Audi a4 b6 - Strange knocks in the engine above 2000 rpm 1.9 TDI AVF
pospiech8 7203 5
  • #1 16247730
    pospiech8
    Rate: 11
    I have a problem, there are strange metallic clicks from the head above 2,000. rev.
    I checked the oil pressure is at free 2 and higher up to 4 bar.
    Engine idle he works evenly, he does not lack his power.
    I am asking for a quick answer.
  • #2 16247802
  • #3 16248892
    bula17
    Help: 52
    Rate: 295
    Have a look at the camshaft and tappets.
  • #4 16249026
    pospiech8
    Rate: 11
    on the shaft on the third cylinder the cam is round and this is probably the reason
    bolus11
    Help: 6
    Rate: 23
    in general, 8 valve unit injectors had a certain drawback when it comes to head lubrication ;) then rollers and glasses wear out. Look carefully at the "bridges" from the levers that press the unit injectors
  • #6 16255647
