Lenovo Ideapad 320-15IKB: Windows 8.1 Pro x64 - Touchpad, WiFi Issues & Missing Drivers (81BG)
happy_kocurrro 12099 9
How can I find and install the missing touchpad, Wi‑Fi, and ACPI drivers for a Lenovo Ideapad 320-15IKB (81BG) running Windows 8.1 Pro x64?
Use the hardware IDs to match the missing devices and install the drivers manually; the thread notes that Windows 10 packages may not install correctly on Windows 8.1 [#17171303][#17171359][#17171817] For `PCI\VEN_8086&DEV_9D60&SUBSYS_384417AA&REV_21`, install the driver manually from the linked Elektroda guide [#17173312] For `ACPI\VEN_VPC&DEV_2004`, try the `wwed010e` and `wwed020e` drivers in sequence, although the poster reported that both installers exited immediately and the problem remained after reboot [#17173312][#17182953] The touchpad later appeared in Device Manager as a `HID compliant mouse` located at an `I2C HID device`, with no Synaptics or Elan entries in Mouse Properties, so it may be working through a generic HID path rather than a vendor touchpad package [#17182953] DriverMSG also provided several Lenovo and Intel download links, including an Intel INF package, to cover the remaining chipset/controller devices [#17171359]
  • #1 17171250
    happy_kocurrro
    Rate: 23
    I installed on a clean laptop (Lenovo Ideapad 320-15IKB), windows 8.1 Professional x64 started installing problems with the touchpad, its cursor was invisible, and after installation the touchpad still does not respond and the laptop does not search for WiFi. In the control panel in Network connections I only have: Ethernet and Bluetooth network connection. I checked in the device manager for drivers and indeed in "Other devices" there are several devices with a yellow exclamation mark, and in the "Drivers for this device are not installed (Code 28)" properties. I tried to download them from the Lenovo website, but all the drivers are already there under Windows 10, so I would like to ask you for help in finding the missing drivers.
    Windows 8.1 Professional x64
    Motherboard model: 81BG
    Hardware IDs:
    System management bus controller:
    PCI \ VEN_8086 & DEV_9D23 & SUBSYS_384C17AA & REV_21
    PCI memory controller:
    PCI \ VEN_8086 & DEV_9D21 & SUBSYS_385117AA & REV_21
    PCI controller for data collection and signal processing:
    PCI \ VEN_8086 & DEV_9D31 & SUBSYS_384017AA & REV_21
    PCI \ VEN_8086 & DEV_9D60 & SUBSYS_384417AA & REV_21
    PCI Simple Communications Controller:
    PCI \ VEN_8086 & DEV_9D3A & SUBSYS_384E17AA & REV_21
    Network controller:
    PCI \ VEN_168C & DEV_0042 & REV_31 & SUBSYS_090117AA
    Unknown device:
    ACPI \ VEN_INT & DEV_0E0C
    Unknown device:
    ACPI \ VEN_VPC & DEV_2004
  • #4 17171817
    9396264
    Rate: 8
    and Windows 10 drivers are sometimes not compatible with 8.1?
  • #5 17171836
    Pedros050
    Help: 2471
    Rate: 3926
    And what about those he gave you @DriverMSG ?
  • #6 17172242
    happy_kocurrro
    Rate: 23
    Almost all drivers are installed, two are still missing, and this driver from the touchpad, unfortunately, does not want to install, an error pops up.
    To tell you the truth, I didn't check if they were compatible with each other before, I have now downloaded the driver for windows 10 from Lenovo, also an error occurred
  • #7 17172244
    DriverMSG
    Help: 3984
    Rate: 4882
    Which are missing? Provide identifiers.
  • #8 17172352
    happy_kocurrro
    Rate: 23
    Ooo, I was in a hurry and forgot to give it, I'm not at home right now, but from what I remember it:
    Unknown device:
  • #9 17173312
    DriverMSG
    Help: 3984
    Rate: 4882
    Install this manually:
    https://www.elektroda.pl/rtvforum/topic2324818.html#11042475 Intel-10.1...12.rar (152.64 kB)You must be logged in to download this attachment.
    Test in sequence:
    atac01..exe (1.45 MB)You must be logged in to download this attachment. wwed01..exe (4.58 MB)You must be logged in to download this attachment. wwed02..exe (4.58 MB)You must be logged in to download this attachment.
  • #10 17182953
    happy_kocurrro
    Rate: 23
    Forgive me for not answering for so long, but I didn't have much to say, during these few days I tried to cope with the drivers myself, but at that time new problems appeared with them. Unfortunately, I no longer have the strength, patience or ideas on how to solve them. The situation looks like this:
    1. I'm still getting tired of this unfortunate driver
    Unknown device:
    @DriverMSG, I installed everything you gave me above, the first one is installed, but the next two are unlikely, after installing the two (wwed010e and wwed020e) the cmd window appears for a second, then it disappears, and after the restart there are no changes in the laptop.
    I found a few other drivers at http://www.driveridentifier.com, but they don't feel like installing:
    However, when he manually installs them, something like this pops up:
    2. Touchpad unchanged, still the same error when installing:
    But one day I accidentally touched the tile and was surprised that the cursor moved. Since then the disc, right and left buttons work, but scroll unfortunately not. In the device manager "HID compliant mouse", in the properties:
    Location to I2C HID device. Would it be a touchpad?
    In Control Panel, mouse properties have neither Synaptic nor Elan.
    Lenovo Ideapad 320-15IKB: Windows 8.1 Pro x64 - Touchpad, WiFi Issues & Missing Drivers (81BG) Lenovo Ideapad 320-15IKB: Windows 8.1 Pro x64 - Touchpad, WiFi Issues & Missing Drivers (81BG)
    A strange situation. It looks like there is no touchpad, yet it IS ALWAYS fully working as it should, but there is only a mouse connected to the laptop, which is not really there.
    3. In addition, the screen brightness adjustment does not work. The slider in the Control Panel moves but the screen does not respond.
    I'm not sure, but shouldn't the "Generic PnP monitor" instead of "Standard PnP monitor"?
    4. And the wonder of yesterday, so I combined with the drivers that until after a restart of the laptop something new appeared in the device manager:
    5. I don't know if it can be related to something, but I will also mention it. Not all keyboard shortcuts work as you need, e.g. the F2 key should allow you to change the file name, but just clicking it regulates
    speaker, while the Fn + F2 key combination changes name. In the case of F11 and F12, just pressing them displays the brightness adjustment bar (but it is known that the screen does not react), although it is Fn + F11 / F12 that should work like that.
The discussion revolves around issues faced by a user after installing Windows 8.1 Pro x64 on a Lenovo Ideapad 320-15IKB (Motherboard model: 81BG). The user reports problems with the touchpad, including an invisible cursor and unresponsiveness, as well as WiFi connectivity issues, with only Ethernet and Bluetooth connections visible in the Network settings. The Device Manager shows several devices with missing drivers indicated by yellow exclamation marks. Various users provide links to potential driver downloads, including those from Lenovo and other sources, while also noting that Windows 10 drivers may not be compatible with Windows 8.1. The user continues to struggle with installing the correct drivers, particularly for the touchpad and an unknown device identified by its hardware ID. Follow-up messages indicate ongoing difficulties and attempts to resolve the driver installation errors.
