Increase Livebox 2.0 WiFi Range: Budget-Friendly Devices & Solutions for Apartment Connectivity
adriano1191 7644 11
How can I cheaply extend the Wi‑Fi range in an apartment when the router is a Livebox 2.0 and I want a wireless link without running cables?
The most reliable solution is not a wireless repeater, but running an Ethernet cable to a small access point/router in the middle room, because Livebox 2.0 has no external antenna and repeaters/AP clients can be troublesome with it [#17202939] [#17203005] Repeater mode is described as slow, unreliable, and unstable, and Livebox can have problems assigning LAN addresses to devices behind an AP client/repeater unless the setup is configured carefully [#17203005] If you can’t use a normal cable, people suggested a flat Ethernet cable under a door or through a window pass-through, then using a cheap AP/router such as TL-WR740N with Gargoyle [#17203692] [#17203408] If you still want to try wireless, an AP client or repeater can work only where the Livebox signal is around -70 dBm, but it may still be problematic [#17203005] It was also suggested to check whether the issue is just crowded 2.4 GHz channels and to try changing the Livebox channel with a tool like InSSIDer [#17203714]
  • #1 17202928
    adriano1191
    I need something that will increase my wifi range in the apartment. I have Livebox 2.0 in one room and unfortunately, but in the last room the range is minimal. I need some inexpensive (within +/- PLN 100) device that I can, for example, put in the middle room, with which I will connect from the last room.
    The most important thing is that it connects to the livebox wirelessly and passes the signal wirelessly. Unfortunately, cables are out of the question.
  • #3 17202959
    waldek123
    Help: 17
    Rate: 45
    Repeter wi-fi
  • Livebox repeater mode is slow and unreliable
    #5 17203005
    matek451
    Help: 4352
    Rate: 5808
    It's Livebox, so using an AP Client or repeater means trouble. Livebox has problems assigning LAN addresses after DHCP to devices connected to AP Client / Repeater. Requires DHCP server to run on AP Client.Repeater, i.e. proper configuration of both devices. The AP Client must be in a place where the WiFi signal from Livebox is around -70dBm. AP Client works in one network with Livbox, receives via WiFi and then via LAN cable. Repeater is a slow, unreliable and unstable mode, one radio receives and transmits over WiFi
  • Livebox repeater needs proper DHCP setup
    #6 17203007
    adriano1191
    I think I will invest in such a small repeater.
    Thanks for the offer.
    edit:
    Hmm, I don't know now.
    I've used something like this before. I have an old tplink TL-WR543G and it connects to the Livebox wirelessly and then gives me the Internet cable. The problem is that currently I don't really have a place to put it so that it catches a good signal and that's why I was thinking about some completely wireless solution
  • #7 17203051
    krzysiek_krm
    Level 40  
    Help: 716
    Rate: 599
    Maybe from another barrel.
    There are probably some solutions that "extend" the network with the help of electrical installation.
  • #8 17203242
    matek451
    Help: 4352
    Rate: 5808
    WR-543 connects to WiFi in the Client Router or WISP mode, and then you have a second WiFi network created by him at home. Devices connected to Livebox and WR-543 are in different networks and cannot see each other. WR-543 does not have AP Client mode. If you are satisfied with such a solution, use it.
  • #9 17203254
    myszkoscielna
    Help: 62
    Rate: 31
    PPK wrote:
    All you have to do is drag the ethernet cable and possibly a small accespoint. Such as e.g. https://www.emag.pl/punkt-dost...PlRCh2sbAe6EAQYAyABEgJLXPD BwE
    I support this proposal
    avoid repeaters, this WIFI mode is generally known for its problematic operation.
  • #11 17203692
    makosuu
    Help: 369
    Rate: 370
    I think it's better than a repeater, I have a 5m flat Ethernet cable to pass under the door and it works well. As an AP or repeater, I recommend TL-WR740N with preloaded Gargoyle. Good price and possibilities.
  • #12 17203714
    PPK
    Level 30  
    Help: 94
    Rate: 428
    It is worth checking if the coverage problems are caused by the "clogging" of 2.4 GHz WiFi channels. I change the channel at least once a month (manually) because around 34 different devices work in the area and most are configured for 1; 6th and 11th channel. I use InSSIDer to check.
To enhance the WiFi range of a Livebox 2.0 in an apartment, users suggest several budget-friendly solutions. While the Livebox lacks an external antenna, options include using a wireless repeater or access point (AP). However, concerns arise regarding the reliability of repeaters due to potential DHCP issues and signal instability. Recommendations include the TP-Link TL-WA901ND and ASUS RPN12 as viable access points. Users also discuss the possibility of using powerline adapters to extend the network through electrical wiring. Ultimately, running an Ethernet cable to a strategically placed access point is considered the most effective solution, with the TL-WR740N recommended for its performance and affordability.
