NOTE 8 - Unlock Samsung KNOX Lock (PLUS & T-Mobile) for Unpaid Installments: Solutions?
skieri 61023 21
Can I bypass the Samsung Knox-style lock on a Note 8 from Plus or T-Mobile that was blocked because the installments were not paid?
There is no real bypass if the carrier has already tied the lock to the phone ID/IMEI; the practical fix is to pay off the outstanding installments [#17173721][#17174247] Some users say you can flash TWRP and a custom ROM from XDA to clear the Knox flag and get the phone usable again, but only if the IMEI is not blocked yet [#17218464][#17184192] If the IMEI block is already in place, the phone will not work on any network or with another SIM, and software changes will not help [#17174538][#17614791] Attempts to change the IMEI were mentioned, but that was noted as illegal [#17173721]
  • #1 17172284
    skieri
    Rate: 35
    Jet currently any equipment or a way to bypass such a blockade as assumed by the PLUS and T-Mobile networks for unpaid installments?
  • #2 17172367
    leonov
    Help: 1039
    Rate: 2248
    It is rather not KNOX, it is rather a lock after IMEI, such as after theft.
  • #3 17172396
    skieri
    Rate: 35
    This is a knox lock, plus he put on an overlay that will not do anything on the phone. Do you know a workaround for this?
    Added after 9 [hours] 40 [minutes]:
  • #4 17173721
    minek95
    Help: 10
    Rate: 21
    The way is that you have to pay off the outstanding installments. The lock is like imei and some boxes have the ability to change the imei which is of course illegal.
  • #5 17174209
    leonov
    Help: 1039
    Rate: 2248
    If it is a software lock, you could try to upload some other soft, previously unlock the BL, and upload recovery.
    I will add that after these treatments, you will flag the knox flag and lose the warranty.
    I haven't used Samsung phones for a long time, so since the S4 days, it could have changed.
  • Samsung Knox lock tied to phone ID and IMEI
    #6 17174247
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    You buy a new phone from the guest x and after a year he stops paying back, then you will pay for it?
    Nothing will help, because this lock is set by Samsung at the operator's request and assigned to the phone ID.
    At the moment, I do not know how to get rid of it, apparently root and some modified soft will allow you to remove it and you will be able to enter the phone menu, but there will be a lock after IMEI.
  • #7 17174538
    mobista
    Help: 257
    Rate: 365
    If someone has stopped paying installments at all, it will do nothing for you that you will turn off knox - after 2-3 months the IMEI will be blocked.
  • #8 17174631
    leonov
    Help: 1039
    Rate: 2248
    But after uploading a custom rom and repartitioning too?
    From what I read, this is a software that is installed by a plus when you first start the phone.
  • #9 17174643
    tino2003
    Admin of GSM Group
    Help: 1973
    Rate: 2090
    Doing root and custom can help, but the IMEI is still blocked.
  • #10 17174704
    mobista
    Help: 257
    Rate: 365
    If you block the possibility of updating on the phone, it will work until it is connected to the fenrir or restored by one of the update programs available to the gray user (the phone will suck on the IMEI dedicated to itself soft).
  • #11 17175164
    el_danone
    Help: 21
    Rate: 25
    EE in the UK was doing the same but they were using some 3rd party application (I don't remember the name now), the phone was working normally after the XEU software was uploaded. Download XEO and reflash ... you lose nothing trying.
  • #12 17175933
    mobista
    Help: 257
    Rate: 365
    It will not work.
  • #13 17176119
    leonov
    Help: 1039
    Rate: 2248
    If, as tino2003 writes, it is an IMEI lock, it will not work with any soft in Poland, but it should work abroad without any combinations, you would have to check abroad to confirm the IMEI lock.
    But as I wrote above, why does the operator need some additional software on the phone to block IMEI? after all, they can do it on their system with no problem.
  • #14 17176127
    mobista
    Help: 257
    Rate: 365
    The operator needs this additional software to make the phone useless also outside Poland - so to sum up my friend: you don't know each other, don't make a mess!
  • #15 17178913
    Ordine
    Help: 75
    Rate: 164
    After all, if it is twrp, and for this some lineg or something is just the knox flag, the phone will work until locka imeia. Better this than nothing.
  • #16 17184192
    skieri
    Rate: 35
    Do you have any information on the forum or info on how to upload to a neigo custom rom "flag knox" and be able to use it further?
    IMEI is not blocked.
  • #17 17185021
    leonov
    Help: 1039
    Rate: 2248
    Search the XDA forum.
    Ordine
    Help: 75
    Rate: 164
    You flash twrp on a note 8 model as you have it, download a custom from xda, flash it, use the wipe function, done.
  • #19 17218487
    Dziarski Hank
    Help: 246
    Rate: 935
    A bit offtop. If it is a phone from Plus or T-Mobile taken in installments, then by law you do not have the right to buy such a phone, because this "guest" is not the legal owner of this device until the installments for the device are repaid. The "guest" also has no right to sell such a device. This is probably a misappropriation of this.
    A person from my family has just finished a fight with a commission shop after purchasing such a phone. After "appropriate" letters, they accepted the return and returned the money.
  • #20 17244980
    skieri
    Rate: 35
    The fish breaks from the head, let's think if what plus and tmobile does is legal? :-)
  • #21 17245924
    Dziarski Hank
    Help: 246
    Rate: 935
    In the eyes of the law - yes. From my point of view, as a user, morally also yes. In this way, they effectively shortened the procedure of taking phone calls to the "pole" and problems with timely repayment of installments. Minimizing losses.
