Samsung Galaxy S8 G950F - No option "OEM unlock" "unlock O
pawelhd2003 6330 4
  • #1 17373115
    pawelhd2003
    Rate: 23
    In Samsung S8 Exynos, there is no option to disable / enable OEM unlock in the developer options.
    I want to do root.
    Is anyone smart enough to say what the reason is and maybe he has met such a case?
    Samsung branded PlusGSM
  • Possible Knox or carrier lock blocking OEM unlock
    #3 17373334
    pawelhd2003
    Rate: 23
    I have already tried this solution, it did not help.
    I wonder if this could be related to Knox and the phone purchased in installments in Plus?
    Plus, in theory, it can remotely lock the phone in the event of default installments, and maybe at this level a lock appears.
    I don't know whether to risk rooting. If this option is not available, the question is what is set in the phone by default.
  • #4 17373621
    kamil2114
    Rate: 12
    Or just plus has blocked this option in your software. Upload clean, non-branded
  • #5 17644512
    michu475
    Rate: 9
    If uploading the software does not help, you can also unlock it after uploading the combinator and then a new software.
