[Solved] Drone Overmax X Bee 2.5 Loses Strength to Float: Motor Replacement & Troubleshooting Tips
SzkitekWLKP 17217 12
Why does my small brush-motor drone lose lift and suddenly drift after a crash and motor replacement?
The drone’s weak lift and sudden drift were caused by bad propellers: the replacement blades were flimsy and, at higher RPM, their imbalance made the drone veer left/back; fitting better propellers with a larger pitch improved hovering and solved the problem [#17187779] Before that, the thread recommended checking the battery voltage after charging and under load, because the pack was dropping quickly to about 3.4–3.6 V after a few minutes, which can keep the motors from reaching full RPM [#17182362][#17183504][#17184013] It was also suggested to test the motors and gearing under load, since a damaged motor or jammed gear can reduce thrust even if the drone seems to hover at low power [#17182362][#17184995] The remote trim and gyro mounting were also mentioned as things to verify, but in this case the core fault was the propellers [#17186529][#17187779]
  • #1 17182272
    SzkitekWLKP
    Hello forum users.
    My problem looks like this. One unfortunate day my drone flight ended in a fall on the grass. Overmax x bee 2.5 drone. The first symptoms are the lack of reaction of two brush motors. I ordered 4 engines and replaced all of them. After the whole operation I was glad to return to the place of flight and this is where the problem begins. The drone "works" but it has no strength to float, sometimes it will rise a little, sometimes it hangs in the air despite the stick for max, and sometimes even slowly falls down. Even when it floats, it feels that it is not the same drone. After many attempts at combining, I ordered a different (smaller) frame for larger brush motors and other batteries with a stronger maximum discharge current. The effect is the same. And here is the question, where can I still look for the reason ?? Could something burn on the drone's flight controller to match these symptoms? I would add that I did not notice any major problems with maintaining the drone's position in the air, it is far from ideal, but behaves like before a fault.
  • #2 17182362
    1 PAWEL
    Help: 674
    Rate: 1364
    Overmax x bee 2.5 brush motors,
    check power supply voltage after charging and under load,
    check if the electronics heat up.
    Check if the gearing is functional and not jamming during slow rotation of the propeller.
  • #3 17182689
    SzkitekWLKP
    I will check the power supply tomorrow, because I can't currently. The electronics do not heat up, holding it in my hand, running for a few moments, I could not feel the heat. Sprockets are functional, they all run smoothly. I noticed one more symptom .... as long as the stick is not set to the maximum tilt up, the drone in the room holds its position, but when I turn up rapidly, it suddenly escapes to the left / back.
  • #4 17182972
    1 PAWEL
    Help: 674
    Rate: 1364
    SzkitekWLKP wrote:
    but when I turn it up abruptly it suddenly runs left / back.
    This may indicate faulty engines or electronics.
    When you turn off the engines do they lose the same speed?
    Propeller engines probably not mistaken for the location?
  • #5 17183443
    SzkitekWLKP
    Propellers put in the right direction, engines according to revolutions as well. When cutting the rod, one propeller stops faster, unfortunately right / back, i.e. it does not affect the drift in the opposite direction, unless I'm wrong. Voltage on the cell looks as follows max 4.2V after a few minutes in the air in one position (if it succeeds) around 3.4V.
    I would add that the problem of floating was probably partly due to the propellers. After changing the propellers to larger ones with a larger pitch, the drone hovers better, but there is still a problem of sudden drift to one side with a vigorous increase in engine revolutions.
  • #6 17183504
    1 PAWEL
    Help: 674
    Rate: 1364
    Replace the battery, the voltage drops too quickly.
    SzkitekWLKP wrote:
    the propeller stops faster, unfortunately right / rear
    Everything is affected by a possible damaged engine or gearing.
