? This can be affected by an old cable, a damaged converter, an incorrectly positioned antenna and obstacles such as trees.
  • #8 17168606
    matheo99
    Connecting this black and white decoder everything flashes without problems, also the problem only on the decoder side. In the previous one there was the same problem.
    The only question is whether the decoder from the link will work or any other that I can buy
  • #9 17168623
  • #10 17168952
    matheo99
    Aston module i.e.
    So you say that I can take it to another point and they should easily exchange / rent a decoder for me? Because, as I wrote where I was, unfortunately they did not want to.
  • #11 17169194
  • #12 17169336
    matheo99
    Now the main broke. Answer I got a break in the salon that I would not exchange the decoder only with a card.
    What is the chance of buying this black and white (the seller claims he went to April 8) that it will work for me? If it has the latest software, will it go by inserting my card?
  • #13 17169363
  • #14 17169372
    matheo99
    Those that I have walked trouble-free for 8 years also I hope that they will also be trouble-free, and after so many years something will come up again
✨ The discussion revolves around the challenges faced by a user with two NC+ decoders in a dual-house setup. One decoder has malfunctioned, and the user is seeking a compatible replacement that can work with their existing Cameleon cards. The user expresses frustration with the operator's refusal to replace the faulty decoder without returning the cards and switching to a multiroom setup, which would only function in one location. Various responses highlight the importance of using operator-approved decoders, the potential issues with non-compliant devices, and the necessity of ensuring proper antenna setup. Users discuss the reliability of older decoders and the possibility of acquiring a black and white decoder that may still function with the user's card if it has the latest software.
TL;DR: For NC+ Cameleon cards, use operator decoders only. In one real case, 1 of 2 boxes was swapped without card return; "The operator protects himself." Third‑party boxes and ASTON CAMs may be disabled. [Elektroda, Anonymous, post #17168623]
Why it matters: This FAQ helps NC+/Canal+ Poland users pick a working replacement box, avoid wasted purchases, and understand multiroom limits.
What decoder can I buy that works with NC+ Cameleon cards?
Use NC+/Canal+ operator decoders only. Community experts warn that third‑party set‑top boxes will stop working with these cards. As one put it: "Operator decoder ONLY." Buying non-operator gear or CAMs risks sudden loss of service after updates. [Elektroda, Anonymous, post #17168493]
Will a used operator "black/white" decoder that was active until April 8 work with my card?
Yes, if it was recently active and runs current software, it should start with your card. One expert summarized it simply: "It will work. But the warranty for the first damage." Verify return rights in case the unit fails soon after purchase. [Elektroda, Anonymous, post #17169363]
What should I ask a seller before buying a used NC+ box?
Request a written “guarantee to start” and evidence the box was connected recently. Units stored offline can struggle to acquire software when first powered. If the seller refuses, consider a different unit. This reduces the risk of paying for unusable hardware. [Elektroda, Anonymous, post #17168520]
My black decoder cuts on HD channels. Is it a software fault?
Yes. Those symptoms match a decoder software problem, not necessarily a signal issue. An expert noted: "Normal. The decoder has a software problem." Arrange an operator swap if resets do not help. [Elektroda, Anonymous, post #17168493]
Could my dish or cabling be the reason HD channels drop?
Yes. Check dish alignment, cable condition, and the LNB for faults. Look for obstacles like trees that attenuate signal. Replace damaged coax and re-point the dish if needed. This prevents misdiagnosing reception issues as decoder failures. [Elektroda, geco, post #17168601]
Why didn’t a prepaid NC+ decoder work with my subscription card?
In the thread, a prepaid NC+ decoder did not work with the user’s subscription card. That experience supports choosing operator decoders matched to your contract. Avoid assumptions that any NC+ branded box will accept your card. [Elektroda, matheo99, post #17168417]
Will the operator replace only the decoder without demanding my card?
Reports vary by point. One installer swapped a faulty unit (one of two on the account) without asking for card return. If a salon refuses, visit another point or ask for the refusal in writing. Policies can differ in practice. [Elektroda, Anonymous, post #17168623]
Can I run Multiroom or two decoders in two houses on one subscription?
The salon explicitly offered Multiroom for several TVs, but only within one house. Two-house operation falls outside what they provide via official Multiroom. Expect restrictions when trying to use one subscription across locations. [Elektroda, matheo99, post #17168417]
Do ASTON CI modules work with NC+ cards today?
They are not reliable going forward. As warned in the thread, "ASTON access modules will also stop working." Use operator decoders to avoid future deactivations after operator changes. [Elektroda, Anonymous, post #17168623]
How do I attempt a software update on a stubborn NC+ box?
Try this:
  1. Connect the box to the dish and power it for a long, uninterrupted session.
  2. Perform a factory reset from the menu and restart.
  3. Leave it tuned to a main transponder while it seeks updates. Note: "even a hard reset did not let the decoder download the software" in some cases, requiring replacement. [Elektroda, Anonymous, post #17168623]
Is a decoder that sat offline for months risky?
Yes. Boxes left unconnected to the antenna may fail to acquire software on first start. Buy only with a seller “start-up guarantee” or the right to return if it cannot activate. [Elektroda, Anonymous, post #17168520]
How can I quickly confirm the box is the problem, not the dish?
Connect a known-good operator decoder to the same dish and cabling. If HD channels work fine on that unit, the original decoder is at fault. This A/B test isolates receiver issues from installation problems. [Elektroda, matheo99, post #17168606]
How reliable are operator decoders over years?
User reports vary. One user noted 8 years of trouble-free operation. Longevity depends on hardware condition and evolving software. Even long-lived boxes can fail later. [Elektroda, matheo99, post #17169372]
Does it matter which unit failed (main or additional) for replacement?
Yes. A responder asked whether the main or additional unit failed, calling it important. Replacement handling can differ. If refused, ask for the reason in writing to escalate properly. [Elektroda, Anonymous, post #17169194]