TL;DR: Apartment Wi‑Fi often runs amid around 34 devices; "It is worth checking if the coverage problems are caused by the 'clogging' of 2.4 GHz WiFi channels." Best fixes: cable an AP from Livebox 2.0, optimize channels; avoid basic repeaters. [Elektroda, PPK, post #17203714]
Why it matters: This FAQ helps apartment users with Orange Livebox 2.0 get reliable, budget Wi‑Fi to the last room without messy installs.
What’s the most reliable way to extend Livebox 2.0 Wi‑Fi in an apartment?
Run an Ethernet cable from the Livebox and add a small access point in the target room. Livebox 2.0 lacks external antennas, so relocating the radio with an AP is effective. This keeps things simple and robust for multi‑room coverage. [Elektroda, PPK, post #17202939]
Will a simple Wi‑Fi repeater work well with Livebox 2.0?
Not reliably. Livebox can fail to assign DHCP addresses across repeaters or AP‑clients. You must run DHCP on the client and configure both devices. “Repeater is a slow, unreliable and unstable mode, one radio receives and transmits over WiFi.” [Elektroda, matek451, post #17203005]
Where should I place a repeater or AP‑client to avoid dead zones?
Place it where the Livebox signal measures about −70 dBm. That provides a usable backhaul. With an AP‑client, receive over Wi‑Fi there, then carry the connection by LAN cable into the last room. [Elektroda, matek451, post #17203005]
How do I fix Livebox DHCP issues when using an AP‑client or repeater?
Enable the DHCP server on the AP‑client and align settings on both devices. Livebox has trouble giving LAN addresses through AP‑client or repeater links without that. After enabling, verify leases and connectivity from the far room. [Elektroda, matek451, post #17203005]
Can I use a flat window/door Ethernet pass‑through instead of drilling?
Yes. A flat Ethernet cable under a door or window works. One user runs a 5 m flat Ethernet under a door successfully and found it better than a repeater. You can pair it with a TL‑WR740N running Gargoyle as an AP. [Elektroda, makosuu, post #17203692]
Does Livebox 2.0 support external antenna upgrades?
No. Livebox 2.0 has no external antennas to replace or reposition. To improve coverage, move the Wi‑Fi endpoint by cabling an access point into the needed room. [Elektroda, PPK, post #17202939]
Are powerline adapters a viable alternative when I can’t run cable?
Yes. You can extend the network using devices that work over the electrical installation. This approach can link rooms without pulling an Ethernet cable through walls. [Elektroda, krzysiek_krm, post #17203051]
How do I pick a better 2.4 GHz channel in a crowded building?
Scan and change channels manually. One user observed about 34 nearby devices and adjusts monthly using InSSIDer. How‑To:
  1. Scan with InSSIDer to see congested channels.
  2. Set the Livebox to a less‑used channel manually.
  3. Re‑scan monthly and adjust if neighbors shift. [Elektroda, PPK, post #17203714]
Will my TL‑WR543G bridge Livebox seamlessly?
No. TL‑WR543G connects as Client Router or WISP, then creates a second Wi‑Fi network. Devices on Livebox and TL‑WR543G sit on different networks and cannot see each other. It lacks a true AP‑Client mode. [Elektroda, matek451, post #17203242]
Which budget router/AP should I consider for this job?
TP‑Link TL‑WR740N with preloaded Gargoyle is recommended as an AP or repeater. It offers good capabilities at a low price point for this use. Configure it as an access point when possible. [Elektroda, makosuu, post #17203692]
If I must stay wireless, what setup is least painful with Livebox 2.0?
Use an AP‑client where Livebox signal is roughly −70 dBm and run a short LAN cable into the final room. Avoid pure repeater mode, which is slow and unstable on a single radio. This keeps one network across rooms. [Elektroda, matek451, post #17203005]
What budget should I plan for an extender or AP?
The thread’s target was an inexpensive device around ±PLN 100. If you follow a similar budget, look for entry‑level access points or small routers that can run as APs. [Elektroda, adriano1191, post #17202928]
Is ASUS RP‑N12 a good match for Livebox 2.0?
ASUS RP‑N12 was suggested as a repeater option, and similar models exist from other brands. If choosing a repeater, confirm placement and compatibility during setup. [Elektroda, krzysiek_krm, post #17202969]
