Seeking Program to Unblock PLUS and TMOBILE Network Operator Bans on Phones
tomi0022 19692 6
  • #1 18550741
    tomi0022
    Rate: 20
    Hello. Does anyone have a program to remove network operator bans??
    Phones are blocked by PLUS and TMOBILE and I would like to unlock them.
    It's a proven program, a way to bypass it.
  • #2 18550914
    staś pytalski
    Help: 760
    Rate: 1436
    Are you talking about simlock or something else? What are the phones?
  • #3 18551010
    arti123
    Help: 377
    Rate: 96
    Probably installment and unpaid calls. Block phones securely on IMEI. Legally insurmountable.
  • #4 18551108
    tomi0022
    Rate: 20
    Operator blockade, i.e. phones blocked for non-payment of installments.
    There are people who go through it, but they don't want to tell you how they do it
  • #5 18551507
    staś pytalski
    Help: 760
    Rate: 1436
    When you make money on something, you don't brag about it left and right. It remains to look for a solution or pay.
  • #6 18551546
    leonov
    Help: 1039
    Rate: 2248
    They do it halfway, they will run it for you, but without the ability to make calls, you would have to change the imei for it to work, and it's illegal, the phone can be used abroad.
  • #7 18552589
    iza2217
    Help: 16
    Rate: 34
    Therefore, before buying the opportunity, you did not check whether the installments are paid, you would save on tears
The discussion revolves around seeking a program to unlock phones that have been blocked by network operators PLUS and TMOBILE due to non-payment of installments. Users clarify that the blocks are typically enforced on IMEI numbers and suggest that while some individuals may have methods to bypass these restrictions, they are often reluctant to share their solutions. There are warnings about the legality of certain methods, such as changing the IMEI, which could allow the phone to function abroad but is illegal. The conversation highlights the importance of verifying installment payments before purchasing devices to avoid such issues.
