Expanding Wi-Fi Coverage and Connecting LAN Device Without Cables
barteksmrek 14091 20
How can I connect a LAN-only device in another room to my Sky Wi‑Fi without running Ethernet cable, and how can I extend the Wi‑Fi range in my apartment?
Use either a PLC/powerline pair or a small router configured as a wireless client/bridge to link the remote LAN device without pulling cable; examples mentioned were TL-WR702N, Nexx WT3020, TL-WA850RE, and a PLC kit with Wi‑Fi AP [#17270864][#17272118][#17272160][#17274997] For a single LAN device, AP Client/bridge mode is enough because the box receives Wi‑Fi from the Sky router and provides Ethernet on the other side [#17270864][#17275054] PLC was described as the better choice in most situations, while repeater mode is less stable and cuts speed by at least half [#17275019][#17275054] If you do use a repeater/extender, place it where it still gets roughly -70 dBm from the Sky router so the link is usable [#17275054] For the kitchen coverage issue, a TL-WA850RE extender was reported to work well with Sky and can also feed an RJ-45 device [#17274997][#17275019]
  • #1 17270853
    barteksmrek
    Help: 89
    Rate: 224
    Hello. I have this issue. I have a Wi-Fi router with a LAN switch and an ADSL modem in my apartment. The supplier is SKY. There is no problem with wi-fi. I want to buy a LAN device and place it somewhere else. I don`t want to pull cables from the router. I would like to place, for example, an AP or other Wi-Fi router next to the device to communicate with the Sky one and connect the device via LAN. What do you recommend? How to solve it? One lan needed.
    Another issue is the range of this sky because I no longer have Wi-Fi in the kitchen. How to confide in him? this sky has no antenna.
  • #3 17270885
    barteksmrek
    Help: 89
    Rate: 224
    Cool.
    Is there anything, for example, for a power socket? That is, I plug the device into the socket and a LAN cable from the Sky router. I plug the second device into another socket and connect my device using a LAN cable. I read about it somewhere.
  • #4 17270899
    jdubowski
    Tube devices specialist
    Help: 2511
    Rate: 2804
    Keyword: PLC
  • #6 17270984
    barteksmrek
    Help: 89
    Rate: 224
    Which solution is better? WR needs power too.
  • #7 17271093
    makosuu
    Help: 369
    Rate: 370
    PLC goes through cables, Wi-Fi goes wirelessly. I would choose a PLC (the ones from the link above are good) or a router with an alternative FW. Because it offers huge opportunities.
  • #8 17271099
    barteksmrek
    Help: 89
    Rate: 224
    makosuu wrote:
    The PLC goes via cable
    Yes. But from what I understand, these are the cables that power the power socket. So it`s as if they didn`t exist.
    Added after 1 [minute]:
    makosuu wrote:
    possibly a router with an alternative FW. Because it offers huge opportunities.
    Can you elaborate? For example, I want to be able to connect the disk to the router as a network drive.
  • #9 17271127
    makosuu
    Help: 369
    Rate: 370
    A router with an alternative FW, i.e. Nexx WT3020, TP-Link TL-WR740N or any other supported device (revisions matter). Preferably with USB, maybe you`ll need it someday. Because it has many applications. Just set it as a wireless bridge and you get what you want. And at the same time, it can take care of e.g. the VPN server, you can connect a camera via USB, or whatever you want to do.
  • #10 17271431
    barteksmrek
    Help: 89
    Rate: 224
    My device will be a home theater amplifier. Some of them have a USB signed DC out for lan adapter next to the LAN. This is a USB LAN power adapter. I mean an adapter powered by USB.
  • #11 17272118
    makosuu
    Help: 369
    Rate: 370
    It may be Nexx WT3020 (it is powered by USB 5v). It may also be the above-mentioned TL-WR702N.
  • #13 17274653
    barteksmrek
    Help: 89
    Rate: 224
    Is it possible to use another such Sky router "Sky Router Hub SR101 Wireless Hub" for configuration, e.g. WPS, and from there connections to amplifiers?
