[Solved] Windows 7 Activation Issue: Online & Phone Activation Fails - Solutions?
PRL 30210 10
How can I activate Windows 7 when online activation fails and phone activation no longer works?
Use Microsoft’s telephone activation number 00 800 12 11 654; that number was confirmed to work, while 800 121 1654 and 22 594 19 99 were reported as inactive or no longer offering phone activation [#19519331] [#19519325] [#19522589] One user also noted that the activation window may show an 800-style number, but activation worked only after dialing it with the 00/00800 prefix [#19519413]
  • #1 19519309
    PRL
    Help: 953
    Rate: 905
    I have a laptop in which I installed Windows 7 with a sticker key.
    Unfortunately, it does not want to activate online. Phone activation no longer works.
    What can I do?
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Since it works for XP, it must work for W7: https://www.youtube.com/watch?v=wIe4SfENT1s I assume you are calling the right number? 800 121 1654, or check the one from the UK -> 800 018 8354 or another country.
  • #3 19519325
    PRL
    Help: 953
    Rate: 905
    800 121 1654 is not active, and 22 594 19 99 (probably this one) no longer gives the possibility of activation by phone - they send a message that I should look for help at help.microsoft.com.
  • #5 19519349
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    Check here: link
  • #6 19519413
    PRL
    Help: 953
    Rate: 905
    This is how a person does not submit to the messages.
    I called 22... and there really is no activation.
    On the 800, I did not choose two zeros at the beginning out of habit.
    It turned out that activation works on 00800.
  • #7 19519416
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    As you can see "you have to be able to click" ;-)
  • #9 19519755
    Kolobos
    IT specialist
    Help: 17171
    Rate: 10455
    On the MS website, the numbers are with zeros and that's enough, and he asks that you had a number from it.
  • #10 19519827
    PRL
    Help: 953
    Rate: 905
    I always called 22.
    800 is given in the activation window.
    There's no point in continuing this issue, it's resolved.
The discussion revolves around issues with activating Windows 7 using a sticker key, where both online and phone activation methods have failed. Users share various phone numbers for activation, with the correct number being 00 800 12 11 654, which allows for activation without consent for Windows 10. Some users experienced difficulties due to not dialing the correct format, specifically missing the initial zeros. The conversation highlights the importance of using the correct activation number provided by Microsoft to resolve activation issues effectively.