  • #7 17183904
    SzkitekWLKP
    I know that many things can be the cause but as I described the drone maintains its position in place at a height of e.g. 1 meter. If any engine were shot it probably would always endure it ?? I might be wrong. The second thing is that he puts him to the left and the engine that stops faster is on the right. Voltage with a second battery similar 3.5 / 3.6V
  • #8 17184013
    1 PAWEL
    Help: 674
    Rate: 1364
    SzkitekWLKP wrote:
    If an engine were shot it would probably always bear it
    No, the engine does not reach its power / RPM under higher load.
    Weak batteries look for something branded to size and plug -
    LiPO Turnigy NanoTech 1S 750mAh 3.7V 35 / 70C pack (7307142724)
  • #9 17184573
    SzkitekWLKP
    Mr. Paweł, it's possible that the batteries are weak but it can happen with a charged cell and after a few minutes it will rise well where it already has a lower voltage. The same with engines, since sometimes it will rise well and sometimes it will stand it, should I understand that engines when they want to achieve their power and if they are in a bad mood then ??
  • #10 17184995
    1 PAWEL
    Help: 674
    Rate: 1364
    Mounted in x bee 2.5 brush motors commutator brushes are plates that overheat quickly,
    the easiest way is to check it under load with a propeller how much power they are consuming and what revolutions are obtained.
    Toothed gear resistances also affect engine performance.
    Perhaps that damaged electronics.
  • #11 17186174
    SzkitekWLKP
    I started to think since you keep writing about these engines. I did a simple test, I translated all the motors diagonally to the second position. The effect remained the same. Still bear left / back. Can this exclude engines ?? If electronics then where to look for the problem ?? THIS is a cheap model for which I do not want to buy additional parts.
  • #12 17186529
    tomek122
    Help: 33
    Rate: 234
    There should be a trimmer on the remote control. So set them so that the drone is stable.
    Expand photos and drone and pilot at all.
    If the electronics in the drone are crooked, then there can also be the same effect (there is a gyroscope on it). Anyway, you wrote that he fell. Check the electronics and set it up. And if it is correctly mounted, then drone pickup.
  • #13 17187779
    SzkitekWLKP
    I trimmed it more than once, I have drone over several dozen hours so basics such as trimming, calibrating and mounting engines and propellers in the right direction I have mastered. Regarding the gyroscope, I also know what it is used for and despite spinning the drone I am sure that the plate sits straight because it holds the position at a lower speed. The problem is solved. The propellers I bought were flimsy, definitely one. Apparently at higher revs, the drone felt a growing difference in poorly balanced or poorly shaped wings for the rest of the wings. For the future for others who encounter such or similar problems, try to start with the wings and not like me with the complete dismantling of the drone for the first part. Thank you all for your help and best regards. Topic is closed
✨ The discussion revolves around troubleshooting issues with the Overmax X Bee 2.5 drone following a crash. The user reports that after replacing the brush motors, the drone struggles to gain altitude and exhibits erratic behavior, such as drifting to one side during ascent. Various suggestions are made, including checking the power supply voltage, ensuring proper propeller orientation, and examining the condition of the battery and electronics. The user finds that larger propellers improve hovering stability but does not resolve the drift issue. Ultimately, the problem is identified as stemming from poorly balanced or damaged propellers, leading to the conclusion that propeller quality should be prioritized in troubleshooting similar issues.
TL;DR: Many X Bee 2.5 lift issues trace to weak 1S packs; a 750 mAh 35/70C upgrade helps, and “No, the engine does not reach its power/RPM under higher load.” Replace battery, inspect props, gearing, and brushes. [Elektroda, 1 PAWEL, post #17184013]
Why it matters: This helps Overmax X Bee 2.5 owners quickly restore lift and stability after crashes.
How do I fix an Overmax X Bee 2.5 that won’t lift after a crash?
Start with power and drag checks. Measure battery voltage after charge and under hover. Feel the electronics for unusual heat. Spin each prop slowly and feel for gear or shaft binding. Fix any mechanical resistance first. Replace tired cells next. These basics restore most lift losses on brushed quads. [Elektroda, 1 PAWEL, post #17182362]
Why does my quad dart left or back when I punch the throttle?