  • #14 17274771
    makosuu
    Help: 369
    Rate: 370
    There is no support for alternative FW and it`s an ADSL router so almost certainly not.
  • #15 17274997
    makosuu
    Help: 369
    Rate: 370
    PLC is a better solution in most situations. Not to mention alternative FW on some device. It does the same and much, much more if you want. The TL-WA850RE is also supported by the way.
  • #17 17275024
    barteksmrek
    Help: 89
    Rate: 224
    You only have this one device? I understand it works with the sky router. So I just plug the LAN cable into the socket and the amp and that`s it? But how does it extend wi-fi? Unless it has a receiver and transmitter.
    matek451
    Help: 4352
    Rate: 5808
    There is no way to write nonsense like @pong. Chu . Only someone who has no idea about the subject can compare the unreliable repeater mode with PLC. A friend of mine wants to power his receiver via USB and he recommends the WA-850. The WR-702 is not an invention and also has a Repeater mode. A discussion without measuring the signal parameters from the SKY router at the receiver is pointless. Both the Ap Client and the repeater must have a signal level of approximately -70dBm in this location. The repeater uses one radio for reception and further transmission, is not very stable and, by definition, cuts the speed by at least half. AP Client only receives via WiFi and then only via LAN.
  • #19 17275093
    barteksmrek
    Help: 89
    Rate: 224
    That`s why I asked if he had two radios. My friend Pong thinks that why do I need the Internet in my amp? For example, for internet radio, i.e. streaming. There is no question of the proposed device. Only wifi reception and then a cable.
  • #20 17275122
    makosuu
    Help: 369
    Rate: 370
    The TL-WR702N was recommended above and it basically solves everything. Similar design, e.g. TL-MR3020, but it will not be a transparent client on OFW.
  • #21 17275206
The discussion revolves around expanding Wi-Fi coverage and connecting a LAN device without running cables in an apartment setup with a SKY ADSL modem. The user seeks recommendations for devices like access points (AP) or routers that can wirelessly connect to the SKY router and provide a LAN connection to a home theater amplifier. Suggestions include using Powerline Communication (PLC) devices, such as the D-Link Powerline AV500, or wireless routers with alternative firmware like the Nexx WT3020 and TP-Link TL-WR702N. The TL-WA850RE is also mentioned as a viable option for connecting devices via LAN while extending Wi-Fi coverage. The conversation highlights the advantages of PLC over traditional Wi-Fi repeaters, particularly in terms of stability and speed.
TL;DR: Extending Sky Wi‑Fi and wiring one LAN device? Repeaters can cut throughput by 50%, and "use one radio for reception and transmission." Prefer an AP Client bridge or Powerline (PLC) for stability and streaming audio. [Elektroda, matek451, post #17275054]
Why it matters: You’ll avoid unstable repeaters and get reliable Ethernet over Wi‑Fi or mains wiring without drilling.
How do I connect a LAN‑only device to my Sky Wi‑Fi without running a cable?
Use a tiny router in AP Client (client/bridge) mode. A TL‑WR702N can bridge your Sky Wi‑Fi to the amplifier’s Ethernet. Power it from the amp’s USB port if available. Connect the amp to the nano‑router with a short LAN cable. This gives the amp internet without pulling new wires. It’s a cheap, compact solution designed for single‑device wiring. [Elektroda, matek451, post #17272160]
Which is better for stability: Wi‑Fi repeater, AP Client bridge, or Powerline (PLC)?
Avoid single‑radio repeaters for primary links. "The repeater uses one radio... and cuts the speed by at least half." AP Client bridges keep a clean Wi‑Fi link and hand off to Ethernet. PLC uses your electrical wiring and avoids the repeater penalty. For steady streaming, choose AP Client or PLC over a repeater. [Elektroda, matek451, post #17275054]
Will a TL‑WA850RE work with a Sky router to give Ethernet to an amp?
