[Solved] Windows 7 Activation Issue: No Valid Phone Number (008001211654) - Updated Contact Info Needed
młody641 12996 3
  • #1 17170360
    młody641
    Level 4  
    Rate: 89
    I have a problem because I can not activate Windows 7 via the Internet. I wanted to activate the system over the phone, but after dialing the telephone number given by the system (008001211654) it reports as "The number provided does not exist".
    Does anyone know on the forum what is the current phone number for activating windows?
  • #3 17170403
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    The number exists, it is an international toll-free number. You either have a problem with over-restrictive outgoing calls settings that you set up or your telephone operator "gives you bodies".
  • #4 17170528
    młody641
    Level 4  
    Rate: 89
    The problem solved itself. The system was successfully activated.
