Evaporation - Decoder Evaporation: Pairing NC+ Card with Another Decoder, Serial Numbers & Tips
-vinci- 5490 6
  • #1 17053577
    -vinci-
    Does anyone know how to pair a card e.g. nc + already assigned to another decoder? Probably this is done so that the card number has been assigned a serial number of the decoder - the card reads this number and compares it with its own. And if you put the same number in the batch in another decoder, it might work? I have a better decoder than what they give and I would like to use it but what if the card does not work in it.
  • #2 17053633
    andpol 33
    Help: 513
    Rate: 1146
    Forget it. If it were that simple, burly heads would already do it.
  • #3 17053654
    -vinci-
    I can't believe nobody has done it yet. And if you did this: suppose I have a decoder paired with the card. If you get the same set-top box of the same model and transfer the whole load from the paired to it, it should work.
  • #4 17053692
    andpol 33
    Help: 513
    Rate: 1146
    Try, maybe you'll be the first.
  • #5 17053788
    -vinci-
    Just a little senseless, for what purpose? - you can only save a few cents this way. Buy a new card with a decoder paired, then buy a used identical decoder for a penny and throw in the charge from the new one, and sell the new one as a new one for a higher price. But there will be pennies, maybe PLN 50 will be saved in this way.
    He does this because he wants me to receive a discovery channel on my own decoder, not paired with the card. Apparently, nc + cards with the start hd package work on everyone, they are not paired, but there is no discovery channel in this package. Is there any card that works without pairing and has a discovery channel in the package?
    andpol 33
    Help: 513
    Rate: 1146
    Discovery is on offer Smart HD link . The card is not paired.
  • #7 17053874
    -vinci-
    Thanks a lot . I buy it.
The discussion revolves around the challenges of pairing an NC+ card, which is already assigned to a decoder, with another decoder. Users speculate on the possibility of transferring the card's pairing to a new decoder of the same model, suggesting that if the serial numbers match, it might work. However, skepticism exists regarding the practicality and benefits of such an endeavor, as it may only yield minimal savings. The conversation also touches on the availability of a Smart HD package that includes the Discovery channel without the need for pairing, which some users find appealing.