Yes. Configure the TL‑WA850RE to join your Sky Wi‑Fi, then connect the amp to its Ethernet port. One user notes it "works very well" with SKY and serves two wired devices via a small hub. Remember, as a single‑radio repeater, total Wi‑Fi throughput will be reduced compared to a wired backhaul. [Elektroda, Anonymous, post #17274997]
How do I set up a TL‑WR702N as a Wi‑Fi‑to‑LAN bridge (AP Client)?
  1. Switch the WR702N to Client/AP Client mode in its web UI.
  2. Scan for your Sky SSID, select it, and enter the Wi‑Fi password.
  3. Save and reboot, then plug the amp into the WR702N’s LAN port. This bridges Wi‑Fi to Ethernet for one device cleanly. [Elektroda, matek451, post #17270864]
Can I power the Wi‑Fi bridge from my amplifier’s USB port?
Yes, many nano routers accept 5 V USB power. The TL‑WR702N is commonly powered this way, even directly from an AV receiver. This keeps the setup tidy near your amp. As one recommendation put it: "USB power supply from the receiver." Confirm your USB port provides enough current. [Elektroda, matek451, post #17272160]
Can I use a second Sky SR101 as a wireless bridge via WPS?
No. The SR101 lacks alternative firmware and client‑bridge capability. It’s an ADSL router and not suitable for acting as a wireless client bridge. Use a client‑capable nano router or a PLC kit instead. As one expert summarized, it’s "almost certainly not" supported. [Elektroda, makosuu, post #17274771]
What signal strength do I need at the device location?
Aim for about −70 dBm or better at the amp’s spot. Below that, repeaters and client bridges become unstable and slow. "Both the AP Client and the repeater must have a signal level of approximately −70 dBm." Consider moving the Sky hub, or use PLC if Wi‑Fi is too weak. [Elektroda, matek451, post #17275054]
Is streaming internet radio heavy on bandwidth?
No. Internet radio uses modest bandwidth. One user notes, "even good quality audio is a small data stream (320kbps with a 20Mbps connection...)." AP Client or PLC easily handles this. Ensure your link is stable rather than chasing maximum Wi‑Fi speed for audio. [Elektroda, Anonymous, post #17275206]
What extras can an alternative‑firmware router provide?
On supported devices, alternative firmware can enable wireless bridging plus advanced features. You can run a VPN server or attach USB peripherals. A user cites models like Nexx WT3020 or TL‑WR740N. Quote: "it can take care of e.g. the VPN server." Check hardware revision support first. [Elektroda, makosuu, post #17271127]
Will a TL‑MR3020 work as a transparent client on stock firmware?
Not on stock firmware. A member reports the TL‑MR3020 "will not be a transparent client on OFW." If you need a pure bridge without NAT or routing, choose the TL‑WR702N or consider alternative firmware on supported hardware. [Elektroda, makosuu, post #17275122]
How do Powerline (PLC) adapters work for this?
Plug one PLC unit by the Sky router and connect it via Ethernet. Plug the second PLC unit where the amp sits and connect its LAN port to the amp. Some kits include built‑in Wi‑Fi to extend coverage as well. Example: a D‑Link AV500 starter kit with Wi‑Fi AP. [Elektroda, matek451, post #17270915]
Do repeaters need two radios to avoid speed loss?
Single‑radio repeaters repeat and forward on the same radio, which halves throughput. That is why they often feel slower. Client mode avoids this penalty for wired devices because it does not rebroadcast Wi‑Fi. Dual‑radio gear helps, but simple nano repeaters are single‑radio. [Elektroda, matek451, post #17275054]
Will a WR702N also extend Wi‑Fi coverage, or just bridge to Ethernet?
It can do both. In Client mode it bridges Wi‑Fi to Ethernet for one device. It also supports Repeater mode to extend coverage, but expect reduced throughput due to the single‑radio design. As noted, the WR‑702 "also has a Repeater mode." [Elektroda, matek451, post #17275054]
What should I search for if I want LAN over a power socket?
Search for PLC or Powerline networking adapters. These carry your network over existing electrical wiring and give you an Ethernet jack at another outlet. Many kits are marketed as AV500 or similar. Start with the keyword suggested: PLC. [Elektroda, jdubowski, post #17270899]
