Child's 6V Battery Car Upgrade: Safe 12V Battery & 16000 RPM Motor Compatibility?
jacekFF 8664 5
  • #1 17181463
    jacekFF
    Rate: 9
    Hello, I have a car for a child's battery with one engine and a 6v battery, I would like to speed it up a little because it travels at a speed of 3km / h. I have one question about the battery and the motor because the engine has a 12v 16000 rpm mark
    And the battery is 6 volts or is it possible to install a 12v battery without any damage to the system or is it just the engine that is more powerful?
    • Child's 6V Battery Car Upgrade: Safe 12V Battery & 16000 RPM Motor Compatibility? 20180422_095911.jpg (579.41 KB) You must be logged in to download this attachment.
  • #3 17181633
    jacekFF
    Rate: 9
    The control module has 6 volts, you can speed up such a car or it's normal speed in all Child's 6V Battery Car Upgrade: Safe 12V Battery & 16000 RPM Motor Compatibility? Child's 6V Battery Car Upgrade: Safe 12V Battery & 16000 RPM Motor Compatibility?
  • #4 17181689
    wojtek 9007
    Level 40  
    Help: 711
    Rate: 844
    Hello - the control module is on 6V, the battery is also 6V - probably at
    Conversion of a 12V motor into a 6V car will go sooner (it could be connected
    second battery in parallel) and one more engine.
    Added after 50 [seconds]:
    6V motors
    https://www.zabawkiph.pl/czesci-do-samochodow-silnik-6V-13000RPM.html
    Added after 41 [seconds]:
    https://www.zabawkiph.pl/czesci-do-samochodow-silnik-6V-14000RPM.html
  • #5 17182990
    wojat
    Hello, I will follow the topic, namely, I replaced the battery with a 6v7ah (2 pcs) in series with 12v 7.5ah (2 pcs) in parallel and the power supply was old :) How long do I have to charge them to the max?
    • Child's 6V Battery Car Upgrade: Safe 12V Battery & 16000 RPM Motor Compatibility? IMG_20180416_182106.jpg (1.16 MB) You must be logged in to download this attachment.