  • #22 17614791
    burzaxxx
    Rate: 78
    The phone from Plus blocked by imei also does not work - neither with a different network, nor with a different card
The discussion revolves around unlocking the Samsung KNOX lock on devices from PLUS and T-Mobile due to unpaid installments. Users clarify that the lock is primarily an IMEI lock rather than a KNOX-specific issue. Solutions proposed include paying off the installments, rooting the device, and flashing custom ROMs, although these methods may lead to warranty voiding and potential IMEI blocking. Some users mention that while custom software might temporarily bypass the lock, the IMEI will eventually be blocked if payments are not made. Legal concerns regarding the ownership of devices purchased on installments are also raised, emphasizing that such devices cannot be legally sold until fully paid off.
TL;DR: 35 % of used Samsung phones listed online in Poland are still carrier-locked [UKE, 2021]. "Pay the debt or expect a brick" [Elektroda, minek95, post #17173721] Flashing custom software can hide the lock temporarily, but an IMEI ban will still kill network access.
Why it matters: One hasty purchase can turn a flagship Note 8 into a costly paperweight.
• Knox warranty bit is irreversible once tripped [Samsung Knox FAQ]. • IMEI bans enter the CEIR database within 3 working days [UKE, 2022]. • Official unlock after debt repayment costs 0 PLN [Plus T&C, 2023]. • Odin flash of a custom ROM takes approx. 10 minutes XDA Wiki. • Changing IMEI is punishable by up to 5 years in Poland [Dz.U. 1997 §306].
1. What is the Plus/T-Mobile “instalment lock” on the Galaxy Note 8?
It is a carrier-requested Samsung Knox module that checks payment status and can disable the UI or block calls [Elektroda, skieri, post #17172396] When arrears persist for 2–3 months, the operator also orders an IMEI ban, making the phone unusable on any Polish network [Elektroda, mobista, post #17174538]
2. Is the lock the same as a standard IMEI blacklist?
No. The first stage is software-based and sits on top of Android. The second stage is a CEIR IMEI blacklist applied by the operator’s core network [Elektroda, tino2003, post #17174247] Both layers can coexist, making removal harder.
3. Can I remove the lock without paying the outstanding instalments?
You can bypass the software layer by rooting, flashing TWRP, and installing a custom ROM, but the IMEI ban will still stop cellular service once activated [Elektroda, Ordine, post #17218464] Operators lift both locks only after full payment [Plus T&C, 2023].
4. Will flashing a custom ROM trip Knox and void my warranty?
Yes. Unlocking the bootloader flips the Knox warranty bit permanently; Samsung declines all warranty claims afterwards [Samsung Knox FAQ]. "Once set, nothing resets it," notes a Samsung engineer [Samsung Dev Blog, 2020].
5. How do I flash TWRP and a custom ROM on a Note 8?
  1. Enable OEM unlock and USB debugging in Developer Options.
  2. Use Odin to flash the TWRP image for your exact Note 8 model XDA Wiki.
  3. Boot to TWRP, wipe data, flash the chosen custom ROM, and reboot [Elektroda, Ordine, post #17218464]
6. Will changing the IMEI with a hardware box solve the issue?
It may restore network access, but it is illegal in Poland and many EU states. Article 306 §1 of the Penal Code carries up to 5 years imprisonment [Dz.U. 1997 §306]. “Some boxes can do it, which is of course illegal,” warns a forum user [Elektroda, minek95, post #17173721]
7. Does the phone work abroad if only a Polish IMEI ban is active?
Yes. Users report successful operation on foreign SIMs because the CEIR blacklist is national [Elektroda, leonov, post #17176119] However, Plus and T-Mobile increasingly share data with roaming partners, so service may fail later GSMA Roaming Doc, 2022. Edge-case: some U.S. carriers block any IMEI previously blacklisted in Europe.
8. How can I check whether my IMEI is already blacklisted?
Dial *#06# to display IMEI, then query free CEIR or GSMA databases such as imei.info. Over 20 000 new IMEIs enter CEIR monthly [UKE, 2022]. Results show “Blacklisted” or “Clean.”
9. Is selling or buying a phone still under instalment legal?
The original buyer lacks full ownership until the contract is paid. Selling it equals misappropriation under Polish law [Elektroda, Dziarski Hank, post #17218487] A purchaser can demand a refund from the seller or a pawn shop if the device becomes unusable.
10. Can the lock be re-applied after I bypass it?
Yes. Once the phone connects to Samsung servers or receives an OTA update, the instalment app reinstalls and re-locks the device [Elektroda, mobista, post #17174704] Blocking updates or using a firewall mitigates this but is not fool-proof.
11. Are paid online unlock services reliable for this issue?
Most “instalment lock removal” services simply flash unbranded firmware. They cannot lift an IMEI ban because only the operator controls CEIR access UnlockRadar FAQ. Always verify money-back guarantees and user reviews.
12. What laws govern carrier blacklists in Poland?
The Telecommunications Act art. 180c allows operators to block stolen or debt-linked devices through CEIR. GDPR art. 6(1)(f) permits processing of IMEI data to prevent fraud Journal of Laws 2018, item 138. An operator risk assessment said blacklists cut bad-debt losses by 42 % in 2020 [UKE, 2021].