This points to a weak motor corner or electronics imbalance. Verify all props and motors are in the correct rotation and position. Cut throttle and watch whether each motor loses speed equally. Uneven spin-down suggests an issue on that arm. Correct orientation and replace the weak part. [Elektroda, 1 PAWEL, post #17182972]
What battery voltage drop is a red flag on this 1S drone?
Dropping from 4.2 V fresh to about 3.4 V within minutes of hover signals a weak pack. Expect reduced thrust and inconsistent lift. Replace the cell if sag repeats across flights. This sag degrades stability during aggressive throttle inputs. [Elektroda, SzkitekWLKP, post #17183443]
Should I replace the battery first or the motors?
Replace the battery first when you see rapid voltage drop. Weak cells cause immediate thrust loss and drifting on throttle. If the issue persists, inspect motors and gearboxes for damage or friction. Address power supply before swapping motors on brushed toys. [Elektroda, 1 PAWEL, post #17183504]
Which replacement battery spec improves punch on the X Bee 2.5?
Use a branded 1S 750 mAh with 35/70C rating, such as Turnigy Nano-Tech. Higher discharge cells hold voltage under load, restoring lift and throttle response. Match the size and connector to the airframe. This upgrade addresses weak-pack symptoms. [Elektroda, 1 PAWEL, post #17184013]
Can brushed motors work at hover but fail at high throttle?
Yes. Brushed motors can spin at low load yet sag at high load. As load rises, a worn motor may not reach required RPM. “No, the engine does not reach its power/RPM under higher load.” Replace the weak unit if tests confirm. [Elektroda, 1 PAWEL, post #17184013]
How do I quickly diagnose lift loss on this drone?
  1. Measure battery voltage freshly charged, then again while hovering.
  2. Run motors briefly and feel the board for unusual heat.
  3. Turn each prop slowly; fix any gear or shaft binding. “Check power supply voltage after charging and under load.” A multimeter and careful feel tests are enough. [Elektroda, 1 PAWEL, post #17182362]
Is swapping motors diagonally a valid test?
Yes. Swap motors across diagonals and retest. If the drift direction remains the same, motors are less likely the cause. Focus next on props, gearing, battery, or the control board. This isolates component faults without buying parts. [Elektroda, SzkitekWLKP, post #17186174]
Could a crooked flight controller or gyro cause aggressive drift?
Yes. A tilted board or misaligned gyro biases the controller, especially at high throttle. Ensure the electronics board mounts flat and secure. Use transmitter trims to stabilize hover only after confirming level mounting. Realign hardware before further tuning. [Elektroda, tomek122, post #17186529]
My drone hovers but still slides on throttle punches. What’s most likely?
Check propellers first. Flimsy or unbalanced props can lose shape at high RPM and unbalance thrust. Replace them as a set with stiffer, properly pitched props. Many drift-on-punch issues vanish after a prop swap. Balance matters more than diameter alone. [Elektroda, SzkitekWLKP, post #17187779]
How can I check brushed motor health under load without lab gear?
Run each motor with its prop and measure current if possible. Compare draw and RPM side-by-side. Feel for quick heating and note any roughness. “Commutator brushes are plates that overheat quickly,” so watch temperature rise closely. Extra gearbox resistance also flags a bad corner. [Elektroda, 1 PAWEL, post #17184995]
One prop stops faster when I cut throttle. What does that indicate?
Asymmetric spin-down indicates nonuniform drag or braking. Treat the quick-stopping corner as suspect. Inspect that gear train and motor for wear or binding. Confirm proper prop type and orientation on that arm. Resolve mechanical differences before chasing electronics. [Elektroda, 1 PAWEL, post #17182972]
When do I suspect the flight controller is damaged?
Suspect electronics after you rule out battery sag, prop imbalance, motor wear, and gear drag. If symptoms persist across motor swaps and fresh props, the board may be faulty. Replace or reflow connections only after mechanical checks pass. [Elektroda, 1 PAWEL, post #17184995]
