[Solved] Audi A4 B5 1.8 125km ARG Engine Choking Issues: Troubleshooting and Solutions
igor13 5925 7
  • #1 17218510
    igor13
    Hello, I have a problem with my Audi, namely that it does not suffocate when adding more gas, today it started to walk as if it was 3 grams and it started to shake the engine after twisting the candles, one is wet. choke it as if it triggered ignition when letting go of a little gas, I will add, and the vigilant position of the fight and shaft was replaced, and the adopted throttle fuel filter vacuum cooed (it was damaged) chain tensioner from variable valve timing, the only error is the lambda probe, but it was long ago Before the circuses with the engine started happening. Sa beru cables do not have to pierce the ngk coil plugs like a whole without cracks and other damage. Please help because I am fed up with asking and replacing unnecessary parts. Thank you in advance.
    Added after 22 [minutes]:
    For texts such as do not rummage and lead me to the mechanic, thank you, I have already been 3 and part of the mentioned parts is through their diagnosis and no improvement
    yezz
    Help: 7
    Rate: 117
    Check the flow meter, damaged shows similar symptoms.
  • #3 17218618
    igor13
    I forgot to add, no improvement was already mentioned
    yezz
    Help: 7
    Rate: 117
    Have you checked if a spark is on all four candles?
  • #5 17218770
    igor13
    Unfortunately, I did not have when to check tomorrow and maybe injections or not sometimes
    Today I just changed the candle quickly, it did not help
    przemek25l
    Help: 124
    Rate: 372
    Swap the coils and see.
  • #7 17218816
    igor13
    The coils do not change places, I have one double
    Added after 7 [minutes]:
    Something like that Audi A4 B5 1.8 125km ARG Engine Choking Issues: Troubleshooting and Solutions
  • #8 17220465
    igor13
    I close the topic, the coil fell
✨ The discussion revolves around troubleshooting choking issues in an Audi A4 B5 1.8 with an ARG engine. The user reports symptoms such as engine shaking, wet spark plugs, and a lack of power when accelerating. Various components have been replaced, including the throttle, fuel filter, and chain tensioner, but the problem persists. Responses suggest checking the flow meter, ensuring spark is present on all candles, and swapping ignition coils. Ultimately, the user concludes that the ignition coil was the source of the issue.
